Old Feb 05, 2011, 12:00 PM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
I ordered the Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)with the
Turnigy 9X8C-V2 8-channel receiver
does this have a RSSi pin
Any help would be appreciated
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Feb 09, 2011, 04:24 PM
bradleyK is offline
Find More Posts by bradleyK
Joined Jun 2010
http://www.rcgroups.com/forums/showt...6#post16192108
i believe this is the mod
bradleyK is offline Find More Posts by bradleyK
Old Feb 24, 2011, 10:09 AM
kd4gfy is offline
Find More Posts by kd4gfy
kd4gfy's Avatar
United States, FL, Port Orange
Joined Sep 2001
FMA FS8 Copilot receiver RSSI out
Tried several email to service at FMA with no reply on the location of RSSI
output on their receiver included with this unit. Anyone got any info on this?
kd4gfy is offline Find More Posts by kd4gfy
Old Mar 23, 2011, 06:42 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Originally Posted by RENATOA View Post
This receiver is using the ML2724DH transceiver, featuring analog RSSI on pin 28.
The RSSI output is buffered, and voltage swing is between 75mv (no signal) - and clipped to 1.9V at –15dBm.
The pin is the not connected one from the picture.
hi, just got my new OSD today .. i have this RX and i have not much understanding ...
what does it mean that the output is buffered ? do i have to do something about it ?
can i just iron a wire from this pin to the coresponding pin in the osd ? sould i do anything else other that that ? is there a (-) rnd wire too ?
thank you !
update:
i did it .. but i get reading of 0.3 ~ 0.6 on my OSD .. is it normal ?
Guy
guy1a is offline Find More Posts by guy1a
Old Mar 28, 2011, 05:09 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The - wire is ground, I thought is obvious.
Buffered means you can connect it directly to OSD, and it's a good thing.
No, it's not normal, if you mean 0.3 ~ 0.6 are Volts. Should be a broader range, as in the picture. Does your OSD provide any calibration for RSSI ?
renatoa is online now Find More Posts by renatoa
Old Apr 03, 2011, 09:31 AM
korayarok is offline
Find More Posts by korayarok
korayarok's Avatar
Turkey, Ankara Province, Ankara
Joined Dec 2007
Hi;
Is there anyone who knows the RSSI pin of the Airtronics-Sanwa 92824 8ch 2.4 Ghz receiver? I checked the internet and there is not an information about this. There is only one web site. It says that the LED blinks while the distance between TX and RX increases. When the distance increases, the time between blinks increases. I am thinking of measuring the intervals between the blinks by using a microcontroller and making an estimation for the signal strength. The distance will be measured by using GPS coordinates and I will try to derive a function for the interval time vs distance. Is it a reliable way for RSSI?
The photos of the receiver were also attached. Maybe there is RSSI pin somewhere on the board.
korayarok is offline Find More Posts by korayarok
Old Apr 06, 2011, 01:57 PM
ziomatrixacs is offline
Find More Posts by ziomatrixacs
Registered Abuser
ziomatrixacs's Avatar
Joined Oct 2006
Originally Posted by korayarok View Post
Hi;
I don't think most 2.4ghz RX's have rssi. But you could try to make and RC filter to slow charge a capacitor which would give you different voltages depending on the duration of the LED pulse. IE, an analog RSSI.
ziomatrixacs is offline Find More Posts by ziomatrixacs
Old May 20, 2011, 05:45 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
So it will be the same with ->
http://www.hobbyking.com/hobbyking/s...dproduct=12339
Originally Posted by bradleyK View Post
msev is offline Find More Posts by msev
Old Jun 03, 2011, 01:53 AM
hanafeearis is offline
Find More Posts by hanafeearis
Malaysia, Selangor, Seri Kembangan
Joined Mar 2010
need diagram for R149DP RSSI
allo guys...
i'm new in this field... i already read some info for the RSSI but i'm still blind how to connect all this wiring.. could some one post the complete diagram for this rssi into osd
hanafeearis is offline Find More Posts by hanafeearis
Old Jun 03, 2011, 07:09 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
It different for every receiver and osd. Basically you need to connect a wire from the rssi pin on the receiver to the rssi input pin on the osd. Some need an rssi buffer and some do not. Your best bet is to search for posts containing your receiver model and "rssi", then read the manual or search the thread for your osd.
techspy is offline Find More Posts by techspy
Old Jul 07, 2011, 05:54 AM
nese is offline
Find More Posts by nese
nese's Avatar
Joined Nov 2010
RSSI pin for Walkera RX-2801pro?
Originally Posted by wiesiek_kr View Post
hello.
This is my first post.
Did some one knew where is RSSI pin?
RX: walkera WX-RX 2801 Pro
Chip: ATMEGA88
I'm searching around for this as well because my electronics is zilch .
Has anyone found the RSSI pin for the RX-2801pro?
Do all receivers have this signal?
How did you guys with other receivers determine the right pin?
Any help on how to determine this is much appreciated . Please someone?
nese is offline Find More Posts by nese
Old Jul 29, 2011, 06:19 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Does anyone know how to grab RSSI of the FRSKy "Orange Rx" FASST compatible Rx ?
i3dm is offline Find More Posts by i3dm
Old Jul 31, 2011, 10:45 AM
Zagadka is offline
Find More Posts by Zagadka
Liverpool, UK
Joined Aug 2004
i3dm, I searched and missed this too - probably because I was looking for 'orange', but check Renatoa's post 235
Just soldering mine up at the moment.
Kev
Zagadka is offline Find More Posts by Zagadka
Old Aug 09, 2011, 03:24 PM
LUIS LOPEZ is offline
Find More Posts by LUIS LOPEZ
hi, who know where is the rssi for R3110 DPS PCM 1024 Futaba receiver?. thanks
LUIS LOPEZ is offline Find More Posts by LUIS LOPEZ
Old Oct 06, 2011, 06:12 PM
gandal is offline
Find More Posts by gandal
FPV NooB (crashing since 1985)
gandal's Avatar
Canada, BC, Kamloops
Joined May 2011
RSSI pin on Orange RX
anyone have a pic?
or know a link to one?
gandal is offline Find More Posts by gandal
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
