Old Oct 02, 2012, 10:22 AM
mataub's Avatar
UK south
Joined Dec 2007
Originally Posted by Paul1PA View Post
Hey Steve,
Yes, the OD of the Radian spar is 10mm. Also, the 75cm length of the HyperFlight carbon spar will be fine (in fact, you'll have to trim off 50mm to match the stock length ).
What is your reason for wanting to use CF? If you're only looking for increased stiffness, one good option is to simply use a Radian Pro wing spar. Both the length and OD are identical but the spar is substantially stiffer. However, since the Pro spar is still fiberglass and has a thicker wall, it is heavier. For comparison, my Radian and Radian Pro spars weigh 21.5 grams and 41.9 grams, respectively. Don't see a published weight for the HyperFlight spar, but being CF it will most likely be stiffer and a bit lighter than the stock Radian spar.
Personally, I like to use the Pro spar in windy/turbulent conditions or when doing aerobatics. Plane seems to handle the flight stress better plus the added mass may help slightly with penetration into the wind.
Hope this helps,
-Paul
Hello Paul and thanks for that information. Like you I have both the Radian and the RP......both of which are, at the moment, 200 miles away, otherwise I might have cottoned on to that solution! The actual weight of the CF tube (10mm OD and 9mm ID) is 24gm per metre length. I might buy a length and try it out, though I quite agree about using the heavier Pro wing spar for windier weather....something I haven't tried yet.
That was useful information and is food for thought - thanks.
Steve
mataub is offline Find More Posts by mataub
Old Oct 02, 2012, 10:41 AM
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
The CF spar is heavier than the Radian spar, at 28 grams, and lighter than the RP spar. It is considerably stiffer than the others two. I like the way it flies and the reduced wing flex probably cuts down on the wear and tear in the saddle area.
Jovanx is offline Find More Posts by Jovanx
Old Oct 02, 2012, 11:53 AM
USA, CA, Pismo Beach
Joined Oct 2007
Weight is dependent on wall thickness so if the wall is the same as the stock spar it should be lighter shouldn't it? Where did you get your CF spar?
Greywing is offline Find More Posts by Greywing
Old Oct 02, 2012, 12:00 PM
Joined Nov 2011
It has the same wall thickness as the RP spar, which is quite a bit thicker than the Radian spar. I got it from Great Hobbies, and it was made by CST The Composites Store. A thinner-walled tube, such as an arrow shaft would still be an improvement over the stock one, and would be the ultimate choice for someone who is serious about keeping the plane light.
Old Oct 02, 2012, 12:02 PM
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
The pilot admitted he charged a 1c battery at 4c by mistake. Since the charger and battery were on the curb he did not torch his car.
Foambird is offline Find More Posts by Foambird
Old Oct 02, 2012, 01:35 PM
Joined Nov 2011
Ground effect on windy day
One of my favorite things to do with the Radian is to milk the ground effect for all it's worth. If the field is big enough, you can get it down to about 2 feet off the deck and still go an amazing distance before finally setting it onto the grass. My question is...does this still apply when the wind is blowing hard and the plane is hovering in one spot?
On Saturday the Radian was put to the big wind test and it did great. Usually I fly the RP on those days, but it was at home. The wind sock was sticking straight out and there was only one guy flying (an edf jet). I did a few loops and spiral dives just for fun, but most of the time was spent with it pointed into the wind and staying in one place. I did about 5 or 6 vertical landings, and all were good except one was hard enough to knock the canopy off.
One of the landings was amazing, and the pilots who were watching were impressed. It just hung there, hovering 2 feet off the ground, for an unbelievably long time. (gliding, not under power). Was the ground-effect cushion still a factor in this wind?
Old Oct 02, 2012, 01:40 PM
NorCal
Joined Dec 2009
"Was the ground-effect cushion still a factor in this wind? "
I think is was but the higher percentage would seem to be with the head wind.
