Old Oct 11, 2012, 12:43 AM
Rhett Gill is offline
Find More Posts by Rhett Gill
Australia, SA, Munno Para West
Joined Oct 2012
Howdy guys, new to the R/C sailplane scene. Just purchased a Radian and am patiently waiting for a nice calm morning to have my first flight fingers crossed i go alright
Rhett
Rhett Gill is offline Find More Posts by Rhett Gill
Old Oct 11, 2012, 02:05 AM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Rhett, go easy with the throttle when you launch and replace those cable locks. Have fun.
Raften is offline Find More Posts by Raften
Old Oct 11, 2012, 02:11 AM
Joined Oct 2012
No probs cheers Raften
Old Oct 11, 2012, 02:18 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
turning upwind-or downwind
1st, this is a matter of perception. it is not something that we can provide data or figures. so i will not try to argue about what anybody thinks. it is a waste of time.
you think what you think and i think what i think, based on our experience or perception.
about slope, if any1 does not think that turning away from the cliff not only allows the plane to keep altitude better, but also keeps it at a safer distance, it's his prerogative to think so.
and about thermals (remember i said 'unless you are into a strong thermal'), my perception is that turning a plane downwind makes it sink more than upwind. that's what i see with my planes. and no1 is going to persuade me on the contrary.
neither i will be able to persuade him of my point of view.
so i will not bring more comments on the issue. it's a waste of time.
phil alvirez is offline Find More Posts by phil alvirez
Old Oct 11, 2012, 01:36 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
All 3 of your pieces of advice are dead on, Raften. Replacing the cable locks is the only must-do mod for this plane. It took me many flights to realize that full throttle is neither necessary nor advisable when launching. This plane has such a flat glide ratio, that it can climb at 1/4 throttle. When it is at maximum, the elevator is super-sensitive and it is easy to see why new pilots get into trouble when using full throttle close to the ground. Once it is up above the trees, feel free to let 'er rip and see if it can go straight up.
Jovanx is offline Find More Posts by Jovanx
Old Oct 11, 2012, 11:20 PM
Joined Oct 2012
Howdy guys, Well i had my first ever go of a R/C plane and of a Radian... I should have got one earlier it was great fun.... Was a cold, calm morning so no thermals around but that is my next challenge to find some Was so pleased with how i went....
Bring on todays arvo flight
here is a vid of this mornings first ever go..
Parkzone Radian maiden flight (3 min 33 sec)
Rhett
Old Oct 12, 2012, 12:12 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Excellent. There is a thread dedicated to the question elsewhere on rcgroups. If you want to troll do it there.
http://www.rcgroups.com/forums/showthread.php?t=1679552
kaptondave is offline Find More Posts by kaptondave
Old Oct 12, 2012, 05:28 AM
Joined Jul 2007
thanks for the link
Old Oct 12, 2012, 07:48 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Oct 13, 2012, 09:36 AM
pilottube is offline
Find More Posts by pilottube
I ain't afraid of no highs
pilottube's Avatar
Spain
Joined Jun 2008
Nice looping jovanx in your previous video! Isn't that too much stress for the wings?
Hey Rhett, not bad for a first flight, that "first Stall" happened to me too, but I had some more altitude and I managed to recover. You just have to know how much down stick is needed to prevent the plane from nosing up when using throttle. Good luck hunting thermals! I caught a few today:
From ground to sky high (3 min 22 sec)
pilottube is offline Find More Posts by pilottube
Old Oct 13, 2012, 11:35 AM
Jovanx is offline
Joined Nov 2011
Thanks. I do lots of loops with this plane because they look so graceful on the Radian. It's true that I am probably pushing the stress level of the wings to the limit, especially considering the stock tubular spar has been replaced with a super stiff CF spar. That pushes the flex out to the wing tips and makes them even more vulnerable to breakage.
The good news is that it has survived many hard loops, dives, and gusty winds. It can't do that forever, as styrofoam fatigues just like any other substance. A guy could replace the flat FG spar with aluminum without an increase in weight. That is the solution for the PZ Corsair which has a notoriously fragile and flexible wing. For now, I think I'm going to put a few strips of packing tape on the underside of the wings and see how it goes.
Old Oct 13, 2012, 10:23 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
First of all, the Radian is not made out of Styrofoam.
You will not break the wings with the factory spar. I have seen winch launches bending the wings past 45 degrees without failure.
The Radian does not weigh enough to overstress the wings in any kind of high speed dive.
Not an issue in two years of flying the Radian.
Foambird is offline Find More Posts by Foambird
Old Oct 14, 2012, 06:33 AM
pilottube's Avatar
Spain
Joined Jun 2008
thanks for the info, I don't usually do loopings but when people are around that can be a good way to impress them. Also is good to know the wings won't break.
Old Oct 14, 2012, 09:24 AM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
wing flex?- the Radian can take it !!! this was captured during a mid air collision with Eckace's Radian...
Name: Snapshot 4 (7-25-2012 11-16 PM).png
Description:
scottdearinger is offline Find More Posts by scottdearinger
Old Oct 14, 2012, 09:33 AM
Joined Apr 2011
here are a few pics i was looking through to find the wing flex photo
just pretty
Name: Snapshot 1 (4-3-2012 10-42 PM).png
Description:
Radian in the clouds
Name: Snapshot 1 (4-30-2012 9-48 PM).png
Description:
the Franken radian stick thing
Name: Snapshot 1 (8-12-2012 4-48 PM).jpg
Description:
Eckace runs into my tail
Name: Snapshot 5 (8-6-2012 11-23 PM).png
Description:
just pretty- up high
Name: Snapshot 5 (3-27-2012 10-50 PM).png
Description:
