Old Sep 29, 2011, 12:08 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Ok so I'm not going crazy LOL. While I didn't run the servo wizard on the PC I do get a "1" for my RSSI on both of my 10.04 ETOSD Pros. I haven't flown them and think that the 1 represents 100% and therefore will get normal numbers when the plane is further away in-flight (ie 91%, 88% etc).
Would be interesting to hear if others have run into this.
Originally Posted by catsw View Post
Hi All!
I`m find some interesting on 10.04 - if I run servo wizard via PC - RSSI don`t working - always show "1"!
But when I run wizard via RC - RSSI working fine...
Can anybody repeat (test) it???
AdamChicago is offline Find More Posts by AdamChicago
Old Sep 29, 2011, 01:02 PM
catsw is offline
Find More Posts by catsw
Joined Sep 2010
No, I try different distance and power TX, and some time I see "2" or "3" - 200%..300% ??
Also I try restart OSD w/o USB (from flight battery), no change at all.
When I set "use TEMP1 as RSSI" to NO - I can see RSSI, but not 1....100% - 15(TX off)...35(TX in power and near).
Only when I run wizard from RC - RSSI working fine!
catsw is offline Find More Posts by catsw
Old Sep 29, 2011, 02:01 PM
Protocrash is offline
Find More Posts by Protocrash
Joined Jan 2010
Guys,
Just want to make sure I'm not about to suicide my plane this weekend (I've raised a proper ticket with ET but that may take a while)...
I recently updated the firmware on my elogger and OSD to 5.84 and 1.96 respectively (which I gather are the latest?). It seemed to go OK
The weird thing is that when I click on firmware control one of two things happens:
a) It says I've got elogger v0.00 and accelerometer v unknown (I don't even have an accelerometer)
b) says I've got the right version but the update buttons are active
I read a previous post that suggested this may be an accident waiting to happen...
Any ideas?
Protocrash is offline Find More Posts by Protocrash
Old Sep 29, 2011, 04:42 PM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
I also got "1" for RSSI when setting up 10.04 from PC. I haven't tried via RC. I changed tmpA back to temperature again as that does indicate RSSI. The scale is off (showing 5-40 for DragonLink) but I get the idea.
FpvKiwi is offline Find More Posts by FpvKiwi
Old Sep 30, 2011, 01:54 AM
WEIDI. is offline
Find More Posts by WEIDI.
Copter-FPV rules
WEIDI.'s Avatar
Österreich
Joined Mar 2009
Let me start by telling you, that changing my wiring seems to work!
I connected +5V and ground to the OSD and on the testflight yesterday, there was no issue anymore .. knock on wood ;-)
To your answers:
Originally Posted by mr..speed View Post
As long as there is no electrical short on the board that should not be a problem.
There is no short on the board, as I already tried a different OSD unit with the same result.
Originally Posted by thekubiaks View Post
What I observed is that if I only power the OSD, the eLogger will start up but hang (and vice versa, power eLogger not the OSD). To fix the problem, both batteries need to be connected.
That's what I'm observing, too. Good to hear, I'm not the only one ;-) Thank you for your tipp pointing out exactly my problem!
What I don't understand is, that, although one can operate the OSD without any connection to the receiver (there is no need to connect the AUX-channels to operate the OSD unless changes have to be made during flight), the manual is not pointing out this powering issue.
Furthermore, although previously a 12V connection was routed through the OSD for camera and VTx, the OSD permanently hang during operation (running motor).
Originally Posted by Thint1 View Post
do you have routed the vid-minus also through the osd? then you had build up ground-loop ... bad emv situation. may cause a malfunction in the osd.
To get a common ground, I thought, it would be mandatory to connect both grounds of the batteries. But I think you're referencing to the ground looping the BEC ground, don't you?
Let me question you:
if no ground would be routed through the OSD, wouldn't it be a problem for the video signal to reference to?
In other words: if there were no ground, wouldn't the video signal get worse similar to FpvKiwi's trouble? (1 page ago)
Anyway, I'll continue testing on the weekend and let you know!
Thx for your support & ideas!
