Old Mar 29, 2010, 09:11 PM
masam54's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Dec 2008
If those are tx on/off figures, I would take the widest range i.e 3.29/1.62
On my RP8D1 I have 2.11/0.77 and works fine
masam54 is offline Find More Posts by masam54
Old Mar 29, 2010, 09:24 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
ok thanks I'll give it a shot and see what happens. oh btw, I have a 10K resistor with a 5% tolerance. Actual resistance is 9.9K... think that will be ok? Or should I find a 1% resistor?
thanks
ash
ashdec87 is offline Find More Posts by ashdec87
Latest blog entry: SS FPV Maiden
Old Mar 29, 2010, 09:29 PM
masam54's Avatar
Joined Dec 2008
Shud be ok.
Old Mar 30, 2010, 01:26 AM
Romania, Dolj, Craiova
Joined Sep 2007
Is ok
Also, do a range check (with antenna collapsed) and see if the voltage variation is liniar between 3.29 and 1.62V, or there is a trigger behaviour, i.e. it jumps abruptly at a given signal level. Is useful to have this info to know how to react in flight.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Apr 03, 2010, 11:52 PM
asaloca's Avatar
Delray Beach
Joined Aug 2004
Hello,
Anybody can help me where is the RSSI for R3110DPS ??
tks
FRED
asaloca is offline Find More Posts by asaloca
Old Apr 04, 2010, 02:16 AM
Joined Sep 2007
Without posting pictures, not
Old Apr 06, 2010, 08:35 AM
asaloca's Avatar
Delray Beach
Joined Aug 2004
Sure Renato.
Lonnnng thread ,but saw the light at the end of the tunnel with your posts
Tks .
FRED
Old Apr 06, 2010, 08:39 AM
Joined Sep 2007
This is s two boards receiver, right ?
I am afraid the FM chip is one of the inner sides, hard to investigate...
I would probe the two groups of three pins that connects the two boards together, last picture, bottom side, left and right
Old Apr 06, 2010, 08:46 AM
asaloca's Avatar
Delray Beach
Joined Aug 2004
Originally Posted by ssassen View Post
For the R319DPS the RSSI pin can be found at the below solder pad, where the red arrow is pointing at. This will output a voltage between 0.7 and 2.2V, with 0.7V being the absence of any signal and 2.2V with the transmitter nearby (hence maximum RSSI value).
Cheers,
Sander.
Seems to bee the very same board!! Confirm ?
FRED
Old Apr 06, 2010, 08:51 AM
Joined Sep 2007
Can't swear they are identical, but... very close.
Anyway, probing that pad doesn't hurt at all !
Old Apr 06, 2010, 03:36 PM
asaloca's Avatar
Delray Beach
Joined Aug 2004
Tks Renato.
My knowlege at this issue is very poor ...how can I test if itīs the right spot ?
Tks
FRED
Old Apr 06, 2010, 03:56 PM
Joined Sep 2007
Measure the voltage between that pad and ground, should have a significant difference when Tx is on or off. Quoting Sander: "This will output a voltage between 0.7 and 2.2V, with 0.7V being the absence of any signal and 2.2V with the transmitter nearby "
Old Apr 07, 2010, 05:10 AM
jawa31's Avatar
south east england
Joined Feb 2009
bloomin heck took a while reading through all this :-)
but still nothing about the original reciever that was asked about.. Lol
I also need to find the rssi point on the futaba R146IP?????
Does any1 no this??
fly fpv so i have an osd and would be great to have the signal strength working..
jawa31 is offline Find More Posts by jawa31
Old Apr 07, 2010, 07:04 AM
Joined Sep 2007
If you ask this here, then you didn't read the whole thread.
At least #18 not !
Old Apr 07, 2010, 07:48 AM
jawa31's Avatar
south east england
Joined Feb 2009
arse!! been a bit blind have i!!!!
thought i'd start a new thread cause only need the info for my reciever..
the info i need in that old thread then??
woops, i'll read through it again.
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
