Old Oct 14, 2012, 05:00 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Originally Posted by Rockin Robbins View Post
Kickstart, you're having spinner problems I haven't heard of before. Anybody else able to confirm similar malfunctions? What could be causing this?
My stock spinner failed when the pin holding the blade in sheared through the plastic. I replaced it with the Multiplex spinner and have never looked back.
TexasAggie is offline Find More Posts by TexasAggie
Old Oct 14, 2012, 05:02 PM
Manonthegrassyknoll is offline
Find More Posts by Manonthegrassyknoll
United Kingdom, England, Windermere
Joined Oct 2010
which spinner was that.? can you point me in the right direction..?
thanks
Manonthegrassyknoll is offline Find More Posts by Manonthegrassyknoll
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Originally Posted by Raften View Post
When are the failures happening, application of full throttle? I have had a loud bang two times when the props were folded back and I gave it full throttle but never had a failure. Anyone know if there is a way to program a soft start. I just bring the power on slowly these days.
I'm fairly sure that loud sound occurs when the blades smack against the stops when you quickly apply full throttle. This will likely put stress on the plastic around the pins, leading to failure. Solution: get a spinner that lets the prop blades swing forward instead of hitting hard stops; or, just be light on the throttle.
Old Oct 14, 2012, 05:04 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
thanks
Part number M733500. For example:
http://www.allerc.com/multiplex-easy...mm-p-5981.html
http://www.bphobbies.com/View.asp?id...7&pid=E1055866
Get some better blades while you're at it. 11x6 enables truly vertical takeoff.
Old Oct 14, 2012, 05:17 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
That's what I have always thought.
Raften is offline Find More Posts by Raften
Old Oct 14, 2012, 05:58 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I have wondered about the stops and why they are there. Couldn't a person cut the white plastic back so there would be no knocking? What purpose do the stops serve?
Jovanx is offline Find More Posts by Jovanx
Old Oct 14, 2012, 06:39 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Originally Posted by Jovanx View Post
I have wondered about the stops and why they are there. What purpose do the stops serve?
I've wondered the same thing myself.
Old Oct 14, 2012, 06:57 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
i have broken more spinners in the last month (2) than the previous year and a half- I wonder if QC has slipped on the _1_1 prop? or the spinner? last week a new spinner and prop broke in flight and shook the wings out of the saddle at altitude- luckily the fuse fell into a river and almost no damage resulted... electronics dried out and a new prop was procured and all seems fine..
scottdearinger is offline Find More Posts by scottdearinger
Old Oct 14, 2012, 07:35 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Oct 14, 2012, 08:46 PM
Rhett Gill is offline
Find More Posts by Rhett Gill
Australia, SA, Munno Para West
Joined Oct 2012
Howdy guys, got out early this morning before the forecast winds picked up... Only my 3rd flight ever and first with the GoPro Hero 2 strapped on Was good fun in the calm and i cant wait for a hot day and some good thermals
Radian with GoPro hero 2 (4 min 33 sec)
Cheers
Rhett
Rhett Gill is offline Find More Posts by Rhett Gill
Old Oct 15, 2012, 01:43 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
spinner
radioac: can you provide link to the hk 50mm spinner? i can't find it.
thanks
edit: never mind: i found it.
but still if you can tell me which blades you can fit in (and links), that provide approx power as the original, i will appreciate.
phil alvirez is offline Find More Posts by phil alvirez
Old Oct 15, 2012, 07:54 AM
Closed Account
Joined Aug 2011
Old Oct 15, 2012, 11:19 AM
Joined Jul 2007
ok. so please tell me which props you have tried and fit in the 50mm alum spinner.
that will let me get them, knowing that are good fit.
does the stock prop fits the al spinner?
hole diameter, gap. without having to do anything.
regards
Old Oct 15, 2012, 02:20 PM
Closed Account
Joined Aug 2011
Old Oct 15, 2012, 02:23 PM
Raften is offline
NorCal
Joined Dec 2009
Rhett, I think you just blew a lot of Americans vision of your country. Many think of it as rocks, roos, snakes, and big things along the coast that eat you. Green fields, who would have thunk it. LOL
