Old Sep 13, 2008, 02:41 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
RSSI pins for various receivers
Changed the title of the thread since so many nice folks are pitching in their knowledge.
I couldn't find the info on this for myself so I figured I'd post my results for those of you who are interested.
The R168DF is an 8 channel PPM receiver, and the R168DP is a PCM receiver. Both use the same 31136 FM detector IC. You can find a datasheet for a very similar (if not identical) device if you search for TA31136FG.
The RSSI pin is pin 12 on the 16 pin device. This is the 4th pin from the top right of the chip.
The pin outputs a DC voltage level is about .7V with the transmitter off and 2.2V when the transmitter is on. You can use this to tell the signal strength that the receiver is getting, but keep in mind that it doesn't tell you anything about signal quality, or if it is your Tx it is hearing or some other guy's Tx a mile away. Also remember that it probably saturates fairly easily, meaning it doesn't take much to make it hit that top 2.2V mark. With my antenna collapsed and on the other side of the house I was reading about 1.8V
Other folks who know more about this stuff should feel free to correct any misconceptions I have here.
R168DF
There is no nice large pad to solder on to here, there are some small vias in the board and I used one of these to tap on to. I used a micro drill bit to clean it out and then used some magnet coil wire to go through it and soldered on. Don't forget to sand the enamel off the coil wire
There are two vias you can tap onto but the one next to the capacitor was the easiest to get to.
(see attached images)
R168DP
I couldn't see the via from both sides here and since there was a large solder pad available on the back side I just used that. There may be other tie in points but I didn't bother once I saw the pad. There is plenty of room for a wire to lay on the under side of the board inside the plastic casing. I drilled a little exit hole near the rim of the case.
If you want to do some real testing on what kind of things increase or decrease your signal range this should be helpful to you. Enjoy.
BushmanLA is offline Find More Posts by BushmanLA
Old Sep 13, 2008, 05:14 PM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
thank you! I have the 168df. I shall try it out. It'd be nice to incorporate RSSI to an OSD, or a small volt meter you could look at with camera while flying.
aaron_gx is offline Find More Posts by aaron_gx
Old Sep 14, 2008, 05:38 AM
ROSSMANS is offline
Find More Posts by ROSSMANS
ROSSMANS's Avatar
UK
Joined Sep 2004
Think I'd go for the small volt meter seen by camera movement myself trouble is..I can things up enough without taking a receiver apart!! Good mod though if you are competent.
ROSSMANS is offline Find More Posts by ROSSMANS
Old Sep 14, 2008, 11:22 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
And if you're looking for RSSI out on a R617FS it's Pin #28
typicalaimster is offline Find More Posts by typicalaimster
Old Nov 21, 2008, 10:54 PM
sokiii is offline
Find More Posts by sokiii
sokiii's Avatar
Chicago, IL
Does anybody know where RSSI pin is on R319DPS?
sokiii is offline Find More Posts by sokiii
Old Nov 22, 2008, 05:56 PM
sokiii is offline
sokiii's Avatar
Chicago, IL
Here is the RSSI for Futaba R149DPS
http://www.rcgroups.com/forums/showp...3&postcount=12
But "unfortunately" I bought R319DPS. Looks like it has the same chip. I have an idea to measure voltage on every pin of chip, I have to be very careful. Does anybody know better way?
Old Nov 22, 2008, 10:55 PM
sokiii is offline
sokiii's Avatar
Chicago, IL
I played a little bit with RSSI signal from R168DF receiver and found it changes from ~2.2V to ~0.7V with the degradation of RC signal. I have onboard voltmeter which is connected to OSD, but internal resistor of voltmeter is only ~70 kOhms. So when I connect RSSI pin to it the voltage range is changing to 1.3V-0.4V.
I still can monitor the signal strength but is it bad for receiver to load RSSI pin? If yes I think I need micro current amplifier with big input impedance. Where can I get it or any recommendation how to build it?
Old Nov 23, 2008, 05:28 PM
MDreamer is offline
Find More Posts by MDreamer
"Here birdy birdy birdy..."
MDreamer's Avatar
Israel
Joined Sep 2006
Does anyone know RSSI pinout on any JR/SPEKTRUM Rx?
MDreamer is offline Find More Posts by MDreamer
Old Jan 25, 2009, 06:52 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
For the R319DPS the RSSI pin can be found at the below solder pad, where the red arrow is pointing at. This will output a voltage between 0.7 and 2.2V, with 0.7V being the absence of any signal and 2.2V with the transmitter nearby (hence maximum RSSI value).
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old May 19, 2009, 07:20 AM
nick.sargeant is offline
Find More Posts by nick.sargeant
Perth, Western Australia
Joined Dec 2005
I have a R149DP but unfortunately it is a different revision to the one linked to above.
Any ideas where the rssi port is on this one?
nick.sargeant is offline Find More Posts by nick.sargeant
Old May 19, 2009, 10:09 AM
BushmanLA's Avatar
Joined Dec 2005
Do NOT significantly load the RSSI pin. By load I mean draw current from it. Which means if you attach anything to it, it needs to have a very high resistance. A few 100k Ohms at least I should think.
I know on my PCM receiver, if I goof with the RSSI pin I can cause the thing to failsafe. So be careful what you do or you might have a reduction in range.
The best bet is to buffer it with a voltage follower. Or some kind of buffer setup.
ex.
http://hyperphysics.phy-astr.gsu.edu...mpvar2.html#c1
Old May 19, 2009, 12:52 PM
sokiii is offline
sokiii's Avatar
Chicago, IL
ex.
That's exactly what I did (half a year ago).
Old May 20, 2009, 04:28 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
LHS of the chip, bottom pin, directly above the Futaba F.
RolandS888 is offline Find More Posts by RolandS888
Old Aug 28, 2009, 01:05 AM
bandito66 is offline
Find More Posts by bandito66
Joined Apr 2006
According to this thread (http://www.rc-cam.com/forum/index.ph...161&#entry6161) ) RSSI pin of new R149DP (FP6302B chip) is located on bottom of chip, second pin from the left.
Can someone could confirm?
Is there a better location to solder than directly on chip's pin (solder pad for example )
bandito66 is offline Find More Posts by bandito66
Old Aug 28, 2009, 01:36 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
I really wish I understood what you were doing. Im right at the point of being able to read signal strength from your OSD. lol
yellowcolorado is offline Find More Posts by yellowcolorado
For Sale usb cable for futaba/hitec pin (round 6 pins) jaas75 Aircraft - General - Miscellaneous (FS/W) 0 Sep 05, 2008 12:34 AM
Pots for Futaba conquest transmitter hcastell Electric Plane Talk 2 Sep 12, 2001 08:14 AM
Make your own DIN plug for Futaba TX! pullin-gs Electric Plane Talk 0 Sep 06, 2001 08:05 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 08:54 PM
Programming manual for Futaba 7UAF gwh Electric Plane Talk 3 May 31, 2001 12:43 AM
