Old Aug 18, 2012, 12:52 PM
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by Foamaholic View Post
Looked like you has some spectators.
I did.
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Aug 18, 2012, 02:32 PM
Canada, BC, Vancouver
Joined Feb 2012
Hey guys, Ive just gotten myself a Radian pro. I am looking for some insight on some good setups/ mixes
Any quick links or should i just start 900 pgs back and have read lol
elliott000 is offline Find More Posts by elliott000
Old Aug 18, 2012, 02:43 PM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Hi Elliott,
You might want to track down the Radian Pro thread - this thread is focused on the R/E Radian.
Best,
Josh
jgalexander is offline Find More Posts by jgalexander
Old Aug 18, 2012, 03:18 PM
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Here is a link to the Radian Pro thread:
http://www.rcgroups.com/forums/showt...+spar&page=682
There are a couple of other ones but that is the busiest one.
Jovanx is online now Find More Posts by Jovanx
Old Aug 18, 2012, 05:31 PM
Joined Feb 2012
thanks guys
Old Aug 18, 2012, 08:06 PM
United States, FL, Grant-Valkaria
Joined Mar 2012
Hey guys, I just got a Frsky module and rx and I'm having a hard time finding a way to fit the D8R-II plus rx in the Radian. Not a fan of Spektrum, but I sure like the size and configuration of their receivers. I'm sure others are using Frsky in their Radians. Anyone care to share how you installed the RX? Thanks.
Calla969 is online now Find More Posts by Calla969
Old Aug 20, 2012, 03:44 AM
Gimmer's Avatar
Australia, QLD
Joined May 2011
I have a 6channel jammed in mine. Have a friend you has an 8channel. He grabbed a knife and strated cutting.
Gimmer is offline Find More Posts by Gimmer
Old Aug 20, 2012, 06:56 AM
Joined Aug 2011
Same problems with my Futaba RX. Servo extension cables and place it in the cockpit.
This is the Orange RX which is even bigger than the Futaba although I removed the case and put it in clear shrink wrap to make it thinner
https://skydrive.live.com/?cid=dbde7...65DDCB92%21745
and
https://skydrive.live.com/?cid=DBDE7...5DDCB92%211204
Radio.Active is offline Find More Posts by Radio.Active
Old Aug 20, 2012, 05:43 PM
Joined Nov 2003
Non HH replacement motor
Hi
I was wondering if there was a non-Parkzone motor (i.e. less expensive) that fits easily in the Radian/ Also are there any tricks to replacing the prop blades on the folding prop? Do you need to secure the screws with thread locker or glue?
Ray
kostuk is offline Find More Posts by kostuk
Old Aug 20, 2012, 06:00 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by kostuk View Post
Hi
Ray
There are no screws for the blades themselves only metal sleves.
You only need to use loktite on the grub screw as mine came off in flight but landed ok.
eckace1 is offline Find More Posts by eckace1
Old Aug 20, 2012, 07:18 PM
Joined Aug 2011
Hi
Ray
Here is an eBay listing for an adaptor plate for replacement motors. Near the bottom of the link are 8 motors with links to their suppliers' pages.
http://www.ebay.com/itm/Parkzone-Rad...-/160521862924
Watch out for shaft diameter as you may need a new hub/spinner if it is other than the 4 mm PKZ standard and perhaps an ESC upgrade to more than 30A. Some might also require a shaft reversal.
One close one is http://www.hobbyking.com/hobbyking/s..._AXi_2814.html but too popular and often out of stock. So U.S. folks this is in stock and quick delivery but still needs the adaptor plate or other mods to the cowling.
http://www.headsuprc.com/servlet/the...lectric/Detail
In the end, it is sometimes just easier to stay with the PKZ $40+ motor. I have yet to detroy one electrically running up to a 11X8 prop and drawing 26A and go almost straight up to ALES height in less than 30 seconds. No need for more than that IMHO.
Old Aug 20, 2012, 09:06 PM
Radian, Polaris, Mistaken ID.
Baseman's Avatar
Japan (Military)
Joined Nov 2010
I did it
OK I did it...
Broke the nose on my original Radian again... Although I glued it at the field and tossed it back in the air, I could not morally repair it many more times, So i had a new fuze I ordered some time ago. ( I new the day was coming )
I went ahead and did all the Paul Naton Mods. Plus a few of my own..
On my original, the pushrods were the first to come loose, and came loose several times. So this time I pulled them both together with a carefully fed zip tie.
The CF Tow really stiffened the fuse, but the vert stab had alot of flex. I fed a 5mm sharpened cf strip down through the Stabilizer all the way to the center of the fuse. Pulled it back out, cut it to length, and coated it with a little epoxy fed it back in. really stiffend the vertical stabilizer.
Added DuBro hinges to the rudder.
Completed with a new stock nose cone.
But i figured since I have it apart, I went ahead and cut in some ailerons... Mostly so I can use them as spoilers... Will report on how she flies upon completion of Aileron mods!
Baseman is offline Find More Posts by Baseman
Old Aug 21, 2012, 07:58 AM
Joined Jan 2010
Hi
Ray
I use this motor from Hobby King:
http://www.hobbyking.com/hobbyking/s...dproduct=17919
I mount it directly to the cooling slots in the firewall, without the aluminum X-mount that comes with it. For a better fit use the aluminum mount from eBay that Radio.Active link you to.
The stock propeller and hub have no screws holding the prop. If you upgrade to the aluminum hub and Graupner prop there are bolts that hold the prop, and those should receive some blue LocTite.
kaptondave is offline Find More Posts by kaptondave
Old Aug 22, 2012, 02:22 AM
Baseman's Avatar
Japan (Military)
Joined Nov 2010
ok, I got it up in the air for a few flights. I am happy to report that I am VERY happy with the way this thing glides now. All the pourposing tendancies are GONE! I mixed in the ailerons to work as spoilers and as flaps. Both of those were great.
All the Paul Naton mods work as intended. This thing flies more like a real glider. It definately does not feel like the Radian I once had, but It glides like never before!
Howerver, I was not happy with the ailerons. I new it was a crap shoot because they are so close to the fuse. I even mixed ailerons with opposing rudder, and was not happy with the results at all. When I fly it with just rudder like she was intended for, it was great.
So, I will be using the ails as flaps and spoilers only.
Overall.... Very Smooth!
Old Aug 22, 2012, 06:34 AM
Joined Aug 2011
Thanks for the update. You didn't say what TX you have. If you have one with a dial or slider you could experiment with your spoiler/flap mod to do camber and reflex... just a few millimeters of up or down to see how it effects your thermaling.
