Old Sep 13, 2008, 07:08 AM
MGeo is offline
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
HBFP -- Arming LED goes green to red during flight
I'm learning to fly hover on a HBFP and so far so good, I can now hover long enough to get through most of an 800mah LiPo.
What I am now noticing is that toward the end of the pack the ESKY 3in1 arming LED goes from green to red during flight at higher throttle settings. If I reduce throttle it goes back to red.
Is this normal, and what does the red LED indicate?
MGeo
MGeo is offline Find More Posts by MGeo
Old Sep 13, 2008, 08:02 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I think it indicates your at full throttle.
BowerR64 is offline Find More Posts by BowerR64
Old Sep 13, 2008, 08:42 AM
MGeo is offline
MGeo's Avatar
New York
Joined Nov 2003
The tx throttle is at hover (~55%), so do you mean the tail motor is at full throttle? That does not seem right since it still responds to rudder inputs (the tail motor can still speed up or slow down based on my rudder command).
Old Sep 13, 2008, 06:18 PM
MGeo is offline
MGeo's Avatar
New York
Joined Nov 2003
Anyone?
Old Sep 13, 2008, 06:52 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
It indicates you are at the end of the pack..ie your voltage has hit the threshold for the red light to go on. As your battery gets older it will come on sooner and sooner.
Bill
poulsbobill is offline Find More Posts by poulsbobill
Old Sep 16, 2008, 12:11 PM
Blade_Killer is offline
Find More Posts by Blade_Killer
innocent victim
Blade_Killer's Avatar
Houston TX
Joined May 2007
it means your 4 in 1 is recieving the full power it needs, it will go red then as you reduce the throttle it goes back to green, it will do this no matter how charged the battery is, the battery charge has nothing to do with it. It's the 4 in 1 is getting all the power it will take at that given time. It's perfectly normal.
Blade_Killer is offline Find More Posts by Blade_Killer
Old Sep 16, 2008, 03:35 PM
Poulsbo, Wa
Joined Sep 2004
and thus as the battery gets weaker it will come on sooner in relationship to a given headspeed...ie voltage is lessening.
What I am now noticing is that toward the end of the pack the ESKY 3in1 arming LED goes from green red during flight at higher throttle settings. If I reduce throttle it goes back to red.
MGeo
You said it goes back to red or green as you reduce throttle? It should go back to green.
Bill
P.s. as posted by me to someone else same subject... http://www.rcgroups.com/forums/showp...4&postcount=91 Have fun!!
Old Sep 21, 2008, 05:34 AM
MGeo is offline
MGeo's Avatar
New York
Joined Nov 2003
Thanks for the help. As you mention, the LED goes back to green if I reduce throttle.
Question Blade CP: 4 in 1 red light on during flight Al P Micro Helis 14 Aug 13, 2008 07:58 AM
For Sale 3 LED light setup! One red, one green, and one white! $15 shipped! edge5foamy Aircraft - General - Miscellaneous (FS/W) 8 Feb 20, 2008 04:50 PM
Discussion BCX2 - 4-in-1 light goes from green to red chexone Coaxial Helicopters 8 May 15, 2007 12:53 AM
Bowling Green Fly-In During Toledo Show UniversalRC Electric Plane Talk 1 Apr 09, 2003 11:06 AM
Motor cutting out during flight dtanderson Electric Plane Talk 2 Aug 06, 2002 09:37 PM
