Old Jan 04, 2009, 06:15 PM
Model Aero is offline
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
Beautiful work. That looks fantastic!
Scott
www.ModelAero.com
Model Aero is offline Find More Posts by Model Aero
Old Jan 05, 2009, 12:45 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Thanx SCott.
It's not quite a good as decals but ...
I had a lot of packing tape left over from a Sloper build that recommended the stuff.
It sticks on it's own but can be Mono-Iron'd to a better stick and even shrinks out
somewhat if you applied some wrinkles too :-)
Considering other excruciating methods of covering foamys I'm like'n tape
a lot lately.
birdofplay is offline Find More Posts by birdofplay
Old Jan 05, 2009, 03:51 PM
HurriHeli is offline
Find More Posts by HurriHeli
Old man in Sweden
HurriHeli's Avatar
Torshälla Sweden
Joined Feb 2008
Birdofplay, I love the colors it looks very nice, myself not much progress but recived the motor/ESC/servos/EZlinks UHUPoor today, I wonder if the motor is overkill 90grams with the prop spinner nut and mount (Turnigy C3530-1700), it fills up the narcell, but this is 120% so what do you think?
HurriHeli is offline Find More Posts by HurriHeli
Old Jan 06, 2009, 05:56 AM
wilco1967 is offline
Find More Posts by wilco1967
Winterswijk, Netherlands
Joined Jun 2007
Hurriheli
That Turnigy 3530-1700 will fly your Polaris fine....
I'm using the same motor on a 100% Polaris with a 7x6 APC prop (the hobbycity clone), and it flies great. It will pull close to 30 amps, so make sure your ESC is up to the task as it receives no cooling inside !
Good luck !
wilco1967 is offline Find More Posts by wilco1967
Old Jan 06, 2009, 08:07 AM
Old man in Sweden
HurriHeli's Avatar
Torshälla Sweden
Joined Feb 2008
Thanks, sounds very good, the ESC is Turnigy 40A so hope it´l work fine.
Edit: Same day so I continue here.
Done some on the motor mount today, intend to seal the hole with cables later, so if possible avoid water coming in if/when its laying up side down in the water . Mount of hinges/ailerons as well and of course I made three linkages while bending them, the first one without the plastic tube....
The included screws for mount the motor seems to be a little to long, maybe it´s only me but if not shortened one of them hit one of the cables pretty hard, it was exactly the same on my puddle twin motors, it´l work like it is I´m sure but for how long? sooner or later the screw will tear through the isolation on the cable..perhaps, see photo.
Old Jan 06, 2009, 04:11 PM
Petem is online now
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Shorten the screw!
I recommend shortening the screw, HurriHeli, or maybe a washer or two under the head till it clears the windings.
This exact problem cost me the smoke out of two ESCs before I figured out what was causing it!
Wisdom is expensive!
Peter
Petem is online now Find More Posts by Petem
Old Jan 06, 2009, 04:30 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Guys, I had the Same problem with other Hobby City motors.
In their defense I suppose it is hard to predict what thickness firewall and
hence what length of screw to provide. sigh ...
Hurri : that motor should make for Short takeoffs :-)))
Re maiden flight ...
Rain all day and for the next two days.
Local Govt just called everyone with Storm and Flood warnings
and potential Lack of emergency services due to heavy rains.
AKA if your low evacuate NOW !
Old Jan 07, 2009, 12:34 AM
Petem is online now
Petem's Avatar
Joined Jul 2008
Storm, heavy rain, flooding = ponds, lakes!?
Sounds like the land of endless watercraft possibilities!
Old Jan 07, 2009, 02:21 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
sketchanderase
If you are talking about the main wing of my 2X Polaris, it is 1/2" blue insulation not BlueCore or PBlll. My BlueCore and PBlll don't have much wave either because the place where I buy it let's me sort through the bundles and pick out the flattest ones I can find.
Steve or Scott
I just purchased the motor for my 2X Polaris. I got a Trungy 3548C with a 12x10 prop. Do you think this will be good? I still don't know what the AUW will be. My guess for air frame weight will be 3.5 to 4.5 lb.
Larry
Originally Posted by sketchanderase
Larryross,
how did you flatten out the blucor on yours? or is it not flattened but the angle it is at makes it look like it is......
larryross is offline Find More Posts by larryross
Old Jan 07, 2009, 03:41 PM
Old man in Sweden
HurriHeli's Avatar
Torshälla Sweden
Joined Feb 2008
Originally Posted by larryross
sketchanderase
Steve or Scott
Larry
Data about the 3548 below:
Kv: 900
Max Amp: 42 A
Pull: approx. 2 Kg @ 3-cell & 13x8 APC-E.
Measured: 630 W with 12x6 APC & 4 cell 2500 mAh!
Max Volt: 18.5 V (5s)
poles: 14
Weight: 163 g
Shaft: 4 mm
AUW model approx: 1200 - 2800 g.
It is a beast!
Old Jan 08, 2009, 03:01 PM
Old man in Sweden
HurriHeli's Avatar
Torshälla Sweden
Joined Feb 2008
Solder the motor cables, very heavy , make it possible to get out the solder joint just if I´ve to change motor (had to on my puddle) 16mm space to fuse with a 8" propeller, tricky with the cables below and the linkage to ailerons but it´l work, pic´s on that later...tomorrow maybe.
Old Jan 08, 2009, 03:30 PM
larryross's Avatar
Joined Dec 2007
Thanks... is this the results of your own test or did you find this data somewhere?
Kv: 900
Max Amp: 42 A
poles: 14
Weight: 163 g
Shaft: 4 mm
It is a beast!
Old Jan 08, 2009, 04:17 PM
Old man in Sweden
HurriHeli's Avatar
Torshälla Sweden
Joined Feb 2008
Found it at my LHS www.rcflight.se
Old Jan 08, 2009, 05:08 PM
Northwest Ohio
Joined Jan 2002
Polaris #2 is coming along well. The second one goes faster than the first.
This one is going to get the Polaris Transport decal set and will also go with me to the E-Fest next month in Illinois. It's gonna be exciting to fly her indoors!
Scott
www.ModelAero.com
Old Jan 08, 2009, 06:03 PM
flicka5 is offline
Find More Posts by flicka5
W. NY
Joined Jan 2002
Twinky
Ok,
flicka5 is offline Find More Posts by flicka5
