Old Dec 04, 2011, 07:00 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
i put a 170k ohm set of resistors in series with a capacitor(47uF) and it seems to be working. getting nice slow readings on the output. takes 1-2 seconds to change .01v(i need 10uF... 47uF is too slow)
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Dec 04, 2011, 08:47 AM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
Originally Posted by chatch15117 View Post
http://static.rcgroups.net/forums/at...g?d=1242909232
you can just use the capacitor on the board. trace the 7th pin to some capacitor and tap it
looks like your pin isn't even being used... unless there's more from a different angle
Guys I have R128DF which has the same chip as this - Can I take it that this also will pipe out RSSI?
I'll upload a pic if you need.
flylite is offline Find More Posts by flylite
Old Dec 04, 2011, 03:25 PM
Joined Apr 2011
yes the second page of the thread says any 7761f chip will work on the 7th pin
Originally Posted by RENATOA View Post
For anyone asking for RSSI for unknown receivers:
- open it
- try to locate chips like 7761 or 31136, 99% of the FM receivers (35/40/72MHz) use such chip
- some pictures of the two chips below:
http://www.rcgroups.com/forums/attac...mentid=2535617
http://www.rcgroups.com/forums/attac...hmentid=770766
- RSSI is on pin 7 of 7761, or pin 12 of 31136
If the above fails, first search rcg archive using "rssi <your receiver>"
If fails again, try Google
Finally, ask here, but always post pictures !
Old Dec 05, 2011, 02:03 AM
Joined Apr 2011
my range is very small... 0.23v to 0.25v. maybe i need more than 170k ohms?
Old Dec 09, 2011, 01:59 PM
bamabaxter is offline
Find More Posts by bamabaxter
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
Found an easier and still reliable tap point for RSSI on the newer Corona RP8D1. Here is a picture. Make sure that a voltage follower or a 10K resistor is used at the minimum. I get ~1.7V full strength and ~0.8V weakest. Hope this helps. Remzibi's way works well, but this is just a little easier.
bamabaxter is offline Find More Posts by bamabaxter
Old Dec 09, 2011, 04:57 PM
999vertigo is offline
Find More Posts by 999vertigo
Closed Account
Joined Aug 2011
deleted
999vertigo is offline Find More Posts by 999vertigo
Old Jan 13, 2012, 06:07 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
Has anyone actually successfully gotten the turnigy 9x receiver to output a useful rssi value and used it with an osd??? Bakchos never actually got it working.
caall99 is offline Find More Posts by caall99
Old Jan 18, 2012, 10:16 AM
pika28 is offline
Find More Posts by pika28
France, Centre, Chartres
Joined Jan 2012
Originally Posted by Freedom35 View Post
I found this image at a Russian R/C forum (here: http://forum.rcdesign.ru/f90/thread1...ml#post1803437)
Attachment 3205801
And I gave it a try. The pin selection is a header between the two boards, so I used the other side for convienence sake. I read 560 mV max and 145 mV min. I hope RVOSD can calibrate to such a small swing.
Attachment 3205802 Attachment 3205803 Attachment 3205804 Attachment 3205805 Attachment 3205806 Attachment 3205808 Attachment 3205809 Attachment 3205810
Cheers.
Jeff
Hello,
First, I apologize for the bad translation. I do not speak English and I communicate with Google translation.
I just made adding the RSSI Pin. I did the test with a multimeter and with the OSD Remzibi. The values ​​of 0% and 100% vary hugely.
0% = 12mV to 27mV
100% = 520mV to 565mV
Have you noticed the same phenomenon?
In the photo of the Russian site, the second is interresting. If the translation is correct, it is the red LED. The output shows the packet loss. Can we also add the signal to the OSD remzibi?
Thank you for the tutorial.
Pika28
pika28 is offline Find More Posts by pika28
Old Jan 18, 2012, 12:30 PM
caall99 is offline
Joined Jun 2011
Bumping this. I assume there are a lot of people interested, but not forward enough to ask for proper guidance.
Thanks.
