Old Jan 25, 2012, 10:23 AM
Luke2000 is offline
Find More Posts by Luke2000
Ireland, Dublin, Dublin City
Joined Apr 2011
Hi (again) all,
Been busy with a Turnigy 9X flashed to ER9X - wow, it's impressive (Thanks wheelspinner)
I have a Polaris question about the CG.
I'm in the middle of a 133% or so Polaris (wingspan 39" as it's all I could get the printer to print after ages). I know it should balance around the step but I've tried right side up and upside down. In both cases, when I think it's balanced, I can tip it either fully forwards, or fully backwards. Does that mean the CG is right.
Another thing happened was I put the 2212-6 motor on a wattmeter and pull scales. Here's what I got:
6 x 4 130 watts 100g = .77g per w
7 x 4 297 watts 600g = 2.02 g per w
7 x 4.5E 310 watts 610g = 1.96 g per w
7 x 5 260 watts 650g = 2.5 g per w
7 x 5 230 watts (lwr v?) 22 amps 620g = 2.69g per w
I wouldn't have thought that this was possible from a motor that size? How are you all using a 6x4 prop when the output is so small?
Luke2000 is offline Find More Posts by Luke2000
Old Jan 25, 2012, 10:45 AM
lennyboy is offline
Find More Posts by lennyboy
lennyboy's Avatar
Joined Oct 2009
Originally Posted by Luke2000 View Post
Hi (again) all,
The watts per Gram is't so..
I beleive you'll find a 34Oz. Plane will fly really well with the recomenden motor and ESC..
Headsup rc .com has a 2200 kva motor and tested it with the proper prop and acheived ???? OZS. OF THRUST,,,,, much higher then your cart explains??
Look once as it has been how I figure to build a lot of of planes..
There are some loss with thrust due to prop size,,apc or plastice slow fly,, and weight< and .,,,
The amp draw will go up..
Just saying??
Later ,
Lenny
lennyboy is offline Find More Posts by lennyboy
Old Jan 25, 2012, 10:50 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It should balance AT the step or 1/4" ahead.
You can't determine CG by sitting the model on its bottom. I simply mark the step location on both sides of the fuselage above the wing and pick it up with finger and thumb. Find the location where it balances level (ignore any instructions that say it should balance slightly nose down -- to find the fore-and aft CG it must balance level). This will give you a good fix on the CG.
If you want more precise measurements (not needed) you can make a stand with two rounded dowels sticking up on which to balance the model. Balance will be the same upside down or right side up, but obviously it won't sit there stably upright as the CG is above the pivot point.
On the thrust measurement, there's something wrong with the numbers for the 6x4. An APC 6x4 should turn 18,500 to 19,000 RPM and pull 22-23A static and 20-21A in the air. This corresponds to around 220-230 watts. The thrust is about 28-35oz. Hence the excellent performance, including accelerating vertical climbs in the 100% Polaris. With the XL, you can expect more modest performance but still get a quick takeoff and 45 degree climb (as long as the model is a reasonable weight -- mine is 32oz with that motor and 2200 30C battery).
Not sure why your data for the 6x4 is way off. Is that a proper APC thin electric prop? You can't use slow flier props on these motors.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 25, 2012, 11:00 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by wijwoj View Post
Hey leo.geo,
I got my bits from giant cod here in the uk. They are very quick and good value. They have a motor which is pretty damn close to the one recommended by all here:
Motor - http://www.giantcod.co.uk/221206-220...-p-402397.html
Prop - http://www.giantcod.co.uk/6x4e-sport...-p-403325.html
Battery (30C could go for cheaper 20C if you want) - http://www.giantcod.co.uk/gens-2200-...-p-406466.html
ESC - http://www.giantcod.co.uk/hobbywing-...ller-p-42.html
Cheers,
Wij.
That motor looks like a good equivalent to the standard Suppo 2212-6. The ESC has a good reputation I've heard. For a standard size Polaris, I use a 20C 2200 battery as the 30C is getting pretty heavy. So it's not only cheaper but more suitable. Prop should be fine.
Old Jan 25, 2012, 11:13 AM
wijwoj is online now
Find More Posts by wijwoj
wijwoj's Avatar
United Kingdom, England, London
Joined May 2007
Ah right, thanks for the info Daedalus. I actually also have a 20C on mine, but saw that prices had gone down on all the bats so thought I would suggest a meatier one. Didn't realise that more C equals more weight, but that does make sense.