WEIDI. is offline Find More Posts by WEIDI.
Old Sep 30, 2011, 03:30 AM
3frcg is offline
Find More Posts by 3frcg
Joined Jul 2010
Hi Billpa,
would you also make the i2c protocoll for the Guardian module available?
Best regards
3frcg is offline Find More Posts by 3frcg
Old Sep 30, 2011, 10:03 AM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
I did a little testing on the OSD... something that I dont think most know...
On the OSD's video and audio, the Positive pins are isolated from the rest of the board, or seems to be.
I think what this means is, you can pass through you signal, power and ground to your camera and mic, saving some time making wire harnesses.
Does anyone else do this?
GregSilver is offline Find More Posts by GregSilver
Old Sep 30, 2011, 10:24 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Yes i included a picture some page ago to a french member explaining the way to get power to those pins.
It is well explained in the manual too ;-)
bakchos is offline Find More Posts by bakchos
Old Sep 30, 2011, 10:49 AM
GregSilver's Avatar
Joined Nov 2005
manual?
lol...whats that?
Old Sep 30, 2011, 11:33 AM
CzechPilot is offline
Find More Posts by CzechPilot
CzechPilot's Avatar
Czech Republic, Prague
Joined Aug 2009
Originally Posted by dgpilot View Post
..... can I copy settings from another easy star ....
Hi
As I could control only 2 surfaces and throttle, could some of you confirm that BigWingEasyStar mod to V-tail like this Hobbyking Solo EPO, but without ailerons will work?
Turnigy 9x equipped planes without Frsky Tx/Rx have servos left in acctual positions when signal lost / that's why I have to decrease the number of surfaces i the case of autopiloting by ET.
CzechPilot is offline Find More Posts by CzechPilot
Old Oct 01, 2011, 11:47 AM
rabit123 is offline
Find More Posts by rabit123
Joined Oct 2009
A good way to trig RTH? (I am not sure with throttle cut switch)
seemed a good way to trig RTH, use the throttle trim down, to active the failsafe,than RTH. the FS was designed in the transmitter that support PCM FS. I use the throttle cut switch(matched to a switch), that simulated the throttle trim down ; can trig the RTH with toggle switch. that is more easy way? I had tested it with 9C, work great.
rabit123 is offline Find More Posts by rabit123
Old Oct 01, 2011, 11:59 AM
rabit123 is offline
Joined Oct 2009
Hi Bill ,
I have a question about the cruise speed in RTH. What about the logic? After reached the cruise altitude, use the level flight throttle? what about the speed control?
I concern that we use the pitot, that can make RTH work when met the strong headwind, almost zero or backword ground speed(spdG)?
thanks
Old Oct 01, 2011, 11:52 PM
1111Mavrick is offline
Find More Posts by 1111Mavrick
1111Mavrick's Avatar
Canada, BC, Gibsons
Joined Apr 2011
I think i know the answer to this question, but I'm hoping someone has come up with a workaround, is there a way to plug the OSD pro AND the power-panel in at the same time?
Oh i hope there is a way.....
Mark
1111Mavrick is offline Find More Posts by 1111Mavrick
Old Oct 02, 2011, 05:26 AM
vertigo79 is offline
Find More Posts by vertigo79
vertigo79's Avatar
Australia, NSW, Holsworthy
Joined Feb 2008
Hi
Ok, trying to setup rth, but on the sim, instead is coming back, it circles where ever it is. Its setup with a guardian if that helps. I have tried the safety wizard and guardian wizard, but nothing seems to work.
I'm running 10.4 if that helps, firmwares updated all through
Anyone had this before?
vertigo79 is offline Find More Posts by vertigo79
Old Oct 02, 2011, 06:04 AM
zapi2 is offline
Find More Posts by zapi2
Dead_Stick_7060
zapi2's Avatar
Espaņa, Comunidad Valenciana, Alicante
Joined Jun 2003
OSD PRO messages
Hello,
Is there any thread or document (for ex. PDF) with all the OSD PRO messages and the explanation of each one??
Tku
zapi2 is offline Find More Posts by zapi2
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
