Old Oct 10, 2011, 07:19 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Which of them, they are many ?
For Futaba FASST compatible, see my post some pages ago, about Frsky receiver.
renatoa is offline Find More Posts by renatoa
Old Oct 28, 2011, 01:32 PM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Hi there
any one know by any chance the RSSI pin for this futaba clone ?
it is FRSKY TFR6
thanks
guy1a is offline Find More Posts by guy1a
Old Oct 29, 2011, 04:43 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
Originally Posted by guy1a View Post
Hi there
it is FRSKY TFR6
thanks
Hi,
Yoy have to look at the other side for the RSSI signal. And you will probably find the seme IC that is on the 8ch version. so see here: http://www.rcgroups.com/forums/showp...&postcount=235
But did not use the RSSI signal on my 8ch clone, because if you fly in a noisy environment, it could give you falsely high rssi voltage. Instead I used the signal to the green led, and put a low pass filter on it. This signal will indicate lost packages, so it will tell you the quality of received signal.
Megafluffy is offline Find More Posts by Megafluffy
Old Oct 30, 2011, 03:46 PM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
thank you, Megafluffy
i will soon check it out.
Old Oct 31, 2011, 08:05 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
I have the FRSKY
TFR8S and the (post 235) component on mine is
2724DH
0322VJ is it the same ?,
anyone got the information on my old Futaba PCM 1024 FP-R139GP,,
pretty please,,,,
paulinfrance is offline Find More Posts by paulinfrance
Old Oct 31, 2011, 01:31 PM
Joined Feb 2009
Originally Posted by paulinfrance View Post
I have the FRSKY
2724DH
pretty please,,,,
If you want us to help you find the rssi signal, you have to provide us with close up pictures of both sides of the receiver pcb. (No, you cant use your phone to take the pictures, we must be able to read all the info on the IC's)
Old Nov 01, 2011, 07:23 AM
Joined Aug 2011
The only problem is i can't find anywhere on this site to import my images, and no album !.
Old Nov 01, 2011, 10:17 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
Under submit reply
click Manage Attachments
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Nov 02, 2011, 01:27 AM
Joined Aug 2011
Great thanks here are the pictures of my FRSKY TFR8S,
Old Nov 02, 2011, 02:34 AM
renatoa is offline
Joined Sep 2007
Yes, it's the same. Second picture.
Old Nov 02, 2011, 05:20 AM
Joined Aug 2011
Thanks, i will have a go this afternoon,,,,,,,,,,,
Old Nov 05, 2011, 02:13 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Please help me!!! I have two Dynam 2.4GHz receivers.
Pictures/info here: http://www.rcgroups.com/forums/showthread.php?t=1534176
Thanks!
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 06, 2011, 04:17 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
I have orangeRX and RSSI out (self soldiered) to RVOSD. at which value (%) I should excpect fail-safe ? 0% ? 30% ? Thanks.
sharonx is offline Find More Posts by sharonx
Old Nov 06, 2011, 04:21 PM
Joined Apr 2011
I'd have 75% loss set for RTH but you'll get glitchy at around 60% packet loss. For safety if you don't want RTH needed keep it under 50% packet loss. The loss increases sharply. It'll go from 60% loss to 80-90% loss in a few hundred meters.
sharonx is offline
sharonx's Avatar
Originally Posted by Freedom35 View Post
I found this image at a Russian R/C forum (here: http://forum.rcdesign.ru/f90/thread1...ml#post1803437)
Attachment 3205801
And I gave it a try. The pin selection is a header between the two boards, so I used the other side for convienence sake. I read 560 mV max and 145 mV min. I hope RVOSD can calibrate to such a small swing.
Attachment 3205802 Attachment 3205803 Attachment 3205804 Attachment 3205805 Attachment 3205806 Attachment 3205808 Attachment 3205809 Attachment 3205810
Cheers.
Jeff
Well ? did the RVOSD gave good reading ? when do you get failsafe ?
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
