Found also Datasheet: http://mdfly.com/Download/Wireless/A7105datasheet.pdf |
Corona RP8D1
Hi all,
Here is some information conserning the RSSI pin of the Corona RP8D1 This is is the 8 cannel 9 pin new version of the Synthesized Dual Conversion Receiver 8Ch, in my case 35 mHz Hobby King sells it for 16$ Corona RP8D1 Hobby K link: http://www.hobbycity.com/hobbyking/s...idProduct=6441 The chip used on a lot of Corona receivers is the Phillips SA616 The RSSI pin is the 5 leg on the chip, see pdf data sheet and photo’s. Pin 9 looks to be connected with pin 5. But please correct me if I'm wrong. I have to try to solder a wire to the leg 5. I don't know if I can do it, any advice? Hope this info can help you all. see you, frans |
| Thread Tools | |
| For Sale usb cable for futaba/hitec pin (round 6 pins) | jaas75 | Aircraft - General - Miscellaneous (FS/W) | 0 | Sep 05, 2008 12:34 AM |
| Pots for Futaba conquest transmitter | hcastell | Electric Plane Talk | 2 | Sep 12, 2001 08:14 AM |
| Make your own DIN plug for Futaba TX! | pullin-gs | Electric Plane Talk | 0 | Sep 06, 2001 08:05 PM |
| WTB: Hitec 555 rx for Futaba ( | Slope Nut | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 28, 2001 08:54 PM |
| Programming manual for Futaba 7UAF | gwh | Electric Plane Talk | 3 | May 31, 2001 12:43 AM |
