Old May 20, 2012, 03:09 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Does anyone know how to get RSSI from FRSKY D8R-II-PLUS Rx ?
http://www.frsky-rc.com/ShowProducts.asp?id=114
i3dm is offline Find More Posts by i3dm
Old May 28, 2012, 03:45 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Reflash it with a firmware that will be soon posted on their site.
Read more about D8R-XP receiver.
renatoa is offline Find More Posts by renatoa
Old May 28, 2012, 07:22 PM
JLT_GTI is online now
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Just confirm that the RSSI out mod of my Futaba R137F Rx works.. IkarusOSD detects it..
tought oddly.. when i measured it with a voltmetter it was 2.2V full and 0.7V no singal.. and when using the OSD self wizard to setup RSSI it detected like 2.2V full and 1.4 or so no signal... weird.
JLT_GTI is online now Find More Posts by JLT_GTI
Old May 29, 2012, 11:15 AM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Turnigy 9X receiver
Originally Posted by guy1a View Post
Any one had success with soldering the ultra micro small of the rssi pin of the a701* ... The turnigy 9x rx ??
Originally Posted by ulkar View Post
Interested on the turnigy 9x receiver as well, I've seen a few topics about it but never anyone getting it to work properly
Me too - the original posts by Bachkos never went anywhere - is there a way to make this work?
Jeff Watt is offline Find More Posts by Jeff Watt
Old May 30, 2012, 11:30 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Originally Posted by khaled_abobakr View Post
Hi ..
Does any one know where the RSSI pin on the Futaba R6208SB
http://www3.towerhobbies.com/cgi-bin...?&I=LXAVCR&P=V
I did search this forum .. but I didn't find it.
Thanks a lot for your help
Khaled
Any idea someone ?
sharonx is offline Find More Posts by sharonx
Old Jun 05, 2012, 07:15 PM
marcelog is offline
Find More Posts by marcelog
marcelog's Avatar
Australia, QLD, Brisbane
Joined Oct 2011
I would like to know too!
marcelog is offline Find More Posts by marcelog
Old Jun 08, 2012, 08:19 AM
jlezana is offline
Find More Posts by jlezana
jlezana's Avatar
Joined Jul 2009
Hello friends .. no one has found the RSSI pin for the receiver Futaba FP-R309DPS??
Thanks for your help ...
J.L
jlezana is offline Find More Posts by jlezana
Old Jun 08, 2012, 11:31 PM
paintz is offline
Find More Posts by paintz
Joined May 2012
J.L
Look at like Post 18 they say what chip to look for, bad thing is I think it is between the 2 boards... :/
paintz is offline Find More Posts by paintz
Reply With Quote  (Disabled)
Old Jun 11, 2012, 07:22 AM
jlezana is offline
jlezana's Avatar
Joined Jul 2009
Thanks I could not read everything and I occupy a translator to understand ..
I will try to open the receiver and unsolder the two plates and make a couple of pictures to see what I find ..
Greetings.
J.Lezana
Valdivia
Chile
Old Jun 11, 2012, 08:13 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
FYI I fixed the broken images in the original post.
BushmanLA is offline Find More Posts by BushmanLA
Old Jun 11, 2012, 10:35 AM
quadcopter007fpv is offline
Find More Posts by quadcopter007fpv
quadcopter007fpv's Avatar
United States, CA, Riverside
Joined Feb 2012
i have Futaba R617FS 2.4ghz FASST 7-Channel Receiver , i want to setup rssi from the led, i have done some testing and have come up with some weird results , i have a 100k resistor off of the +leg of the led , going to 4.7 uf cap across the ground after the resistor, when i test it with just volt meter i get 0.05 volts with full signal , and 2.95 volts when i turn off the transmitter, when i put my tx on low power and put it in microwave to sim low sig i get the voltage jumping from .42 to 1.92 to 2.95 with full signal loss , but when i do the same test with the osd min max rssi at .05 and 3v i put the volt meter in parallel with the rssi out and the max voltage with full signal loss was only 1.36 to .05 with full signal, when i unplug just the osd it goes up to 2.95 with full signal loss> i am confused as to why im getting different voltages could the osd be pulling all the power out of the cap or is the cap to big , im not great with electronics , i was wondering if some one could help , it was mentioned to me that an op amp is another way to go ?
Thanks to anyone that can help
quadcopter007fpv is offline Find More Posts by quadcopter007fpv
Old Jun 22, 2012, 05:36 AM
jbsmith78 is offline
Find More Posts by jbsmith78
Joined Mar 2012
Good morning, I was looking for this pinout info for a Futaba R127DF - any help would be awesome!! Thank you!!
jbsmith78 is offline Find More Posts by jbsmith78
Old Jun 23, 2012, 01:09 PM
Joined Mar 2012
Can anyone point me in the right direction for this?? Please, thank you!!
Old Jun 23, 2012, 03:58 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Could this be the right direction?
http://mysite.verizon.net/res7yvp2/w4dh22/id2.html
boopidoo is offline Find More Posts by boopidoo
Old Jun 23, 2012, 04:23 PM
Joined Mar 2012
Like a laser Boopidoo!! Thank you!!
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
