Old Jan 29, 2012, 05:14 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Hi ..
Does any one know where the RSSI pin on the Futaba R6208SB
http://www3.towerhobbies.com/cgi-bin...?&I=LXAVCR&P=V
I did search this forum .. but I didn't find it.
Thanks a lot for your help
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Feb 05, 2012, 05:21 PM
mrdakota is offline
Find More Posts by mrdakota
mrdakota's Avatar
United States, WI, Kenosha
Joined Nov 2004
NER-549 JR 9ch RSSI pin
Here is mine,
Description:
mrdakota is offline Find More Posts by mrdakota
Old Feb 06, 2012, 11:59 AM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Any idea where we can get the RSSI out of a Futaba R137F?
JLT_GTI is offline Find More Posts by JLT_GTI
Old Feb 06, 2012, 12:12 PM
bamabaxter is offline
Find More Posts by bamabaxter
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
need a picture of the inside
top and bottom of the board
bamabaxter is offline Find More Posts by bamabaxter
Old Feb 07, 2012, 02:29 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
You can see if the inside looks like the 136 http://www.rcgroups.com/forums/showp...0&postcount=95
I have modified my 136 to 7ch by just adding one resistor and capacitor. So i guess the pcb are the same.
Megafluffy is offline Find More Posts by Megafluffy
Old Feb 07, 2012, 02:34 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Yes... i just did the photos of the 137 and the board seems the same as the 136.. so i guess same pins? And its just solder 2 wires to those two? need to solder resistances or capacitors between like in the Coronas?
Old Feb 08, 2012, 01:30 AM
Joined Feb 2009
No, one wire. You see both pads is connected by a track on the pcb, you can choose which pad you solder to.
No need for resistor or capacitor if you connect it to a high impedance input. I you are connecting it to a input like the eLogger temp1 for rssi on the osdpro, you need a buffer.
Old Feb 08, 2012, 02:38 AM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
thanks
I would be connecting it to Ikarus OSD
Old Feb 26, 2012, 03:01 PM
fpvman is offline
Find More Posts by fpvman
beginner
Norway, Oppland, Raufoss
Joined Feb 2012
[QUOTE=bakchos;16409800]Finaly got this thing done, i had to build a dimmer for my soldering iron to get it cooler.
I question tho, when the Transmitter is off, i have 0.87 Volt, when on at 100 % i get 1.07 Volt, and when the transmitter is in the microwave i get 1.25 Volt.
So it looks like it get higher when strenght is weak, but gets lower when turned off, is that common ?
Did you figure it out? i get 1.02 when Tx is 1m from Rx and 0.8 when off.
I get so confused seeing people writing that the Rssi increase when poorer signal, and decrease when better. I thought is was the more volt the better your signal was??
fpvman is offline Find More Posts by fpvman
Old Mar 14, 2012, 01:46 PM
arismad is offline
Find More Posts by arismad
Joined Mar 2012
Nice
arismad is offline Find More Posts by arismad
Old Mar 17, 2012, 11:07 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
Has anyone pulled out the rssi on a Futaba r309dps? is it the same as a r319dps?
paintz2007 is offline Find More Posts by paintz2007
Old Mar 22, 2012, 12:35 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Anyone know how i can display RSSI on my Osd Pro with a FrSky D8R-II plus or D8R-II?
Cheers,
Alan.
Teamsherman is offline Find More Posts by Teamsherman
Old Mar 22, 2012, 01:14 PM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
Cheers,
Alan.
You can buy (or make) one of these.
http://www.ebay.com/sch/i.html?_trks...+rssi&_sacat=0
http://www.fpvuk.org/forum/index.php...db1fbf1d575528
g00bd0g is offline Find More Posts by g00bd0g
Old Mar 26, 2012, 03:17 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
Originally Posted by g00bd0g View Post
Wouldn't this also work?
Take the Tx port and ground from the side of the D8R-II/PLUS, and solder to dpcav.com's buffer board?
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old Mar 29, 2012, 03:43 PM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
Originally Posted by caall99 View Post
Bumping this. I assume there are a lot of people interested, but not forward enough to ask for proper guidance.
Thanks.
I found solution for you, just get new Tx and Rx with build in RSSI. LOL.
man1024 is offline Find More Posts by man1024
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
