Old Oct 17, 2012, 06:31 PM
Joined Oct 2012
hello, what is the pin 7, or where it connects to receiver RSSI JR 649S?
enriquejosegomez is offline Find More Posts by enriquejosegomez
Old Oct 19, 2012, 09:20 PM
Daniel del Chaco
Joined Sep 2012
Originally Posted by masam54 View Post
In my old NER649S, there's a 7761 chip, I also managed to get rssi from my old 10ch JR rx.
Hello,
I do not understand that pin is welded, and that side?
Please!!!
Daniel
daniel sanguinet is offline Find More Posts by daniel sanguinet
Old Nov 13, 2012, 07:57 AM
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Originally Posted by typicalaimster View Post
And if you're looking for RSSI out on a R617FS it's Pin #28
Hi
Could someone please tell me what I need to do besides soldering a wire to the RSSI pin..... Please correct me
1-10K ohm resistor inline with the RSSI wire
2- Ground reference wire soldered to any ground in the RX board
Thanks a lot for your help
Much appreciated
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Nov 18, 2012, 12:48 AM
Romania, Dolj, Craiova
Joined Sep 2007
The resistor without a capacitor to the ground doesn't make much sense.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Nov 18, 2012, 11:50 AM
Joined Nov 2006
Sorry .. but I really don't know why I have to use a 10K ohm resistor inline with the RSSI wire , and a capacitor inline with the ground wire ... I'm trying to replicate what other people did without understanding the science behind it ... I have no electronic background at all .. so I apologize for the newbie/stupid questions ...
Thank you very much for bearing with me ...
Khaled
Old Nov 18, 2012, 12:23 PM
Joined Sep 2007
This structure is known as a low pass RC filter.
For RSSI the purpose is to average the receiver pulses into a less jumping voltage, easy to follow on the screen.
Old Nov 18, 2012, 01:39 PM
Joined Nov 2006
Thanks a lot .. for the info .. I really appreciate it
Khaled
Old Dec 08, 2012, 03:00 PM
United States, PA, Norristown
Joined May 2012
Originally Posted by Ludo91 View Post
Hi,
does anyone knows where is the RSSI pin on a futaba fasst R6014?
tnks!
Searching for this myself right now if anyone could fill me in, got the R6014HS 12 channel
Jengaleng is offline Find More Posts by Jengaleng
Old Dec 24, 2012, 03:05 PM
United States, CA, Loma Linda
Joined Oct 2012
I'm going to bump this up again about the Futaba R6208 SB. I was using a FrSky Sbus Rx but was getting cruddy range, so I switched back to the Futaba and I'm easily getting nearly twice the range and running into the limit of my FPV now. Much better, but it would be nice to have RSSI which is why I switched to begin with.
pelted is offline Find More Posts by pelted
Old Jan 16, 2013, 02:29 PM
Joined Jan 2013
Hello, I'd like to ask following - does Radiolink R7EH receiver contain RSSI or PWM signal pin? I'm attaching board photos. Thank you in advance for your answers
sobi78 is offline Find More Posts by sobi78
Old Jan 16, 2013, 03:14 PM
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
In picture #2 what is the number on the IC chip with all the leads in the middle (it's fuzzy in the picture)? Do an internet search on it--should have a diagram of the pin functions and a layout by pin. Use the index mark to find the correct pin.
For example here is a new Corona RP6D1 (without the jumper)
1fullbird is offline Find More Posts by 1fullbird
Old Jan 17, 2013, 03:38 PM
Joined Jan 2013
It looks that chip inside is Texas Instuments CC2500.
Datasheet link: http://www.ti.com/lit/ds/symlink/cc2500.pdf
But ...hmmm... there's written that RSSI is digital see 17.3 on page 34 - can it help me somehow?
Old Jan 17, 2013, 07:07 PM
1fullbird's Avatar
Joined Nov 2011
I looked at the pin data sheets on page 16 & 17 of the spec doc and I don't see a RSSI output pin.
Old Jan 20, 2013, 03:49 PM
Denmark, Central Denmark Region, Karup
Joined Aug 2012
Has anyone found out how to get acces to rssi pin (or where to solder the wire to) on walkera rx802 with devo8s. ? would be nice...
vartaz is offline Find More Posts by vartaz
Old Jan 23, 2013, 02:38 AM
Joined Sep 2007
CC2500 digital RSSI requires additional decoding hardware and software, is not a DIY solution without advanced electronic skills.
Has been done for Frsky receivers, but is not an universal solution.
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
