Old Nov 14, 2009, 04:50 PM
vpersiani is offline
Find More Posts by vpersiani
Creteil, France
Joined Nov 2003
R136hp rssi
So as you can see on attached pictures, TA7761 on one side so RSSI on pin7 and FP6302B on the other so RSSI also there (see some ealier posts).
Which side do you recommend to pickup the signal to feed ET OSD Pro?
(In either case I guess that a buffer will be needed).
Vincent
vpersiani is offline Find More Posts by vpersiani
Old Nov 14, 2009, 06:17 PM
MercadoNegro is offline
Find More Posts by MercadoNegro
Argentina, Capital Federal, Buenos Aires
Joined Oct 2008
Does anyone know how to obtain RSSI signal on a JR R2100 receiver?
Thanks!
Gustavo
MercadoNegro is offline Find More Posts by MercadoNegro
Old Nov 14, 2009, 09:43 PM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
For infos, the RSSI on XPS system is the pin #6 on the xbee pro module.
Take note that it's a PWM of 64uS period, when 24% is on you're at rx's sensibility.
You can add a 100kohm res. and a 10uf cap to filter it into 1-3.6V signal.
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Nov 15, 2009, 03:29 AM
mrleenagle is offline
Find More Posts by mrleenagle
fpv addict
mrleenagle's Avatar
Sydney, Australia
Joined Nov 2007
Anything on jr rx's spcm
mrleenagle is offline Find More Posts by mrleenagle
Old Nov 16, 2009, 04:12 AM
alanhsu is offline
Find More Posts by alanhsu
Joined Dec 2003
I found the RSSI pin for FMA co-pilot FS8 receiver.
It is on the 2292 IC on the back of the receiver.
Here's the datasheet
alanhsu is offline Find More Posts by alanhsu
Old Nov 17, 2009, 10:26 AM
SirAlex is offline
Find More Posts by SirAlex
SirAlex's Avatar
Joined Sep 2005
RSSI capture for Multiplex RX-12Synth DS IPD and Multiplex RX-9Synth DS IPD
The IC its Philips SA676 and RSSI its on pin 5.
Here is the data sheet http://www.datasheetcatalog.com/data.../7/SA676.shtml
Alex
SirAlex is offline Find More Posts by SirAlex
Old Nov 23, 2009, 10:57 PM
h_bondok is offline
Find More Posts by h_bondok
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
Hi guys,
any one know where is the RSSI for R3110DPS futaba receiver.... thanks
h_bondok is offline Find More Posts by h_bondok
Old Dec 25, 2009, 01:38 PM
workshop is offline
Find More Posts by workshop
Closed Account
Joined Nov 2004
Jr r2000 & r2100
I found the 31136 chip on the JR R2000 series of receivers...
It is sandwiched between two PCBs and unreachable...
Jeff
workshop is offline Find More Posts by workshop
Old Dec 25, 2009, 01:40 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Try to follow the track from pin7
renatoa is offline Find More Posts by renatoa
Old Dec 25, 2009, 01:43 PM
workshop is offline
Closed Account
Joined Nov 2004
It is a multi layered board and the bottom is a solid copper trace...
Desoldering the top board would be a chore for someone with my skills.
I'm going to look at the other JR ScanSelect SPCM receivers to see if I can find a single layer board.
Old Dec 26, 2009, 07:08 AM
Ludo91 is offline
Find More Posts by Ludo91
Joined Sep 2009
Hi,
does anyone knows where is the RSSI pin on a futaba fasst R6014?
tnks!
Ludo91 is offline Find More Posts by Ludo91
Old Dec 26, 2009, 10:59 AM
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
this folder may contain usefull info
http://www.webx.dk/rc/RX-measurements/
I took also RF measurements and DC supply rejection and IF filter width measurements
see the HTML file in the main folder,
you will also see alot of closeup pictures.
most receivers use the same radio chips, so that is actually what you need to google.
thomasscherrer is offline Find More Posts by thomasscherrer
Old Dec 26, 2009, 12:55 PM
workshop is offline
Closed Account
Joined Nov 2004
No JR on the list... I wonder why so many FPVers seem to choose other radios?...
Old Dec 26, 2009, 08:21 PM
workshop is offline
Closed Account
Joined Nov 2004
Jr r790
I found the chip! It was unmarked and hiding under a capacitor!
I love this seven channel scan select SPCM receiver and use it on all my >1mile machines. It is really too bad the pin is so inaccessible. I fished around on both side of the board looking for a better attachment point but, alas, I could not find one.
No Signal = .205V
Full Signal = .618V
Cool. Now I have to learn how to solder to that tiny pin!
Old Dec 27, 2009, 01:19 AM
renatoa is offline
Joined Sep 2007
The voltage swing is too small, imo, for a healthy RSSI indication.
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
