Old May 25, 2001, 08:28 AM
chris dodge is offline
Find More Posts by chris dodge
Amesbury, Ma.
Joined Dec 2000
Sig Riser 100
I just bought this kit.Is there anyone that has this plane and do you like the way it fly's?Is there anything that I should lookout for while building this kit and is there any modifications that I should make while building. Your help will be greatly appreciated. Thank you.
chris dodge is offline Find More Posts by chris dodge
Old May 26, 2001, 03:13 PM
Richard is offline
Find More Posts by Richard
Terre Haute, Indiana
Joined Nov 2000
I have a half built Riser that I am going to convert to e-power per conversion article in Feb 2001 S&E Modeler. The article mentioned watching out for heavy tail wood and sticky push rods. You may want to eliminate the overhanging rudder.
Richard is offline Find More Posts by Richard
Old Apr 07, 2008, 04:17 PM
stargazerww is offline
Find More Posts by stargazerww
Parkside PA.
Joined Mar 2008
there are a couple of builds going on in this forum just do a search of "riser 100" i will be starting mine this week oh and my glider riser 100 is very tail heavy so i will be lightening it up in this build when it comes to that
stargazerww is offline Find More Posts by stargazerww
Old Apr 07, 2008, 04:21 PM
quigley257 is offline
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
Excellent kit! Do a search for "riser 100". There is several builds going on right now in the forums. I have built two of them and still fly my second one. It is over 14 years old now and still flies great.
--quigley
quigley257 is offline Find More Posts by quigley257
Old Apr 07, 2008, 05:13 PM
CV580drvr is offline
Find More Posts by CV580drvr
Super Secret Agent
CV580drvr's Avatar
Sink City, USA
Joined Oct 2007
Hi Chris!
Riser? Never heard of it.
We're having a good time with some Riser 100 build threads here, so feel free to join on in with any comments/questions you might have.
CV
CV580drvr is offline Find More Posts by CV580drvr
Old Apr 07, 2008, 08:28 PM
jh2rc97 is offline
Find More Posts by jh2rc97
Dallas, TX
Joined Jan 2005
Here is the one I built about three years ago:
http://www.rcgroups.com/forums/showt...00#post3378143
Great plane to convert to e-powered. I had to add about 1/5 ozs to the tail to get the CG right. I found it to fly the best with the CG at the rear most recommended position.
Alan
jh2rc97 is offline Find More Posts by jh2rc97
Old Apr 08, 2008, 05:11 AM
Lockley is offline
Find More Posts by Lockley
KI4UBK
Lockley's Avatar
USA, NC, Old Fort
Joined Nov 2007
Do reinforce behind the TE, do the mod to the rudder and take a chair when you fly, you will be in the air for a while.
Lockley is offline Find More Posts by Lockley
Old Apr 08, 2008, 07:01 AM
jh2rc97 is offline
Dallas, TX
Joined Jan 2005
How does the rudder mod help?
Old Apr 08, 2008, 05:15 PM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
We can debate the rudder for eons,back in the day that the risers were drawn up,with the air foil used it was thought that the balanced rudder had more advantage because the balance area above and in front of the hinge line would help give more rudder effect in turns with elevator in put,and also give a very slight up elevator input to turns.All this aside-build as per plan,even for E power.and enjoy.If you do all sig says to do you still get a fine sailplane.For Me ill keep the counter balance on the rudder and just fly the thing.
rabidrue1 is offline Find More Posts by rabidrue1
Old Apr 09, 2008, 06:21 AM
tinkrerpilot is offline
Find More Posts by tinkrerpilot
tinkrerpilot's Avatar
Puyallup, WA
Joined Nov 2001
CD, Glad to hear you bought a model of wise decision. You will enjoy the build withthe guys here. Its a great bunch to chat and dicuss the build of the Riser. Any questions are usually answered with some details. The only ones that are not talked about are the one that you don't ask. We have fun with the build and with some of us that have been building for awhile learn something new too. So join in and have some fun. Make some new friends.
Here are the threads,
http://www.rcgroups.com/forums/showthread.php?t=838014
http://www.rcgroups.com/forums/showthread.php?t=844023
http://www.rcgroups.com/forums/showthread.php?t=825546
rabid, CV, stargazerww and the rest of the guys that have Riers soon to be flying or flying. Gentlemen, glad to have ya here with the threads. We are planning a one day Riser fly where we all go fly the Riser on the same day. Then post a picture of the day. All are welcome. As soon as we get Bob in the air with his we will put this together.
Regards,
tink
tinkrerpilot is offline Find More Posts by tinkrerpilot
Old Feb 03, 2015, 02:08 PM
ScienceGuyOrg is offline
Find More Posts by ScienceGuyOrg
Joined Mar 2011
I have the tail surfaces built on Sig Riser 100 and pushed out the ribs and fuselage parts. Some of the wing ribs are really hard balsa. Considering there is 1000 sq in. of wing should I be worried that some of the wing ribs are a little heavy?
Planning to put Go Pro in the fuselage.
ScienceGuyOrg is offline Find More Posts by ScienceGuyOrg
Old Feb 04, 2015, 04:56 AM
chawkins is offline
Find More Posts by chawkins
PBR Sailplane
chawkins's Avatar
United States, MI, Midland
Joined Jul 2012
When laying out the ribs for the wing I always weigh each rib and mark that number in pencil on the rib. Then I lay them out distributing the weight evenly across the span of the wing. And I always balance the wing prior to covering. I do this with every Riser and Sailplane I build. Easier to take a little wood off the heavy wing tip than add weight to the light end.
chawkins is offline Find More Posts by chawkins
Sig Riser 100 Rob Nelson Thermal 13 May 28, 2005 11:55 PM
Sig Riser 100 electric conversion John Gallagher Electric Sailplanes 9 Apr 07, 2004 11:17 PM
F/S: Sig Riser 100 Jim Carlton Aircraft - Sailplanes (FS/W) 2 Dec 24, 2002 12:32 AM
WTB NIB SIG Riser 100 J Bergsmith Aircraft - Electric - Airplanes (FS/W) 3 Apr 02, 2002 12:39 AM
Sig Riser 100 NIB soar-iowa Aircraft - Electric - Airplanes (FS/W) 0 Feb 12, 2002 09:09 AM
