Old Nov 27, 2011, 11:14 AM
rabit123 is offline
Find More Posts by rabit123
Joined Oct 2009
any expert can tell me about the new message shown in the "servo deflection'?
I used the 10.04 firmware before(beta version), the value of "P 0 dt 0 d" , after the value of "Th E R G" , I known the 'G' is the gain of stabilzer. what is meaning of that?
Seemed after I used the formal 1004 version FW, the "p150 dT6 d " or value like this , changed in fly, not in RTH.
I am so lucky today, not sure why I trig RTH with alt at 34meters, then full throttle, E=-96, that should be climb, but the plane got down, below 20 meters, the throttle went to lowest , the plane auto landing in my runway, it is so fantastic.
rabit123 is offline Find More Posts by rabit123
Old Nov 27, 2011, 02:04 PM
CzechPilot is offline
Find More Posts by CzechPilot
CzechPilot's Avatar
Czech Republic, Prague
Joined Aug 2009
Originally Posted by zapi2 View Post
.... "Graphic Error 0D0000", ....
Out of sync caused by something else.
CzechPilot is offline Find More Posts by CzechPilot
Last edited by CzechPilot; Nov 28, 2011 at 06:40 AM. Reason: Different problem than I suggested
Old Nov 27, 2011, 02:12 PM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Hi Bill,
I have a new issue, "Graphic Error 0D0000", but as you can see in the video, nothing to disturb the guardian, only a cool flight in a very cool day.
I get this twice in my last 5 flights, the problem is that when it happens, EagleEye get completly crazy and change RX every half second. So the Trakking antenna also run crazy.
Fortunatly in this video the plane is returning and arriving to the landing point. Imagine this with the plane far away.
I am running the last 10.04 version.
Any idea?
http://www.youtube.com/watch?v=rx-DPRAqfq0
Tku
Eric
One thing I noticed in your video was that your GPS coordinates put you out in the Atlantic Ocean. Maybe you are flying FPV off of a cruise ship
38N 00W (or E00) is out in the ocean. Perhaps the two are related????
thekubiaks is offline Find More Posts by thekubiaks
Old Nov 27, 2011, 09:58 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Eagletree doesn't include the minus sign for west longitude. Try coordinates 38 21.8511, -00 32.3453.
Steve
Floater73 is offline Find More Posts by Floater73
Old Nov 28, 2011, 05:05 AM
Joined Aug 2010
Old Nov 28, 2011, 06:18 AM
zapi2 is offline
Find More Posts by zapi2
Dead_Stick_7060
zapi2's Avatar
España, Comunidad Valenciana, Alicante
Joined Jun 2003
Hi,
I have just check the coordinates of the video with my Google Earth there are correct. There is a small problem with the seconds, it is supposed that the latitude in the beginning of the video is not possible: 38º 21'. 85.94" N !!!
maximum is 59.99"
For info:
There are 3 types of coordinates:
1: degrees, min, sec. like this 39º 28' 5.19" N 0º 20' 33.17" W
(google Earth)
2: decimal degrees like this lat. 39.4681088 lon. -0.3425468
(google Maps)
3: utm (WGS84)
you can use this: http://www.mundivideo.com/coordenadas.htm
and I have been searching for the problem, I have double check my connections and everything is allright, but then I check the camera, and I finally found it, my problem is due to a bad welding of one pin on the main board of the camera Kx181-HQ.
So for me the issue is closed.
Sorry.
zapi2 is offline Find More Posts by zapi2
Old Nov 28, 2011, 06:35 AM
Joined Aug 2010
Old Nov 28, 2011, 10:27 AM
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Deleted.
Old Nov 29, 2011, 02:12 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
All, I wanted to update you on the status of the beta version of our software. There were some issues reported with 10.08, and none of the issues seemed to be related to any changes in 10.08. Also, a small bug was found in PC live mode with 10.08, so we removed the beta version.
I believe that the issues reported with 10.08 have now been found to be from other causes. Alpha version 10.12 is now posted, here, and a few people are running it now. It has the following changes:
- Fixes RSSI detection when running the PC version of the servo analysis wizard.
- Adds support for getting rid of the slight nonzero airspeed reading when the model is stationary.
- reduces/eliminates inadvertent menu trigger if an Rx glitch occurs during flight.
- greatly reduces or eliminates the occasional "error 0x0D000000/0xA000000" display (but see below).
We'd certainly appreciate help testing the above version, but it's not beneficial unless you are experiencing one of the above issues. And, of course full ground tests should be conducted since it's alpha software.
Zapi, I watched your video before I saw your last post, and was going to suggest there might be a loose ground wire from the camera. The Graphics Error D will appear if the synch signal from the is lost over and over, which will happen in your scenario. Glad you found it!
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 29, 2011, 03:50 PM
mamut is offline
Find More Posts by mamut
mamut's Avatar
Romania,Est Europe
Joined May 2004
Hi Bill
Can you make an upgrade for pan&tilt the emitter antenna(5.8 Ghz little patch) to the ground station, something similar to pan/tilt camera connected to OSD?
Why waist so much energy around...
mamut is offline Find More Posts by mamut
Old Nov 29, 2011, 04:10 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Bill,
Question for you. Is the USB connector on the V4 e-Logger a standard mini USB connector or a lesser know one? I purchased one and found that I don't have the proper USB cable for it and have to use the 4-pin connection instead.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Nov 29, 2011, 04:31 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by healthyfatboy View Post
Bill,
Standard mini
has to be deep, not the shallow ones.
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Nov 29, 2011, 04:43 PM
brifa is offline
Find More Posts by brifa
brifa's Avatar
ITALY
Joined Aug 2006
Hi
we are doing a bench test for the tracking function using 2 hitec hs645mg on a wood eagle pan/tilt mechanism and we saw that servo seem to have not enough power... in other word when we do a simulation if we push a little the pan movement the pan tilt stops... if we move by hands it, servos have not power... is it normal??
and say that when we test the servos with a servo tester they work fine.. so i don't think it's a problem of the servos..
please help us
brifa is offline Find More Posts by brifa
Old Nov 29, 2011, 04:53 PM
sverlander is offline
Find More Posts by sverlander
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
Ok I have a question about updating the software version. How do you manage all the different software upgrades?
When I first got the ET system I loaded the newest version on my main computer and upgraded everything but that was over a year ago. I just upgraded everything to version 10.4 but I installed the program on my laptop computer so it was the first install. So my question is how do I update my laptop from 10.4 to the new 10.8 ? If I download 10.8 and install it will it install over top and erase 10.4? Or do you install in a different directory and have both 10.4 and 10.8? Do you save your setup file in a folder separate from the ET software and how do you label each file so they don't get mixed up, by date, number. What's your system.
sverlander is offline Find More Posts by sverlander
Old Nov 29, 2011, 04:58 PM
Joined Jan 2007
Originally Posted by m_beeson View Post
Standard mini
-Mike
Hmmm...I guess looking at it, they are the same as they have the same number of contacts. Looking at the outer casing, I guess I took too quick of a look and thought it was not the standard mini connector.
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
