Old Sep 09, 2012, 11:07 PM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Closed Account
Joined Mar 2012
Originally Posted by phil alvirez View Post
thank you very much. seems very close.
have you used it?
any more input?
thanks again.
I've used an EMP 3530/1100kv motor. The major thing that you'll have to worry about, will be overheating those flimsy wires, as I did with my similar motor. Look at the video below and you'll see what happened to mine after 3 minutes of a full throttle climb. But, like I always say, if you buy cheap, expect cheap! Just don't be a yahoo on the throttle, like I was and you'll be fine.
Brushless Motor Repair (8 min 49 sec)
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Sep 09, 2012, 11:23 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
great advice
thank you very much for the great advice and video.
as i have noticed that my rad climbs at 1/2 throttle, i think (hope) i will not overheat the wires.
i am planning of using a 30 a esc on it and same (original) prop.
what pack are you using?
thanks again.
phil alvirez is offline Find More Posts by phil alvirez
Old Sep 10, 2012, 12:40 AM
Joined Jul 2007
replacement spinner
now what about a replacement spinner?
2", or between 52 and 55 mm dia., that fits the 4mm shaft.
ideally plastic, and if possible, that matches the original prop blades.
and more pointed?
can't find any at hk!
Old Sep 10, 2012, 01:41 AM
Closed Account
Joined Mar 2012
and more pointed?
The original spinner/prop adapter is 2.5in in Dia., which equals 63.5mm in Dia. metric. As far as the spinner is concerned, you'd more than likely have to go with one slightly larger, or smaller, if you're looking for a pointier spinner, as well as one that's either carbon fiber, or aluminum, which HK, has a pretty good choice, or ebay.
Old Sep 10, 2012, 04:39 AM
Joined Jul 2007
pack capacity?
Originally Posted by Maximilionalpha View Post
The original spinner/prop adapter is 2.5in in Dia., which equals 52mm in Dia. metric. As far as the spinner is concerned, you'd more than likely have to go with one slightly larger, or smaller, if you're looking for a pointier spinner, as well as one that's either carbon fiber, or aluminum, which HK, has a pretty good choice, or ebay.
thanks.
what pack capacity are you using in your rad?
where is it balancing?
regards
Old Sep 10, 2012, 08:15 AM
Closed Account
Joined Mar 2012
thanks.
regards
I use both, a 2200mah 3S Lipo, as well as, a 1300mah Lipo. Can't give you the specifics about it's balance weight, due to my different camera mounting setups, but without any of my mounts and cameras onboard, it balanced at 2 inch back from leading edge with 2200mah 3S Lipo and about 2.5in from LE with 1300mah Lipo. With my cameras and mounts added, it's waaaaayyyy, different.
Old Sep 10, 2012, 08:39 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Sep 10, 2012, 08:56 AM
Closed Account
Joined Mar 2012
Originally Posted by Radio.Active View Post
The EMP 3530/1100 is rated at 30A for 60 Seconds. That may be the problem
http://mayor-hobbies.net/RC/pages/info/emp_35-30.html
I know, but it was such a fast motor, that I decided to try my luck and push it for a 3 minute climb, but, no luck....
EMP 3530 1100kv Brushless Motor Meltdown In My Parkzone Radian (9 min 28 sec)
Old Sep 10, 2012, 09:40 AM
Greywing is online now
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
You might want to check the math here. 2.5" is 63.5 mm. The OEM spinner is about 52mm which is a shade over 2". Most 2" spinners look fine in place - such as the Cularis.
Greywing is online now Find More Posts by Greywing
Old Sep 10, 2012, 09:46 AM
Closed Account
Joined Mar 2012
Yes, sorry, thanks for the correction!
Old Sep 10, 2012, 10:38 AM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
here is our Sunday Radian adventure over downtown - with police permission and Bob hits a cell tower... fun times...
: D
It is a bit long- but there is too much in here to cut. 6 camera views all good stuff
Metro Skyscraper Radians with Cell Tower Crash (8 min 39 sec)
scottdearinger is offline Find More Posts by scottdearinger
Old Sep 10, 2012, 12:01 PM
Joined Jul 2007
packs
interesting. thanks. i have been using it with 1 pack of 3x1000-and 24 gr ballast, and also with a 3x1300 pack. both weigh about 105 g and balances at 2-1/2"=33%. a 3x2200 may make it too heavy for thermalling, and will need to add some ballast at the tail, but would make it good for windy weather.
Old Sep 10, 2012, 05:48 PM
Closed Account
Joined Mar 2012
I thermal quite a bit with my 2200mah lipo. That's one of the main things I set out to do, when the days are just right for thermaling. Just balance out your plane and it's not really going to much matter which type of battery you're using, at least it hasn't mattered much to me.
Old Sep 10, 2012, 05:51 PM
Closed Account
Joined Mar 2012
: D
http://www.youtube.com/watch?v=GTnzFI8okv8
No offense guys, but those GoPro cameras make things look like google earth 3D. Just too artificial for my taste, but that's just me.
Old Sep 10, 2012, 06:12 PM
Qualo Kabrigne is offline
Find More Posts by Qualo Kabrigne
Joined Nov 2009
Is 9 to 10 mph a good wind speed to search for thermals in? That is typically the wind speed at the field I fly at, and it takes a little courage for me to launch and fight the gusts.
Qualo Kabrigne is offline Find More Posts by Qualo Kabrigne