Raften is offline Find More Posts by Raften
Old Oct 02, 2012, 06:23 PM
Joined Jan 2010
Thanks for the clarifucation. For those not making the connection Foambird is referring to an earlier post about the practice of charging Lipos in a vehicle.
kaptondave is offline Find More Posts by kaptondave
Old Oct 02, 2012, 08:18 PM
cliffkot's Avatar
Joined Jun 2010
When the wind is blowing absolutely steady, it has no effect on rate of descent. However, keep in mind that when you are in ground effect you are very close to the ground which means that any wind will be affected by frictional ground forces and deflect off any discontinuity in the surface. This in turn causes turbulence, which negatively impacts the aircraft's performance, but it may also cause little updrafts which will tend to keep the plane aloft a bit. What I've found though is that these little updrafts generally hit one wing or the other which causes the plane to bob around which is not good if you are trying to get every last little bit of performance out of the plane.
I find that I get the best glide in this situation on absolutely still days. Then the plane seems to want to fly forever, even 12 inches off the ground. It's fun to do, unless you misjudge things a bit and find yourself heading for a fence, curb or pick-nick table, in which case you have to dump the nose real quick and pick up a little grass.
Cliff
cliffkot is offline Find More Posts by cliffkot
Old Oct 02, 2012, 09:56 PM
Joined Nov 2011
Originally Posted by cliffkot View Post
I find that I get the best glide in this situation on absolutely still days. Then the plane seems to want to fly forever, even 12 inches off the ground. It's fun to do, unless you misjudge things a bit and find yourself heading for a fence, curb or pick-nick table, in which case you have to dump the nose real quick and pick up a little grass. Cliff
That's a roger. cliffkot. I like to make circles close to the ground, until the wing tip almost touches, and then the circles have to be bigger. Eventually, the ground effect is exhausted, and the plane is forced to make a perfect soft landing. This is much more difficult with the Radian Pro, because it is moving faster, sideslips more, and is more likely to drag a wing tip on the ground. The ground-effect-effect with the standard Radian is absolutely awesome.
Old Oct 03, 2012, 06:11 AM
mataub's Avatar
UK south
Joined Dec 2007
Thanks you for your input, Jovanx.
Steve
Old Oct 03, 2012, 11:50 AM
Windsor, Canada, near Detroit
Joined Jul 2007
my view is that, as the wind blows horizontally, it has to be some sort of vertical draft, a surface thermal coming from warm air from the ground, mild but strong enough to keep the plane afloat. i have seen this with some of my planes. i used to fly free flight towline gliders. once early in the morning i launched to test trim with a short line, about 20 feet, and the plane remained turning around at 10 feet for 3 minutes, until the dethermalizer made it drop. it was a surface thermal, not stronger than the plane needed to stay at same level. when the speed of the plane is the same as the wind, and there is a thermal strong enough to balance the weight of the plane, it stays there as hanging from the sky. it also happened to me when flying another r/c sailplane: it didn't move for over 10 minutes. people came asking how was it hanging. i had to bring it down because there was another fellow on same frequency and was asking me how long i would be there.
phil alvirez is offline Find More Posts by phil alvirez
Old Oct 03, 2012, 12:09 PM
Joined Sep 2009
Sounds like you would like slope soaring your Radian. I have "parked" the Radian in the air and set the contoller down and watched it just sit there hanging six feet above the ground. Really fun.
jmps is offline Find More Posts by jmps
Old Oct 03, 2012, 12:21 PM
Joined Nov 2011
I have slope soared a couple of times with the Radian Pro and it is a lot of fun. I tried again yesterday but there was barely a breeze and no lift to speak of. It would have been more fun with the Radian. I want to try it with the Radian for sure. The landings up on the mountain are not foam-friendly, and I did some damage to the RP on a sharp rock. Gotta keep practicing those hand-catches.
The scenario I was describing earlier occurred on flat ground, and although it might have looked to the other people that it was just hanging by itself, I was actually very busy operating the elevator stick to make it happen.
Old Oct 04, 2012, 01:51 AM
Me Flyin' me Smilin'
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
Less wind I take the Radian out. More wind I take the Radian Pro out.
They are both terrific, just different.
Grazer is offline Find More Posts by Grazer
