Old Jun 13, 2011, 09:17 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Please help with the "Calibrate Throttle" settings on the eLogger PC application. I have the the USB plugged into the PC, the eLogger PC application running, the plane is powered and ready...when I go into the "Calibrate Throttle" option and follow the instructions to move the throttle full open (up all the way) and the motor on the plane is spinning at full throttle, the little meter on the PC screen doesn't move...I left the throttle open for about 20 seconds and nothing happened...do I just need to go longer or is something not working.
Thanks again!
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 13, 2011, 09:21 PM
Chicago, IL USA
Joined May 2010
Sorry, you're right...I didn't put a resister on the RSSI, it was the secondary battery wire that I did that. BUT the RSSI indicator is still not working
Originally Posted by Targetlocman View Post
You don't need a resistor for the rssi connection only for voltage measurements.
Old Jun 13, 2011, 09:23 PM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
ok make sure your rssi cable is attached to the center pin.
billyd60 is offline Find More Posts by billyd60
Old Jun 13, 2011, 09:48 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Adam,
I hooked up RSSI with ground, and it whacked everything out.
I used just RSSI, and it works great.
RSSI will not calibrate, until you go through the safety wizzard. When it prompts you to turn off your transmitter, and turn it on, RSSI is calibrated...
m_beeson is offline Find More Posts by m_beeson
Old Jun 13, 2011, 09:53 PM
billyd60 is offline
Joined Mar 2006
Originally Posted by m_beeson View Post
Adam,
I had the same thing happen! Yes don't use ground, signal only, and make sure you are connected to the center pin. You will still have to go through the safety wizard once you have it connected right. If it still doesn't work I suggest checking your solder joint on the LRS rx and make sure you've got a good connection on that end of things.
Old Jun 14, 2011, 01:19 AM
danhamilton is offline
Find More Posts by danhamilton
danhamilton's Avatar
France, IdF, Livry-Gargan
Joined Jun 2011
Totally confused...am I the only one who is not on the cool new firmware versions and cannot find the downloads on ET's site nor have options for them in the PC eLogger Data Recorder software?????
Please confirm I'm on the right versions:
- eLogger V4 firmware version 1.03
- OSD Pro firmware version 1.96
- eLogger Application version 9.13
You have the last versions.
What are you looking for on ET's site ?
Only Applications Data Recorders can be find, not firmware, it's upgrade process that directly connect to internet for download firmwares..
Have Fun with FPV.
Dan
danhamilton is offline Find More Posts by danhamilton
Old Jun 14, 2011, 10:26 AM
Chicago, IL USA
Joined May 2010
That's what I've got...RSSI Rx center pin out to OSD Pro Temp1(a) in.
Old Jun 14, 2011, 10:30 AM
Chicago, IL USA
Joined May 2010
Well I've seen posts like this and others that have different/newer firmware versions, so I thought my versions were old??
"Originally Posted by billpa View Post
fordarrick, There was an issue in software version 9.43/OSD Pro firmware version 2.16 that was causing that message to display incorrectly. That should have been fixed in version 9.44/2.17 and later. Can you let me know what firmware version is displayed on the video screen by your OSD Pro, when you start up?"
Have Fun with FPV.
Dan
Old Jun 14, 2011, 01:17 PM
billyd60 is offline
Joined Mar 2006
No the center pin on the osd pro temp input. The rssi on the rx is on a solder point, there is no pin. It would be the 4th pin on the 12th channel. You have to add your own.
Old Jun 14, 2011, 01:35 PM
Chicago, IL USA
Joined May 2010
There acually are RSSI out pins on the Thomas Scherrer LR UHF, but I may not be using the right pin(s)...thanks for reminding me of this. On my RangeVideo OSD you just plug the full 3-wire servo cable from the Rx to the OSD but on OSD Pro you just input the signal wire into the OSD but I'm not entirely sure which pins to use out of the Rx.
Old Jun 14, 2011, 05:05 PM
billyd60 is offline
Joined Mar 2006
Well I have the diversity rx from Scherrer. On the 12th channel, there is a 3 pin connector, but if you want rssi, you have to add a 4th pin to the 12th channel location.
Old Jun 14, 2011, 08:31 PM
Chicago, IL USA
Joined May 2010
I must have a newer version or something with the RSSI pin: (note photo of Scherrer LR UHF Rx below)
However you helped me figure out that I probably have the wire coming off of the wrong pin. I think I pulled from the standard signal pin instad of the 4th RSSI pin...I hope that's it!
Old Jun 14, 2011, 10:13 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
I have a noob question about the rssi.
I have a Futaba rx with a rssi buffer setup. It works fine, however the numbers seem arbitrary to me. Should it read 100 for full and 0 for failsafe?
GregSilver is offline Find More Posts by GregSilver
Old Jun 14, 2011, 10:20 PM
Chicago, IL USA
Joined May 2010
Greg, not too much help here, but when I set up my RSSI reading in RangeVideo OSD (read from the Scherrer LR UHF Rx) it gives you numbers from like 0 - 900 and then you select the min and max values after testing them (ie max is when Tx is near Rx and min is when Tx is far away from Rx). Then those weird numbers are converted into a percent of 100% on the OSD screen. So "I THINK" you maybe seeing those 0 - 900 numbers...what that means I'm not sure...packets etc?? So what you maybe seeing are those weird 0-900 numbers. There maybe a setting you can select to show the percent instead??
Good luck.
Old Jun 14, 2011, 10:43 PM
GregSilver's Avatar
Joined Nov 2005
I know I can calibrate it in the safety wizard, but it seems to change each time I power up.
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
