Old Oct 21, 2012, 10:55 AM
John63 is offline
Find More Posts by John63
Vancouver, Canada
Joined Jan 2010
Yes, I am coming to that conclusion. I am using a DX6i.
Thanks to all who gave me some ideas here.
John
John63 is offline Find More Posts by John63
Old Oct 21, 2012, 11:25 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
John
Don't give up hope yet. The Radian is only a 3 channel airplane, so a 4 channel receiver should still give you options for throttle on a switch. I also have a DX6i and have been thinking about trying it. Here's a question...when you have the esc plugged into something other than the throttle channel, do the elevator and rudder work, or do you get nothing?
I wouldn't give up on that 6255 receiver either. You may have to cut some foam but there must be a way to make it fit. That receiver has a couple of advantages over the lower end Spektrum receivers that make it ideally suited for sailplanes. One is the long antenna leads, so the antennas can be brought out to the outside of the fuselage. The other is that it has programmable failsafes. The 600 and the 6210 only have failsafe on the throttle.
Jovanx is offline Find More Posts by Jovanx
Old Oct 21, 2012, 01:10 PM
John63 is offline
Vancouver, Canada
Joined Jan 2010
Jovanx
thanks for your offer.
I just hooked it up in three different ways. Yes, the elevator and rudder in all three slots But when the lead from the ESC is in all but the throttle slot I do not get the "fully armed" tone of the 3 rising notes.
John
Old Oct 21, 2012, 02:04 PM
Jovanx is offline
Joined Nov 2011
You would probably need to re-bind after moving the esc wire to some other channel. The binding process sets the zero point for future throttle arming, as well as the failsafe. Does it successfully bind with the wire in another slot?
Old Oct 21, 2012, 02:42 PM
John63 is offline
Vancouver, Canada
Joined Jan 2010
Jovanx, I just tried binding in the rudder slot and it would bind but I could not get the motor to come on. It would not do the full "arming" of the system. I did notice that both the instructions for the Rx and the Tx say that the ESC should be plugged into the throttle. I had read this before but on previous planes it seemed to be variable in what you could do. I will live with this the way it is.
Thanks again to all who contributed. John
Old Oct 21, 2012, 11:35 PM
labrown is offline
Find More Posts by labrown
SSP ASP#88
labrown's Avatar
United States, PA, Hatfield
Joined Apr 2009
I tried what you said but nothing changes. I have the "travel adjust" set at 50% so that in theory the motor will only rev up that much when I switch to "gear".
Try setting the travel adjust to 100%. The ESC is picky about the throttle signal being as low as possible when you plug in the battery, otherwise it won't arm.
--[Lance]
labrown is offline Find More Posts by labrown
Old Oct 22, 2012, 06:25 AM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Recalibrate the ESC, it should work then.
Endlesslag is offline Find More Posts by Endlesslag
Old Oct 22, 2012, 05:49 PM
strawcuter is offline
Find More Posts by strawcuter
strawcuter
Winchester, KY
Joined Feb 2004
Loose Prop
Guys, yesterday after puting a new motor in my Radian, I took it out for a maiden flight. Every thing went well until I got about 100 feet up, then the prop came out.
Fortunately I was able to recover it.
When I took it apart I found that the grub screw was loose. I had tightened it as tight as I could get it before assembling the rest of the prop system..
I was wondering what solutions any of you may have for this issue? I am thinking about using some CA on the motor shaft. What do you think.
Bob
strawcuter is offline Find More Posts by strawcuter
Old Oct 22, 2012, 06:19 PM
Jovanx is offline
Joined Nov 2011
Bob
I have 2 questions that might help to figure out what went wrong...
1 was the new motor a stock RP motor?
2 was the grub screw set into the flat part on the motor shaft?
Good on you for being able to bring it down safely after such a sudden in-flight failure! It's great to be heads-up and calm when things go wrong.
Old Oct 22, 2012, 06:23 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Oct 22, 2012, 06:51 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
Originally Posted by Radio.Active View Post
If you used a new motor without a flat spot on the shaft, or if you tightened the grub screw onto the round part of the shaft of the OEM Radian motor rather than aligning it to seat into the flat spot, this will happen.
Don't use CA as you might want to get it off later
You can grind a flat spot with a dremel . Here are some methods http://www.helifreak.com/showthread.php?t=395691 or use a new spinner with a collett rather than the grub screw.
http://youtu.be/h4S9gxzQ39g
If you decide to stay with the screw, you need to use a thread locker to make sure that the screw never loosens. Use the blue variety, it is designed to release. As mentioned before, don't use CA.
http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm
Cliff
cliffkot is offline Find More Posts by cliffkot
Old Oct 22, 2012, 07:26 PM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Be careful to not get Loctite on the plastic parts of the spinner. It will cause failure in time.
Greywing is offline Find More Posts by Greywing
Old Oct 22, 2012, 11:21 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
A dab of Canopy Glue works well and lets you remove without too much effort.
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 22, 2012, 11:53 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
Apply the LocTite to the threads, not the top of the tightened screw. It is a "thread" locker.
Foambird is offline Find More Posts by Foambird
Old Oct 23, 2012, 11:11 AM
w4yn is offline
Joined Jan 2007
Loc Tite will destroy plastic there is a lot on issues on this site where it has destroped motor and gear plastic mounts.
I use canopy glue because it is water based and will not attack plastic. A little on threads going in works well if you have access you can put a dab on protruding threads fir extra insurance. Just a word of caution on using loctite on plastic.
Tim
