Old Jun 25, 2010, 03:49 PM
bob4432 is online now
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Originally Posted by metalfred View Post
Bob, what brand / model of RX and TX are you using?
futaba 6ex w/ r606fs - tx reads 10.2V
bob4432 is online now Find More Posts by bob4432
Old Aug 23, 2010, 12:47 AM
pietro811 is offline
Find More Posts by pietro811
Joined Jan 2009
Hello everyone,
I want to know how to change a V8FR FRSKY to view the signal quality with my Eagle Tree OSD PRO and elogger V3, please help me. Thanks in advance to all.
pietro811 is offline Find More Posts by pietro811
Old Aug 23, 2010, 04:04 AM
arisarts is offline
Find More Posts by arisarts
Athens, Greece
Joined Dec 2004
Originally Posted by pietro811 View Post
Hello everyone,
Clear Top & Bottom Pictures (macro mode) of the PCB would be helpful Pietro..
arisarts is offline Find More Posts by arisarts
Old Aug 23, 2010, 09:28 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Search-here-for-this-RX-RSSI-tap-point-proved-negative.
Any-suggestions?
John
chaosMurphy is offline Find More Posts by chaosMurphy
Old Aug 24, 2010, 03:17 AM
Joined Jan 2009
I'm sorry for the low quality of images, for now I only have the phone, if these are not clear I will make more with a given machine. This a site with pictures http://www.rcmodelreviews.com/frskyreview.shtml . Thanks
Old Aug 26, 2010, 12:05 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Any-suggestions?
John
Try pin 12 on the chip with the blue dot
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Aug 26, 2010, 02:01 PM
luis fernando is offline
Find More Posts by luis fernando
Joined Sep 2004
Does someone please post how to get the RSSI from a futaba 6014HS
luis fernando is offline Find More Posts by luis fernando
Old Aug 26, 2010, 02:23 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Hello everyone,
There is no RSSI pin in this receiver. You can tap a pulsing signal from the green LED, it is not a proportional measure of signal strength, but a digital measure of data flow. It start to flash if no packet arrived for 9msec.
renatoa is online now Find More Posts by renatoa
Old Aug 27, 2010, 08:36 AM
mr..speed is offline
Find More Posts by mr..speed
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Originally Posted by SirAlex View Post
RSSI capture for Multiplex RX-12Synth DS IPD and Multiplex RX-9Synth DS IPD
The IC its Philips SA676 and RSSI its on pin 5.
Alex
Did anybody connect to the compact version, looks totaly different, 2 or 3 PCBs above and chip probably inside.
mr..speed is offline Find More Posts by mr..speed
Old Sep 11, 2010, 12:46 AM
Joined Jan 2009
thanks very much for your help....
Old Sep 16, 2010, 06:30 AM
cwd10 is offline
Find More Posts by cwd10
ΜΟΛΩΝ ΛΑΒΕ!
Pennsylvania, U.S.A.
Joined Feb 2005
Originally Posted by masam54 View Post
In my old NER649S, there's a 7761 chip, I also managed to get rssi from my old 10ch JR rx.
masam54. Did you do the mod to your NER649S? I did it on mine, and noticed something strange. I'm getting an inverse voltage on pin 7. In other words, it goes from about 3V with the TX off, to about 1.3v with it on. Can you confirm this is the right signal? If so, I guess I'll have to build an inverse follower of some sort.
cwd10 is offline Find More Posts by cwd10
Old Sep 16, 2010, 06:58 AM
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Here is the data sheet http://www.datasheetcatalog.com/data.../7/SA676.shtml
Alex
Can Anybody explain to me what I can do this the AUDIO signal of the SA676 ? See Pin 8 Audio.
Thanks Volker
Old Sep 16, 2010, 07:06 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
Thanks Volker
Hi,
That is the pin that the demodulated signal (ppm-stream) is coming out from, that your receiver then splits to each servo-ch. output.
So if you don't need the ppm-stream I would leave it..
Megafluffy
Megafluffy is offline Find More Posts by Megafluffy
Old Sep 16, 2010, 08:32 AM
masam54 is offline
Find More Posts by masam54
masam54's Avatar
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Dec 2008
My old JR NER649S was "retired" a couple of years ago, , so I did not do the rssi mod on it. Getting a reverse voltage rssi is no big deal, as long as its linear. If your OSD can calibrate for reverse voltage there's no need to build an inverse follower.
masam54 is offline Find More Posts by masam54
Old Sep 16, 2010, 08:46 AM
cwd10 is offline
ΜΟΛΩΝ ΛΑΒΕ!
Joined Feb 2005
Ok. Thanks. I guess I'll have to PM Bill at EagleTree, and see what he says.
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
