Old Jun 13, 2010, 05:16 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
So how do you go about implimenting this to an OSD display then ? Im using a blackstork 2
Coyote64 is offline Find More Posts by Coyote64
Old Jun 13, 2010, 05:51 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ
Joined May 2010
how is this tut?:
http://fpv-community.com/forum/showt...highlight=rssi
bob4432 is offline Find More Posts by bob4432
Old Jun 13, 2010, 07:05 AM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
Yup thats a great help, appreciated
Old Jun 13, 2010, 10:54 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
If anyone can help please let me know... I am trying to find the RSSI pinout for this RX:
This works with the FlySky FS-TH9X (b version).
Here are some pictures of the circuit board:
Any thoughts?
metalfred is offline Find More Posts by metalfred
Old Jun 14, 2010, 01:01 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What is on the other side ?
Can you read on the chip above the crystal ? I wasn't able to distinguish something readable
Most 2.4Ghz receivers does not exhibit a RSSI signal due to their operating nature. Instead they signal lost packets, by flashing a LED. Is there a LED on this receiver? If positive, I would tap it into the OSD RSSI input.
renatoa is online now Find More Posts by renatoa
Old Jun 15, 2010, 08:48 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
I will let you know what is written on the chip, those chips are way too small
Yes the RX has a red LED when status is OK, when I turn off the TX this LED turns off. I don't know if it blinks when having lost packets... How can I simulate that? I guess I will have too power on the stuff and record a video of the RX and leave the house!
How this will be displayed on an OSD ? lets say that 0% is 0.6v and 100% is 6v, when the led is flashing will it dance between those two? or will it simply go to 0.6v?
Old Jun 15, 2010, 09:35 AM
Joined Sep 2007
Originally Posted by metalfred View Post
...Yes the RX has a red LED when status is OK, when I turn off the TX this LED turns off. I don't know if it blinks when having lost packets... How can I simulate that? I guess I will have too power on the stuff and record a video of the RX and leave the house!
You can simulate simpler than you believe...
Just place the radio inside a microwave owen, this will be a perfect Faraday cage, creating the effect of a 2km distance.
DON'T power the microwave owen, lol !!!
After you close the owen, the range of your RC will be reduced to 3-5m only. You can walk with the receiver and see how it behaves, if it blinks, or stop abruptly.
If you use the LED method there is no more quantitatve approach, like signal xx% good. You must return imediatelly you see permanent blinking in the OSD. Random blinks at some seconds interval can be ignored.
Old Jun 15, 2010, 09:52 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Thanks Renatoa for this very useful information!!
I will do this test when I get home, I guess knowing that you are loosing packets is better than nothing. Mostly when you are using a cheap ass 60$ 9 channels TX / RX (FS-TH9X) like I do.
Old Jun 15, 2010, 10:04 AM
Joined Sep 2007
Cheap ass is not always necessary bad.
If you allow me another sugestion, if your actual 2.4GHz RF system (module + receiver) doesn't not satisfy you, you have the chance to upgrade to the new FrSky system, for at least several reasons:
- it is one of the best 2.4GHz systems on the market, borrowing the best from cream of the cream like Hitec and Futaba.
- it has +5km range, tested by me, search my recent posts for the test report. In fact, is the biggest range known by me reported by an individual for a stock setup, no booster, no fancy antennas.
- it is two way, i.e. has telemetry, and more important for your range worries, it features audio out-of-range warnings, in the radio module. This way you can forget about OSD, when you hear out-of-range beeps, you simply return ! These beeps tones ranges on three levels, some hundreds meters before total link lost, so you have enough time to return.
- not the last, because you can ! the system is available as JR module, that fits your radio.
Old Jun 15, 2010, 10:28 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
wow this thing looks nice... I will definitely look into this as an upgrade for my tx / rx. Thanks for the tip.
Old Jun 16, 2010, 09:27 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
So I have tried to find what is happening on the RX when it is missing packets and I couldn't make it dance. I have put the TX in the microwave oven, selected defrost and typed 3 minutes...and j/k :P
Seriously the TX in the microwave did not change anything on the RX side, I couldn't move the RX a lot to have it further away so I will have to re-do this test a bit later when wife is not there to tell me that my TX cannot be eaten.
Old Jun 16, 2010, 01:43 PM
Joined Sep 2007
Are you sure you closed the door perfectly ?
Only one mm open and the leaks are significant.
If still behave as above, then I would serious look for an owen service ... you can't continue to use it this way :scared:
I can make a movie to see how efficient is the shielding of mine.
Old Jun 25, 2010, 04:09 AM
bob4432 is offline
bob4432's Avatar
United States, AZ
Joined May 2010
is this pretty accurate range wise (2KM)? the reason i am asking is because i can go about 20M and outside just a bit w/ no led blinking, it seems my front door being metal stops it as i go outside and shut the door, i go about 1M and it starts blinking red/grn, but if i go in front of a window i can go another 5M and still have red/grn and i don't get full red until probably a full 15M outside.
Old Jun 25, 2010, 08:07 AM
Joined Sep 2007
Ah, is not accurate at all !
It depends from receiver to receiver, each has its own sensibility.
What you can detect pretty exact with this method is if you receiver has an usable range of led blinking before failsafe, to allow you turn in real flight, or the switch from flight to failsafe is sudden and unpredictable.
For example, if your led starts blinking at 18m and failsafe kicks at 20m, then you may rely on a 10% warn range margin in real flight too. This could mean 200m if your receiver has 2km range, or 300m for 3km range.
Old Jun 25, 2010, 08:58 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Bob, what brand / model of RX and TX are you using?
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 01:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 09:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 09:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 09:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 01:43 AM