Old Jan 18, 2012, 12:56 PM
msev is online now
Find More Posts by msev
Joined Sep 2010
Id like to hear exactly how to make that rssi buffer, exactly which components to use...
msev is online now Find More Posts by msev
Old Jan 18, 2012, 01:35 PM
bamabaxter's Avatar
Joined Apr 2010
http://www.rcgroups.com/forums/showp...2&postcount=39
Old Jan 18, 2012, 05:10 PM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Originally Posted by bamabaxter View Post
Hi all.
I am puzzled as well because after doing lots of research I was not able to find a post including a straight forward working solution for displaying the Turnigy 9X RSSI with ET OSD pro, since both of these products are quite common.
I did add a RSSI out pin on my rx by connecting the RSSI pin of the TGY 9X rx according to Bakchos' post. The results were not as expected, since the RSSI value displayed was fluctuating way too much (about 100% to 40% with the tx sitting next to the rx)
Then, I did built the RSSI buffer using the LM358 according to BlueAngel2000's post, but that did not improved the situation, since the same fluctuations were evident.
Time for a disclaimer here: I am not very familiar with the theory or practice of electronics. I am slowly building my knowledge on the subject and what I usually do up to now is trial and error (read:magic smoke). My comments below could well be totally wrong - the input from electronically educated people is desired and welcomed.
Then, I did built a PC oscilloscope and checked the RSSI output of the LM358. The output puzzled me even more, but I do not have the background to explain it: The LM358 outputs some form of pulse waveform voltage, and not a constant voltage (always tx sitting next to the rx). It seems to me that the RSSI value that the OSD displays is the momentary volt value at the time of sampling, which could be at the top of the pulse, at the bottom of the pulse, or anywhere in between. Maybe some form of R-C circuit could be used to smooth out this pulse, but this just an uneducated guess on my part. Does RSSI outputs digital signal, but the OSD expects analogue signal?
To complicate things even more, and confuse my uninformed self, the amplitude of the volt output pulses that is displayed in the PC oscilloscope, is great the moment I connect the LM358 to the oscilloscope probe, but it constantly decays with time, and after 3-4 sec the oscilloscope display shows effectively a flat line, until I disconnect and reconnect again when this decaying pulse is again shown. I suspect that this behaviour has to do more with how the pc oscilloscope works than whith what the TGY9X rc RSSI pin really outputs.
Then, there is the red LED solution that could be a better approach, but I have not tried it yet. I am aware of the RCexplorer tutorial on how to do it on a FASST rx, and the relevant thread by reely340. I suppose it could be done in a similar way with the TGY 9X (please advise).
Please show understanding if the above post is not very clear the first time you read it, I am writing in a language that is not my mother language, and I am writing about electronics, that I do not understand well.
However, it would be GREAT if this post makes knowledgeable members (and there are a few) to cooperate in order to come up to a working solution for TGY9X RSSI with ET OSD pro. I bet that there will be many, many people that will be grateful for that (myself included)!
Best regards,
Stavros
sfakias is offline Find More Posts by sfakias
Old Jan 18, 2012, 10:29 PM
rotaryboots is offline
Find More Posts by rotaryboots
United States, MT, Columbia Falls
Joined Jun 2011
Just did the rssi mod to my FS-R8B. Let me just say, wow thats small. It's been a while since I've soldered something this small. Got it all done though and it looks great.
With the transmitter off I get .8 volts, with it on and the tx right next to the rx I get 1.050volts avg. The number then goes up the further away I place the tx. Haven't tried the microwave trick, but when I do I'll post the numbers.
With this mod I'll be able to hold off on the FRSky telemetry setup for my 9X for a little while. In a week I'll be able to plug this into my OSD and see what it does.
rotaryboots is offline Find More Posts by rotaryboots
Old Jan 19, 2012, 01:12 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
With pulsed rssi signal you need to make a low pass filter.
You can increase value of both to increase filtering.
If you are not using a buffer, I would recommend a high R value ( >100kohm)
Megafluffy is offline Find More Posts by Megafluffy
Old Jan 19, 2012, 05:07 AM
pika28 is offline
Joined Jan 2012
Hello,
Who can tell me why my RSSI value varies from 0% to 17% when the radio (transmitter) is off?
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