Leo.geo, here's a 20C one from giant cod:
http://www.giantcod.co.uk/gens-2200-...-p-407317.html
Cheers,
Wij.
wijwoj is online now Find More Posts by wijwoj
Old Jan 25, 2012, 11:27 AM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
luke....either your battery was dead or something like that OR maybe prop was on backwords?? d66 numbers have been repeated over and over within 5% or so on most of the posted standard setups. on a 3s 25c and up healthy battery. or maybe didnt have full throttle? not sure. since other prop numbers look in the ball park....im gonna go with backwords prop. ...
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Jan 25, 2012, 12:12 PM
Luke2000 is offline
Joined Apr 2011
It wasn't the battery as this was the first prop I tried. I'm gonna do that test again and see. Maybe the backward prop syndrome all right.
I have a CG setup with the dowels and all, but what I'm finding is that it won't actually stay balanced at all! If I move the battery to the point where it appears balanced, it will tip either slowly nose down and then keep going down, or tip slowly backwards and then keep going backwards. I guess it's balanced at that stage but I have around 10 airplanes, and never came across one yet that won't stay at the balance point.
Thanks all
Luke
Old Jan 25, 2012, 01:05 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
Thanks all
Luke
try balancing inverted
mt_flyer is offline Find More Posts by mt_flyer
Old Jan 25, 2012, 01:17 PM
Luke2000 is offline
Joined Apr 2011
I tried that. It's a bit better upside down, but still just won't stay put. I'll see.
Regarding the prop, I tried again.
6 x 4 same as 1st time 155watts 15A 360g
6 x 4e 155w 14.5A 370g
7 x 4e (different prop to st test) 170watts 16A 510g
Don't think that any of them are genuine APC props though. I think that the sled the motor is mounted to jammed on the first 6 x 4 test.
At around 32oz. I think it's gotta be the 7 x 4 prop. Any suggestions?
Luke
Old Jan 25, 2012, 01:32 PM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Thanks all
Luke
Correct, if it's moving slowly back or forwards it's OK. More precise is not needed.
It means that your vertical CG (or better: center of mass) is between your wings. Which is good! Your other planes may be high wing models?
mavlo77 is offline Find More Posts by mavlo77
Old Jan 25, 2012, 01:48 PM
bob93447 is online now
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
Polaris XL question
Is the Polaris XL pylon strong enough to support an 85 gram motor?
bob93447 is online now Find More Posts by bob93447
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thanks all
Luke
The backwards prop theory might explain things. What kind of prop was it?
Another possibility is that the ESC was not calibrated correctly for that run, so it wasn't reaching anywhere near full throttle.
Anyway, you don't need tests to determine whether it will fly. If things are set up right, the XL with 2212-6 at full throttle should have enough thrust to just about lift vertically out of your hands.
While batteries make a difference, there would have to be something seriously wrong with any 2200 (like a dead cell) to explain your numbers.
Re Balance
It doesn't need to stay balanced. What you describe simply shows that the vertical CG is above your balance point. Same thing always happens if you try to balance a low wing model right side up. But it doesn't matter (unless you let the model fall on the floor! )
All you are trying to do is find the longitudinal balance point. It's absolutely easy if you just pick up the Polaris by the fuselage with thumb and finger and find the point where it balances level. Takes about three seconds.
Having noted that the CG is too far forward, say, you move the battery back and try again. And so on till you have it right. Don't try moving the battery while balancing the model.
If you had no trouble balancing the others, they must be high wing models.
Old Jan 25, 2012, 01:50 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
That's about the standard size. Mine currently has a 100g motor on it. No problem at all, though the battery needs to move ahead slightly for balance.
Old Jan 25, 2012, 01:54 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Luke
All those numbers are too low. With a 7x4, for example, you'd expect to see well over 20A.
So forget about measuring thrust and figure out why your motor is not drawing enough current. Take a good look at the ESC to make sure it's properly calibrated.
Exactly what props, motor and ESC are you using?
Old Jan 25, 2012, 01:55 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Great minds think alike. I didn't see this before I commented!
