Old Sep 13, 2008, 04:21 PM
midlifez is offline
Find More Posts by midlifez
Joined Aug 2008
help! Blade 400 servo>RX connections
Went to hook up a RX and ran into a snag. While pulling a connection from the RX it popped out and brought the others with it, i.e. disconnected all but one of the wires to the RX.
I cannot locate anywhere a diagram that shows which cable goes to which pins on the AR6100e receiver.
Can anyone help?
Basically there are the following servos on my Blade 400
1. Servo on the RIGHT just behind the main drive shaft
2. Servo on the LEFT just behind the main drive shaft
3. Servo in the nose area which has two connecting rods going from it to the swash plate
4. Connector from the ESC
5. Tail servo (have this one figured out)
On the AR6100e there are the following inputs
AUX1
GEAR
RUDD (I have this one handled>TAIL SERVO)
ELEV
AILE
THRO
BATT
I understand reasonably well Rudder, Aileron, Elevator but that still leaves one left over and no matter what I do my tests (without the HC connected) are not successful.
midlifez is offline Find More Posts by midlifez
Old Sep 13, 2008, 04:43 PM
MrR is offline
MrR
Find More Posts by MrR
MrR
Joined Sep 2006
From left to right looking at the receiver from the connections on the back:
batt-open
thro-ESC
aile-Lower rear servo
elev-front servo
rudd-tail servo plugs into the gyro, gyro plug goes here.
gear-one yellow wire also from the gyro.
aux1-upper rear servo
Hope that helps you out
MrR is offline Find More Posts by MrR
Old Sep 13, 2008, 05:02 PM
JustinMoore12 is offline
Find More Posts by JustinMoore12
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
http://www.slyster.com/heli/
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Sep 13, 2008, 05:36 PM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
Yep... this is from the reciever section.. click the link... a great helpful photo
#14- Receiver
"Oops!" I fogot where to plug things in on rx !!!
http://www.helifreak.com/showpost.ph...91&postcount=7
Slyster is offline Find More Posts by Slyster
Old Jul 10, 2009, 12:48 AM
mattxr2i is offline
Find More Posts by mattxr2i
Sky Soldier
mattxr2i's Avatar
Vicenza, Italy
Joined Feb 2008
batt-open
thro-ESC
elev-front servo
Maybe a silly question but what is the "batt" connection on the receiver actually used for?
mattxr2i is offline Find More Posts by mattxr2i
Old Jul 10, 2009, 01:21 AM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
Bind plug
prop bender is offline Find More Posts by prop bender
Old Jul 10, 2009, 01:58 AM
mattxr2i is offline
Sky Soldier
mattxr2i's Avatar
Vicenza, Italy
Joined Feb 2008
Originally Posted by prop bender
Bind plug
Can it be used to operate anything though?
Old Jul 11, 2009, 02:25 AM
USA, CA, Red Bluff
Joined Dec 2007
No!. Other than to plug in a flightpack battery if you use the reciever in a plank( airplane) Nitro engine powered.
Discussion Blade 400 servo and swash settings help variableprollc Mini Helis 5 Nov 05, 2010 10:57 PM
Question Blade 400: servo noise? Jon Craig Mini Helis 11 Jun 19, 2008 10:39 PM
Discussion HELP blade 400 and 6102 waytoofast 3D Electric Heli Flying 0 Mar 16, 2008 04:24 PM
Discussion Blade 400 Servo's Turnell Mini Helis 4 Mar 05, 2008 02:36 PM
Discussion Blade 400 servo rev. switch Bing44 3D Electric Heli Flying 2 Feb 28, 2008 11:35 PM
