Old Mar 29, 2012, 06:17 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Can some please validate this finding for me please? This appears to be the RSSI Pin in the FlySky 6 channel RX.
Here is the Datasheet for the A7105 Chip.
Edited: It appears to me, they are sending the output directly to ground via the resistor. So what I MAY need to do is cut the trace and use a RSSI Buffer
Edited, the named Resistor is a CAP, sorry.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Apr 02, 2012, 08:48 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Richard this will be of interest to you :
http://www.rcgroups.com/forums/showt...1589154&page=2
msev is offline Find More Posts by msev
Old Apr 02, 2012, 09:09 AM
Joined Aug 2009
Awe!! Thank you.
Old Apr 02, 2012, 09:12 AM
msev is offline
Joined Sep 2010
No problem! I sent you a pm Richard!
Old Apr 03, 2012, 06:36 AM
Lennartvm is offline
Find More Posts by Lennartvm
Joined Dec 2010
Originally Posted by sharonx View Post
I have orangeRX and RSSI out (self soldiered) to RVOSD. at which value (%) I should excpect fail-safe ? 0% ? 30% ? Thanks.
can you please send me some pics that would be awesome
Lennartvm is offline Find More Posts by Lennartvm
Old Apr 03, 2012, 07:03 AM
Joined Dec 2010
what I was thinking was can't I just tap the pins of my OrangeRx spektrum sattelite port? Is that possible Please respond!
Old Apr 03, 2012, 07:19 AM
ApoC is offline
Find More Posts by ApoC
Germany, SA, MD
Joined Sep 2011
Does anyone know the RSSI Pin for the Graupner GR-16 HOTT Reciever?
ApoC is offline Find More Posts by ApoC
Old Apr 10, 2012, 05:01 PM
vichito is offline
Find More Posts by vichito
vichito's Avatar
Caracas,Venezuela
Joined Jan 2004
RSSI measurements R149DP
Hello.
I have trouble with the measurements in the RSSI wire R149DP
Tx on 0.20V
Tx off 0.29V
I have taken the measure in the rssi wire, and then verified directly of the pcb in both gives me the same values.
I hope you can understand my poor english.
Thank you
vichito is offline Find More Posts by vichito
Old Apr 18, 2012, 04:49 PM
compa71 is offline
Find More Posts by compa71
I try to Fly
compa71's Avatar
Italia, Emilia Romagna, Reggio nell'Emilia
Joined Dec 2011
is it the same for OrangeRx R910 Spektrum DSM2 9Ch 2.4Ghz TwinPort Rx?
many thanks for attention
compa71 is offline Find More Posts by compa71
Old Apr 19, 2012, 07:43 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Originally Posted by khaled_abobakr View Post
Hi ..
Does any one know where the RSSI pin on the Futaba R6208SB
http://www3.towerhobbies.com/cgi-bin...?&I=LXAVCR&P=V
I did search this forum .. but I didn't find it.
Thanks a lot for your help
Khaled
I too would like to know that
sharonx is offline Find More Posts by sharonx
Old Apr 20, 2012, 01:25 AM
galaxy1 is offline
Find More Posts by galaxy1
galaxy1's Avatar
Italy
Joined Oct 2005
RX R149DP differences between old and new
I know that there are differences between the old version and new version of the RX R149DP.
I would like to know exactly if if the new version has better receiving and sensitivity.
galaxy1 is offline Find More Posts by galaxy1
Old Apr 26, 2012, 11:16 PM
AaronHartwell is offline
Find More Posts by AaronHartwell
United States, WA, Duvall
Joined Mar 2012
I'm getting 1.2v to .3v with transmitter on and off on a Futaba FP-R148DF using my multimeter. It seems like most people get 2.2v on the top end, not 1.2v. Does that indicate that I did something wrong?
AaronHartwell is offline Find More Posts by AaronHartwell
Old Apr 27, 2012, 03:50 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Any one had success with soldering the ultra micro small of the rssi pin of the a701* ... The turnigy 9x rx ??
guy1a is offline Find More Posts by guy1a
Old Apr 27, 2012, 05:01 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
Interested on the turnigy 9x receiver as well, I've seen a few topics about it but never anyone getting it to work properly
ulkar is offline Find More Posts by ulkar
Old Apr 27, 2012, 03:55 PM
delcut03 is offline
Find More Posts by delcut03
Joined Jun 2006
got 1.2/1000 lawmate.
the covers are off.
vrx on table w/channel switches at left corner, pins facing me w/two blue "tictac" looking components in right corner, and ant. on my right side.
from left to right.
2 pins positioned horizontally(pointing in my direction), not connected to nothing...
3 pairs of soldered pins...
2 pins positioned vertically, not connected to anything...
and lastly 3 pairs of soldered pins.
2 blue "tictac" looking pieces are in the corner.
how are these pins numbered, and does anyone know which pins do i solder my rssi wires to.
much thnx from fpv newb.
looked through out thread,and didnt come across any one with 1.2/1000 lawmate, installing rssi.
thnx in advance.
delcut03 is offline Find More Posts by delcut03
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
