Old Jan 09, 2010, 04:08 PM
areis81 is offline
Find More Posts by areis81
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
hi... no help for hitec hfs-06mt of post #68,69? thanks....
areis81 is offline Find More Posts by areis81
Old Jan 09, 2010, 04:38 PM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
haha, just ask Renatoa one more time.
he's active in a lottt of treads
Remy is offline Find More Posts by Remy
Old Jan 10, 2010, 02:52 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Thank you Remy, will slowdown soon, I must build and fly more than watching forums.
@areis81, sorry, but from your post #70 I thought you are clear now.
31136 is one of the two well known universal chips, rssi is on pin 12.
Read #18 also, please.
@Ceccoz, can you check the levels on red circle pad? Even if circuits are different, there are chances that pin to be RSSI. I would like also have a picture of the other side of the receiver.
renatoa is offline Find More Posts by renatoa
Old Jan 10, 2010, 05:04 AM
Remy is offline
Netherlands
Joined Feb 2004
Here ya go.
Old Jan 10, 2010, 07:12 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
ah! from the numbers i thought they were different chips! i'm really sorry i didn't understand, my english must be improved! thanks a lot for your help and patience guys, you helped me a lot! thanks to all!!!
Old Jan 10, 2010, 07:15 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
Originally Posted by RENATOA View Post
For anyone asking for RSSI for unknown receivers:
- open it
- try to locate chips like 7761 or 31136, 99% of the FM receivers (35/40/72MHz) use such chip
- some pictures of the two chips below:
http://www.rcgroups.com/forums/attac...mentid=2535617
http://www.rcgroups.com/forums/attac...hmentid=770766
- RSSI is on pin 7 of 7761, or pin 12 of 31136
If the above fails, first search rcg archive using "rssi <your receiver>"
If fails again, try Google
Finally, ask here, but always post pictures !
darn, i read this post a dozen times thinking 'gosh my chip is different i must ask for help!' but i was only reading 7761 and not the second number.... i'm really sorry, i'll try to use more attention from now on... thanks again!
Old Jan 10, 2010, 07:50 AM
Remy is offline
Netherlands
Joined Feb 2004
haha Renatoa saved the day. Did it also many times for me.
Old Jan 10, 2010, 08:36 AM
h_bondok is offline
Find More Posts by h_bondok
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
Hi guys,
any one know where is the RSSI for R3110DPS futaba receiver.... thanks
h_bondok is offline Find More Posts by h_bondok
Old Jan 10, 2010, 11:18 AM
renatoa is offline
Joined Sep 2007
Originally Posted by h_bondok View Post
Hi guys,
Could be very close to R5114dps, but... as the picture says...
Old Jan 17, 2010, 04:52 PM
Ceccoz is offline
Find More Posts by Ceccoz
Ceccoz's Avatar
Italy, Emilia-Romagna, Modena
Joined Sep 2009
Hi Renatoa,
I have tested the levels on red circle pad. I think that is RSSI pin.
Levels are:
0.8 V Transmitter off
2.13 V Transmitter on
In attacchment you can find also a picture of the back side of receiver.
What do you think??
Francesco
Ceccoz is offline Find More Posts by Ceccoz
Old Jan 18, 2010, 12:32 AM
renatoa is offline
Joined Sep 2007
What can I say... congrats !
Another one ... receiver solved, what do you think
Old Jan 18, 2010, 11:57 AM
Ceccoz is offline
Ceccoz's Avatar
Joined Sep 2009
I think that I have only to thank you .
Do you know if there is a way to mod dsc port to pull out RSSI voltage?
Francesco
Old Jan 18, 2010, 12:54 PM
renatoa is offline
Joined Sep 2007
Only if you want to sacrifice DSC feature, because there is no pin not allocated.
Old Jan 18, 2010, 02:51 PM
Ceccoz is offline
Ceccoz's Avatar
Joined Sep 2009
yes, of course, how can I do it?
Old Jan 18, 2010, 03:50 PM
renatoa is offline
Joined Sep 2007
Cut the pin(s) of dsc plug and solder your RSSI and instead, how else ?
I would cut the ppm pin only (where comes white wire), and keep black and red (ground and power). Black/Ground is required anyway, to connect to the OSD ground.
Be sure how you insulate the red/power coming from receiver, to not touch something at OSD side.
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
