[QUOTE=dragant;16616860]It helps a lot. Thanks
Does it works for you?Where do you connect this on the Remzibi board? One more question for you (please) ![]() I have 6ch Flysky receiver for my FPV plane and would like to have rssi on my osd screen. This Rx have same A7105 chip and I see where you soldered one wire, but where should I solder second whire on my board? [QUOTE] It was connected to the ADC2 pad on Osd, For the wires, one is connected to the RSSI pin of the chip, and the other is a ground. |
He every one i use this module
http://www.bevrc.com/bev-24g-long-ra...s-rx-p-85.html I must connect + in1 or in2 ? Thank you |
I need help.
I was testing the IC pins of my Hitec RCD9600 to look for the RSSI pin. I found three pins which vary when the TX is switched on and off. Pin 1 -> 0.69V to 1.3V Pin 2 -> 0.18V Pin 3 -> 0.3V Pin 4 -> 0.19V Pin 5 -> 0.19V Pin 6 -> 0.4V Pin 7 -> 0.16V to 0.85V Pin 8 -> 0V Pin 9 -> 0.68V to 1.3V Pin 10 -> 0.24V Pin 11 -> 0.18V Pin 12 -> 0.24V Pin 13 -> 0.31V Pin 14 -> 0.4V Pin 15 -> 0.24V Pin 16 -> 3.59V So I chose pin 7 as the RSSI (Dunno if that's correct) Then I made the soldering connections. RSSI is read by RMILEC $10 OSD. When I connect the power to the RX, the ESC keeps beeping. I found the culprit is the RSSI signal cable. When I disconnect the cable the ESC boots up fine. I thought the RSSI needs an impedance, so I added 1000 ohm resistor in series. Seems like its not enough or I'm doing something wrong. Marking on the chip is IW4015BD 0427 OK I found the datasheet, but it doesn't say which pin is RSSI. http://www.digchip.com/datasheets/pa...4015BD-pdf.php |
Romania, Dolj, Craiova
Joined Sep 2007
4015 is the channels decoder (shift register), not the needed chip.
My guess is that what you want is on the vertical board, 3rd picture. See other Hitec receivers in this thread, all are using same chip. |
Latest blog entry: JRSky - birth of a dream radio
Joined Sep 2007
FrSky Futaba FASST compatible
This receiver is using the ML2724DH transceiver, featuring analog RSSI on pin 28.
The RSSI output is buffered, and voltage swing is between 75mv (no signal) - and clipped to 1.9V at –15dBm. The pin is the not connected one from the picture. |
It must be the other chip. Its hard to get at. |
TA 7761 So the RSSI is the "signal level" pin 7? |
| Thread Tools | |
| For Sale usb cable for futaba/hitec pin (round 6 pins) | jaas75 | Aircraft - General - Miscellaneous (FS/W) | 0 | Sep 05, 2008 12:34 AM |
| Pots for Futaba conquest transmitter | hcastell | Electric Plane Talk | 2 | Sep 12, 2001 08:14 AM |
| Make your own DIN plug for Futaba TX! | pullin-gs | Electric Plane Talk | 0 | Sep 06, 2001 08:05 PM |
| WTB: Hitec 555 rx for Futaba ( | Slope Nut | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 28, 2001 08:54 PM |
| Programming manual for Futaba 7UAF | gwh | Electric Plane Talk | 3 | May 31, 2001 12:43 AM |
