Old May 24, 2001, 08:37 PM
avdflyer is offline
Find More Posts by avdflyer
Lincoln Municipal, Nebraska, United States
Joined Mar 2000
1114/4Y 3.7 box what cell count and prop??
I have an aveox 114/y4 witha 3.7 to 1 gearbox I would like to use with a Falcon hotliner see NSP website. I am think that perhap 10 cells (1250's) and a 12X10 prop may work out ok but I really want to use all of the available power that this motor can give! Aveox says 40 amps max but I am only looking to run the motor a few seconds or so. What prop would work the best for a fast climb..run time be dammed! I have a 160c Controller so NO problem there...give me your suggestions!!!!!!
avdflyer is offline Find More Posts by avdflyer
Old May 25, 2001, 10:53 AM
Keith Watson is offline
Find More Posts by Keith Watson
Wilsonville, OR, USA
Joined Mar 2000
Electricalc shows the 12x10 at 30A and 45oz thrust for 2.4 minutes. The 14x9.5 shows 40A and 59oz thrust for 1.8 minutes. Maybe that prop?
Keith
Keith Watson is offline Find More Posts by Keith Watson
Old May 25, 2001, 11:06 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
If you have the little 3.7 :1 planetary gear(under the Robbe label), they are not very good. Make sure you loctite the screws and check it every flight . The nylon planets in it are not very strong.
Brian
bhchan is offline Find More Posts by bhchan
Old May 26, 2001, 03:48 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
Originally posted by avdflyer:
Brian,
Nope I have the real planeta 3.7 to 1 just like the f10lmr and others so there should be no problems with power output of the 1114/4y
In this, there is not enough motor!
Brian
Old May 27, 2001, 12:25 AM
avdflyer is offline
Joined Mar 2000
Brian,
What prop? 7.2V 2 cell direct drive rdeis Power Systems 2 Oct 03, 2005 12:35 PM
Mega 22/30/3 Geared 4:1 Cell Count Please mudlark Power Systems 0 Apr 22, 2005 06:08 AM
Hacker 9-cell motor with 7 cells...what prop? sayno2glo High Performance 3 Apr 26, 2004 03:20 PM
1406/2y w/ 3.7:1 what setup and plane? soholingo High Performance 8 Sep 11, 2003 10:25 AM
Max cell count for a hacker 50 10L with 6.7 gear box. dr.E Power Systems 5 Jun 11, 2003 08:21 PM
