Old Apr 01, 2011, 03:53 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Originally Posted by soarsimon View Post
Are people flying the stock prop? I've done a lot of searching in the different threads (tons of info in the "Parkflyers" thread too) and earlier everybody was going to the Graupner or Aeronaut props as a performance boost and as a way to not worry about exploding props. It seems that now with the new _1 prop that it's not much of an issue anymore. I'm waiting on a new prop and still flying the old one but considering an upgrade, should I just fly the new _1 and not worry?
I am flying the stock prop. Great climb!
The active discussions about changing the prop for climb performance were for the Radian Pro, not the Radian. The Pro is a different glider and the early batch of props were not shaped properly apparently.
aeajr is offline Find More Posts by aeajr
Old Apr 01, 2011, 04:53 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Originally Posted by Mcdyvie View Post
I have used it. It is a bit too heavy for my liking, but helps stabilize the plane on a really windy day.
Cool i will start out with a 3s 1000mAh then.how long do you reckon a 1000mAh will last me ? I know its hard to say
Kris... is offline Find More Posts by Kris...
Old Apr 01, 2011, 07:54 AM
jfflyer is offline
Find More Posts by jfflyer
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
4 or 5 climbs, assuming about 30 seconds full throttle and stock (_1) prop.
With the standard 1300 mAh you generally can count on 6 climbs.
jfflyer is offline Find More Posts by jfflyer
Old Apr 01, 2011, 09:03 AM
Pen is offline
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
I agree that the stock prop climbs great! ... but it was not quite enough to get me to 200m (656 ft) with a 30 sec motor burn for ALES competition. I was getting to about 550 feet in 30 seconds. I can get to 200m in about 25 secs with a graupner 11x8 though.
Pen is offline Find More Posts by Pen
Old Apr 01, 2011, 09:16 AM
jaksno is offline
Find More Posts by jaksno
jaksno's Avatar
Norwood, CO
Joined Jul 2009
Originally Posted by kaptondave View Post
I think you will have some problems if you try to wrap the wing saddle. Because of the shape it will be difficult to get the tape to lay flat and smooth so it will not be pretty, and it will not take much wrinkling to make it too tight. If you choose to use tape it is better to cut strips and lay them inside the wing cutout parallel with the center-line of the fuselage. The best tape is 3M/Scotch Extreme, which has a cross weave.
I used light fiberglas and epoxy on the inside top of the saddle: Snug fit for wings, light, strong.
jo
jaksno is offline Find More Posts by jaksno
Old Apr 01, 2011, 09:19 AM
Pen is offline
Pen
Pen
FPWhat?
Pen's Avatar
Joined Sep 2008
Hey Pen got any photos of your FPV Radian and some footage would love to see that
I'll post a new pic this evening. I attached an old pic but I've made a few changes since then to lose almost a pound.
Couple of vids here
Old Apr 01, 2011, 11:05 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
I have tried tape but have switched to a method similar to yours. I use light-weight (1.5 ounce) fiberglass cloth bedded in Minwax Polycrylic, which is water based. Polycrylic is probably not as strong as resin but is less messy and easier to clean up after.
kaptondave is offline Find More Posts by kaptondave
Old Apr 01, 2011, 12:04 PM
Mcdyvie is offline
Find More Posts by Mcdyvie
Mcdyvie's Avatar
Germany
Joined Jul 2009
Best way to tell is to get a wattmeter and take notes...i.e. throttle time, number of climbs, etc and check your battery after each run. Start low and move your way up...
I don't use the stock setup so I can't help you with that!
Here is my setup:
Upgraded Radian
Mcdyvie is offline Find More Posts by Mcdyvie
Old Apr 01, 2011, 12:13 PM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Here is my setup:
Upgraded Radian
Well that shouldn't be a problem with the DX8.
Old Apr 01, 2011, 01:11 PM
Mcdyvie is offline
Mcdyvie's Avatar
Germany
Joined Jul 2009
All the better!
Old Apr 01, 2011, 01:21 PM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
All the better!
Very very nice mate.... great channels by the way ! subbed.
Old Apr 01, 2011, 02:19 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
On the stock 1300 pack, with multiple climbs and some reserve capacity I usually get at least an hour of flying, sometimes more. With two packs and one battery charger you can stay up all day.
Old Apr 01, 2011, 02:43 PM
Mcdyvie is offline
Mcdyvie's Avatar
Germany
Joined Jul 2009
Old Apr 01, 2011, 03:17 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Couple of vids here
Wow! Does that actually fly?
Old Apr 01, 2011, 04:10 PM
Pen is offline
Pen
Pen
FPWhat?
Pen's Avatar
Joined Sep 2008
It flew for 12 minutes in that config with a GoPro added as well. I get an easy 15 minutes in this config which is about 0.9 lb lighter and more stream lined.
