![]() I like the way you didn't big yourself up and say "Here's what I wrote" You should do though it's just what we needed. ![]() Excellent
Joined Jan 2010
After the mod mine flew as slowly and with the same low sink rate as before, which is to be expected because after adjusting the cg rearward and trimming it should be flying at the same Angle of Attack as the unmodified plane. The difference is that it will have less pitch stability. That will make it respond more quickly to AoA changes caused by thermals and gusts. In calm air it will fly much as before but in turbulence it may require more control input.
I have to assume that you have an opinion to back up justification of the modification. Quote:
More control input is always needed in turbulence. Stability is a slow responding process thus the need for more input control in turbulence. It would be interesting to understand why the modification causes less pitch stability (if it does). Zor |
Canada, BC, Smithers
Joined Nov 2011
Why is it that everybody who has done the infamous mod has been pleased with the results? (including Paul who wins contests using that mod...we know he is a skilled pilot, yet he still does it). |
Joined Aug 2011
I modified my Radian and the Radian Pro to 0* decalage as I do with almost all gliders I own. I reworked my Easy Glider Pro to a floating tail to eliminate the argument all together. In all cases I also move my CG as far back as I like to fly at. In dead air all modified gliders can fly dead slow, slower then originally did mostly due to rearward shift in cg. The huge difference is that now the glider does not plow through the air over stabilized, it feels much more nimble, reacting to air currents and signaling lift. Also when hitting turbulent air it rises up and down fairly level not just nosing up and down creating the usual up down oscillations of a nose heavy machine with every change of speed. Of course full power climb is just a strait line holding tiny bit up in my case.
As a side note I modified several of these foamies and I stiffen the fuse first and then measure the decalage, each one proved to be a little different angle. It is better to leave a bit of a positive angle rather then go to far which creates a bit unpleasant flying glider. One of my friends has unmodified Radian but very rearward CG, in dead air, side by side, his sink rate and speed is comparable with our modified ones, but it does not signal air changes as well and once upset by gusts, his corrections are much more difficult then ours, due to instant humping up and down and as a result he always losses more height then we do. It all also depend on flying experience, few years ago I did not see or feel much of this, but now I do and I know what I am looking for, but still learning every day. By the way my fully floating tail on my EGP, after I got it to fly to my liking and measured the decalage angle it is nearly 0 and so is my newly motorized Aguila Woodie gas bag. Quote:
If you don't move the CG back, you want to leave decalage alone. Cliff PS to any Noobie reading this. If you elect not to do any major surgery on you bird at least try moving the CG back a half inch or so in baby steps. You will be very pleased with the result. |
Joined Aug 2011
I've found that when I add my CF arrows I don't need to do the decalage mod as the tail boom is vertically straight on the bottom, the elevator is pulled down and the decalage is then near zero. |
Joined Nov 2011
The benefits of replacing the existing FG junk with a CF arrow shaft are a whole other story, just in terms of the increased control you get from the elevator and rudder, but here we also have a decalage adjustment. When I put that straight rod into that curved slot, the ends were still sticking out. I wrapped some tape around the ends of the rod to hold them while the glue was setting up. The decalage was reduced by forcing the fuselage into another position. It flies great!! |
Joined Jan 2010
Those that have done it are pleased because it flies better, which is the reason Paul advocates it and the reason he wins contests with it. |
Joined Mar 2012
Naked-Eye Flying, my Parkzone Radian
