Old Aug 22, 2009, 05:11 PM
RCWingFlyer is offline
Find More Posts by RCWingFlyer
Naza, Rabbit, FF, MWC, FY
Saint-Petersburg Russia
Joined Jun 2008
Just completed all of these steps... The error message still remainings on the OSD screen (not in windows app!!!)
RCWingFlyer is offline Find More Posts by RCWingFlyer
Old Aug 22, 2009, 05:56 PM
Tom in Cincy is online now
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
It will eventually work. Try loading in the previous firm ware for both units. repeat the factory resets. How did the problem start? Did it ever fail when you were programming?
Tom in Cincy is online now Find More Posts by Tom in Cincy
Old Aug 22, 2009, 07:02 PM
Joined Jun 2008
Oh guys.... i am in panic!!! I am trying to update FW in my second, reserved OSD Pro... The error on the osd screen was appear the same... Internal error 03 contact support
now i have two OSD pro and both of them doesnt work properly....
application ver 7.83 from ET site
and now error @56 was appear every time i am trying to save OSD Pro's settings
Old Aug 22, 2009, 07:51 PM
Tom Para
Joined May 2003
I have seen all this before. Keep going. You have yet to get OSD Internal Error 05. The USB port on your computer is incompatable with the Eagle Tree hardware. I have 3 computers here a Compac, an Acer, and an old IBM thinkpad. The Compac will flash the OSD right into the garbage can every time. The Acer , about 50% 0f the time. The old IBM works perfect and has gotten my OSD/ E logger back on line 3-4 times.
Old Aug 22, 2009, 10:20 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
RCWingFlyer, sorry to hear about your issue. As Tom mentioned, it does sound like there may be a USB compatibility issue. What type of PC are you using? if you have access to a different PC, or a USB hub, that might be worth trying.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Aug 22, 2009, 11:54 PM
Joined Jun 2008
The led on the e-logger doesnt respond after the last fw update app 7.83 -> app 7.79...
The OSD pro main screen displaying firmware version number like a broken symbol (dotted square)... Finita la comedia?
Old Aug 23, 2009, 12:31 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
RCWingFlyer, if you disconnect everything from the eLogger, then connect the USB cable, does "Hardware, Firmware Control" indicate that hte eLogger is detected? if so, can you update the eLogger firmware?
Also, what type of PC are you using?
Regards,
Site Sponsor
Old Aug 23, 2009, 12:35 AM
Tom Para
Joined May 2003
The Performance is Ended
Bill will get it working for you...
Last edited by Tom in Cincy; Aug 23, 2009 at 12:44 AM. Reason: Bill Pa has it under control....
Old Aug 23, 2009, 01:00 AM
Joined Jun 2008
Yes, Bill, the HID device was appear in device list
But neither battery no USB cable cant light the LED on e-logger. When i am starting windows app, it's hang up and doesnt respond
I am using my old IBM Thinkpad R52, Intel Pentium M 1,75 2Gb RAM WXPSP2
Old Aug 23, 2009, 03:43 PM
SirAlex is offline
Find More Posts by SirAlex
SirAlex's Avatar
Joined Sep 2005
RCWingFlyer
I had the same error.
The problem was the USB connection. I was using Windows running on parallels on a Mac.
Now whit Win on bootcamp I have no more communication problems.
Try using a different Pc.
Now my problems:
How can I show the RSSI% on OSDpro?
Can I make the characters in the OSD bigger?
Can I move the graphical battery icon?
Alex
SirAlex is offline Find More Posts by SirAlex
Old Aug 24, 2009, 09:20 AM
npole is offline
Find More Posts by npole
Joined Apr 2009
Bill i've sent an email (it's about a request) via this forum.. but im not sure if the address you've used here it is correct, may you check please?
Thanks!
npole is offline Find More Posts by npole
Old Aug 24, 2009, 11:56 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
RCWingFlyer, is there a chance that you could try a different PC with your eLogger, to confirm that the problem is related to your PC?
All, we are anxious to resolve any and all USB compatibility issues. But, the problem we have is that we have not been able to repro any of the issues in-house. I suspect the issue is a combination of PC, installed software, BIOS revision level, chipset, and perhaps even slight variations among eLoggers. One thing we have thought about is borrowing a customer's problem PC, and the eLogger that is having the problem, so that we can debug the issue here. If there is someone in the US who is interested, let me know!
NPole, got your email and I'll be responding today.
SirAlex, we are releasing a sensor soon that will let you display RSSI from RX's (such as Thomas's) that provide an analog RSSI output.
There is presently not support for making the OSD Pro font bigger. We also don't have support for moving the battery icon. Are these two things features that others would like to see?
Regards,
Site Sponsor
Old Aug 24, 2009, 12:03 PM
Joined Jun 2008
Dear Bill,
it is possible that i am kill e-logger, if it doesnt respond with blinking light whis battery connected? Or HID device appear in My Computer will give me a chance?
BTW, OSD works when it's connected to the mulfunctioning e-logger, but stops at the welcome screen....
Old Aug 24, 2009, 12:11 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
Originally Posted by billpa
All, I hope that we will be able to release a "whitepaper" on connecting the FMA CPD4 head/system to the OSD-Pro this week. This will be an interim solution, but should work fine until something more substantial is done. Sorry for the long delay on this.
any idea when this will be released?
downeym is offline Find More Posts by downeym
Old Aug 24, 2009, 12:49 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Billpa,
Font not an issue, but it would be nice to move the battery..
On the CPD4, can't wait for that!
Great job as allways!
Dion
rcimports is offline Find More Posts by rcimports
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
