Joined Jan 2010
There is debate as far as I am concerned. I am reporting facts based on personal experience with the decalage mod. Zor has no such experience, does not own the standard Radian for which the mod was designed, and therefore has no standing from which to debate facts.
United States, CA, Laguna Niguel
Joined Jan 2012
FASST compatible OrangeRX in servo bay
Think I need to remove a little foam in front of the receiver to give the servo arms a bit of room to move. What might be a good attachment for a dremel to remove the foam in front of the receiver here. I already chipped out that one bit of foam so the receiver could lay flat, but would like to find a cleaner way to machine out the foam without it being chunky
YMMV LOL
Joined Apr 2002
Extended Wing Span Radians ?
Guys,
Who's been successful extending the WS of the Radian? Given the eliptical wing planform I wondering if this is best done at the root or near the tip. The mod itself looks pretty easy with some careful cutting and the installation of a sup-spar insure good load transfer at the point where the extension is made... Thoughts, experiences and horror stories welcome ![]() TIA. :harry |
#60 grit sand paper and hemostats
![]() js |
Joined Jan 2012
Thanks to everyone for the suggestions. I went down to the hardware store and picked up a router bit for my Dremel. Got home and could not find my Dremel case. So time to think of another option.
I was a bit hesitant to use a soldering iron on the foam. But it actually worked fantastic. Practically no smoke and super quick. As if the foam just magically disappears with the touch of the soldering iron. You just have to be careful not to get the iron close to any part you don't want to disappear. It's quick. I also thought it might gunk up the tip of the soldering iron but it was as if the foam just evaporated, no gunk. Of course, for precise depth cutting like Lilienthal mentions above for his spoilers, the Dremel would be the option. But I just needed to rough out the foam so my RX would fit better. |
Gliding for distance is done at the angle of attack for the highest lift to drag ratio. Gliding for endurance is done at a slightly higher angle and lower speed than for distance because by reducing speed below that which gives the flattest glide we gain more by the lower airspeed than we lose by the speeper glide. The full size pilot can make the adjustment since he has an airspeed indicator on his instrument panel. The model plilot has no way of judging the small difference in nose attitude or judging accurately enough the airspeed of the model. Zor |
Debate or discussion or exchange of understandings; call it whatever you wish, that is fine and changes nothing.
Many readers and participants in the forum have knowledge of Zor's experience in aviation and also as a modeler. Radians do not fly by any different principles than any other airplanes. Quote:
I would hardly refer to that as "a design" Quote:
I restpectfully wish you some more knowledge and experience in the domains in which you are expressing your "feelings" even if you like to call them "facts". With all due respect to you as a modeler friend . . . de Zor |
Kilsyth, Victoria, Australia
Joined Oct 2003
I don't wish to criticise any individual or this thread in general but it seems mildly amusing. I came into this thread just because purely for fun I purchased a basic Radian merely to compare it with my Easy Glider Pro. I got here to find extended, relatively heated, discussions on the aerodynamics of what appear to me to be a basic albeit very good flying electric sailplane.
I understand the desire to tinker with or modify the model because it is so cheap a total loss isn't the end of the world but it simply is what it is a good flying foamie. If it isn't can someone explain? |
Joined Jan 2010
I understand you being perplexed David. Your assessment of the Radian is spot on. It is a basic yet good-flying machine as it comes out of the box. However it invites tinkering because the foam construction makes it easy to do and cheap to recover if a mistake is made. People are willing to do things with a Radian that they would never try with an expensive composite glider.
Are you familiar with the GWS Slow Stick? To me there is a parallel there. The Slow Stick has a huge following of tinkerers. There are more posts about it on rcgroups than on any other plane. The reason is the same. It is simple, cheap and easy to modify. The same goes for other models including the Multiplex Easy Star. On the Radian there are two types of popular mods - those intended to improve durability and those intended to improve performance. Both enhance the enjoyment, and that is why we do them. It may be that there are one or more individuals who take aerodynamic theory over the top a bit but that is their form of enjoyment, and we can live with that. |
Joined Feb 2006
Competition RC sailplane pilots make frequent elevator adjustments for differing conditions. Indeed, the RC pilot can't see small differences in nose attitude, but he has some sense of airspeed just looking at the plane. Skilled pilots have a keen sense of when a plane is in lift or sink. Coming home with a head wind is a challenge. To cope with all of these conditions, the pilot makes changes in elevator trim. RC competition sailplanes end up being flown much like their full-scale counterparts despite not having the full range of cockpit sensors available in a full-scale sailplane. With recent advances in on-board instrumentation (e.g., speed, altitude, variometer..) and down links for RC sailplanes, pilots can now fly these like the full-scale sailplanes.
Joined Sep 2009
