Old Sep 18, 2008, 10:55 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Hey BEC, you know you want to come over to the Dark Side Once a Foamie-guy, always a foamie-guy You'll wonder why you didn't start sooner
Gene Bond is offline Find More Posts by Gene Bond
Old Sep 18, 2008, 11:02 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Well, Gene...... I have two Blu-Babies flying now and have been working with some students who are going to be making their own planes from one of those bundles of PBIII from Lowes in Renton......
It has begun. But I still like laser-cut wood!
BEC is online now Find More Posts by BEC
Old Sep 18, 2008, 11:59 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Your spar design looks great, Pat. I never thought of using sq CF, good idea.
I do have a concern, though. The reason I put a swept spar on the horizontal is so that the spar would straddle across the width of the nacelle to provide good lateral support to the horizontal tail. It had to be swept to reach the wide part of the nacelle, as a straight spar misses almost all of it. Otherwise, I was concerned that the horiz tail may not have enough lateral support (remember this part sits directly in the prop blast so it takes a beating). Does it feel strong enough to you? If not, you might want to put some foam, balsa, or fiberglass bracing on the bottom at the intersection of the horiz and vert tail to strengthen it.
jetset44 is offline Find More Posts by jetset44
Old Sep 19, 2008, 12:00 AM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Gene - Yeah, I've been trying to convert Bernard to the dark foamy side for years, and it looks like he's taken the first baby step with his Blu-Babies. He's almost there...one more foamy and he'll be hooked!
Old Sep 19, 2008, 12:27 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Steve,
After messing around with it some tonight, I think you're right. I'll be adding CF sticks along the leading edges of the horizontal stab too for extra support.
I got the motor firewall installed and hooked up the wiring in preparation for finishing up the nacelle. Man am I glad I checked the motor one more time before closing it up. For some reason, my motor (brand new) now does not seem to want to run properly. I think that when I bent the wires back to put them through the firewall, one of them may have broken loose.
And just to check what was bad, I hooked my ESC to another motor, and it worked fine. I then hooked the suspect motor to another ESC, and it still did not work. It acts like it's off on the timing. I'll have top open it up and take a look.
In the meantime I'm pulling a motor from another plane that is down for repairs right now. I hope to be gluing everything together tomorrow night (I wanted to do it tonight, oh well).
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Sep 19, 2008, 12:13 PM
SWblade is offline
Find More Posts by SWblade
Joined Aug 2008
Great looking aircrraft.
Since I don't have my phlatprinter yet, I'm interested in a kit... do we know when the kit will be available?
Jason
SWblade is offline Find More Posts by SWblade
Old Sep 19, 2008, 12:44 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
That looks great, I keep thinking about a sea dart, maybe a ski-less version would work....
Frank
burkefj is offline Find More Posts by burkefj
Old Sep 19, 2008, 01:59 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Jason
Hard to say for sure, but I'd guess the kits will available in about a month.
Old Sep 19, 2008, 08:06 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
There were two versions of the sea dart , one had two skis , the other only had one , one was better than two .
lake flyer is offline Find More Posts by lake flyer
Old Sep 20, 2008, 01:14 AM
Tomas Dunker is offline
Find More Posts by Tomas Dunker
Tomas Dunker's Avatar
Sweden
Joined Mar 2006
Thank you Steve for excellent thread!
This sommer I tryed for the first time to fly from water. A BluBaby with floats, see movies:
http://www.tomasdunker.se/mfilm/blub...floats_HiQ.wmv
http://www.tomasdunker.se/mfilm/blub...loats2_hiq.wmv
My 2nd seaplane will absolutly be Polaris! Thank's Steve!
/Tomas Dunker
Sweden
Tomas Dunker is offline Find More Posts by Tomas Dunker
Old Sep 20, 2008, 01:29 AM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
You're welcome for the plans, Tomas. Post pics if you build a Polaris!
Hey, is that my VTO design in your avatar?
Steve
Old Sep 20, 2008, 09:07 AM
Sweden
Joined Mar 2006
Steve
Yes, thats right! VTO was my wery first Depron and brushless model.
Ċhh! So you are the designer!
Here some better picture on my VTO.
Old Sep 20, 2008, 12:50 PM
KaanX is offline
Find More Posts by KaanX
Türkiye
Joined Jun 2007
Steve, are the auxiliary ply spars really necessary? Your Gripen's wings are almost the same dimension, and it flew OK only with the 6mm main carbon spar.
KaanX is offline Find More Posts by KaanX
Old Sep 20, 2008, 01:01 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
KaanX,
I highly recommend them. I have noticed on my other depron profile planes that over time the leading edges start to warp, even with a main spar in place. Having these spars in should eliminate that.
Pat
Old Sep 20, 2008, 01:18 PM
KaanX is offline
Türkiye
Joined Jun 2007
My depron planes never last that long
OK, I won't be lazy and add them...
