Rhode Island
Joined Aug 2007
Question regarding 3 ch setup
Forgive the possibly stupid question but is the rudder usually assigned to the right stick on 3ch planes such as this one?
The only reason i ask is that the manual shows the rudder on the left stick of the DX5E. How is this plane set up out of the box? thanks |
Mahomet, Illinois
Joined Aug 2007
David Horizon |
Rhode Island
Joined Aug 2007
thanks for the reply. How much of a leap will it be to fly this if my RC flight experience is with the Blade CX2 and the Parkzone Vapor? Would you consider the Radian somewhat of a slowflyer? |
The day that video was recorded was april!!!!!!!!!!!!!!!!!!! How come we did not know about this plane in april. |
Mahomet, Illinois
Joined Aug 2007
The Radian does require a much larger flying area, however! For a beginner, think about an open area at least the size of a football field, preferrably two. It has an amazing L/D (glide ratio), especially if you're not used to flying sailplanes. It takes a little practice to master the energy management to make a spot landing. The good thing is that with rudder/elevator sailplanes, it's very relaxing. Things don't happen too fast, and they're usually fairly smooth. Many people have flown sailplanes as their first R/C aircraft, including me. Hope this helps, David |
Rhode Island
Joined Aug 2007
I am definitely leaning towards purchasing the Radian, Super Cub or SLO-V. The radio/electronics included with the Radian are a pretty big plus in it's favor for sure! I had a chance to see a friend's Super Cub in action today. Much faster than my Vapor!! I was wondering if the Radian flies at about SC speed or slower than the SC. Also is it faster or slower than the Slo-V? If a field is large enough for the SC or SLO-V, is it also large enough for the Radian? thank you |
USA, AZ, Chandler
Joined Nov 2007
[QUOTE=Dave EichstedtThe Radian does require a much larger flying area, however! For a beginner, think about an open area at least the size of a football field, preferrably two. It has an amazing L/D (glide ratio), especially if you're not used to flying sailplanes. It takes a little practice to master the energy management to make a spot landing. The good thing is that with rudder/elevator sailplanes, it's very relaxing. Things don't happen too fast, and they're usually fairly smooth.
Many people have flown sailplanes as their first R/C aircraft, including me. Hope this helps, David[/QUOTE] If this bird has a good L/D but no ailerons or spoilers, then it would really be tricky to land in a confined area. Better to decide to land w/ enough battery for a couple of go-arounds. Or do some really pronounced S-turns on final or gentle stalls if you are a risk-taker. I have encountered a lot of rising air bubbles on final to make any sailplane hard to land inside the same zip code. |
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
I guess a Dethermalizer (sp?) would be an obvious mod. Or parachute...
An easy way to slow down a 3 channel glider for landing is to turn the motor on, just a click or two. The folding prop will extend, but the motor won't be turning fast enough to push the plane (unless you have a rediculously over powered setup) and the larger the prop, the greater the "air brake" effect of the extended prop blades. When I need to get my 3 channel birds down quicker or out of lift, I'll deploy the prop to keep me from going too fast while I bleed off altitude.
On landing, be ready to shut the motor off and engage the esc brake, just before the plane touches the ground. JimNM |
I am impressed - Parkzone is definitely covering all of the bases for most pilots and doing a better job with each new release.
For a while I have been considering adding the MPX EGE to my fleet, but this has me curious enough to wait! Take care, Mike |
Latest blog entry: Video of the Fire Near Colorado Springs...
I am definetely interested in this model. I find myself flying my models higher and higher. I even fly my 3D plane to unreasonable heights. I am amazed at how much range i get from just an AR6100 and a DX7. I may get it around Christmas time. Having said that, do thermals occur in winter time?
