Old Oct 26, 2008, 02:06 PM
Adlerauge is offline
Find More Posts by Adlerauge
Joined Jan 2007
Good evening to you all !!
Just a motor question.
Last week I went to a Hobbystore to buy all the electronics.
There I show the construction guide and the tip to take a 240 watt motor.
Two people are looking with really big at me and say, "what, 240 watt ?"
They showed me a 240 watt motor and it was a really big motor and then they´ve given me this:
Magic-Torque 15-14 motor
Magic-Speed 18 controller
APC 7" x 4"
They told me something about 130 watt and that will be enough.
Please help, I´m so confused. What´s right and what´s wrong ????
Thomas
Adlerauge is offline Find More Posts by Adlerauge
Old Oct 26, 2008, 04:52 PM
Model Aero is offline
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
APC 7" x 4"
Thomas
Always trust the designer of the airplane over the hobby shop owner.
What Steve states in the construction guide is exactly what you want. I'm afraid 130 watts won't be enough. I would see about returning the motor and get what you need. Good luck.
PS-I do have the correct 2212-6 motor in stock but I encourage you to work it out with your local hobby shop.
Scott
www.ModelAero.com
Model Aero is offline Find More Posts by Model Aero
Old Oct 26, 2008, 05:46 PM
steven4601 is offline
Find More Posts by steven4601
steven4601's Avatar
the Netherlands
Joined Jul 2008
APC 7" x 4"
Thomas
try www.rctechnics.eu
they got the 2212-06 for 17 euro or so.
A 25Amp esc will do nicely with a 6x4 prop, gives 600 to 700 grams static.
steven4601 is offline Find More Posts by steven4601
Old Oct 26, 2008, 05:51 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Originally Posted by hoppy
Flew the plane yesterday and like you said, no issues with flight characteriestics. Flew true as built. I'm still working on landings as that nose up (ala SST's) attitude at slow speeds is a little strange to me. Got to get the tail on the ground before chopping the throttle or come in fast and have it slide quite aways. Overall, I'm quite pleased with it and many thanks again for the plans.
Glad you like it! Yes, this model takes a lot longer to slow down than any of my park jets or sport RC models, due to it's very low drag airframe (no flow-through inlets!) and small prop diameter (very little airbrake effect). Thus, I have to think ahead when landing it and chop the throttle way earlier than I'm used to. To get that great nose-high landing attitude, you have to add a little power immediately after it slows down. Then you hold lots of back stick to keep the nose up and use power to control the rate of descent. Done right, you can drag the rudder through the water while the rest of the airplane is still up in the air! Great fun. It takes quite a bit of power to maintain level flight once the nose is really high, and it also makes some weird sounds as pockets of separated airflow from the nose and wing go through the prop. Doesn't hurt anything, but sure gets your attention!
Steve
jetset44 is offline Find More Posts by jetset44
Old Oct 26, 2008, 05:57 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Thomas
I love Scott's comment on this ("Always trust the designer of the airplane over the hobby shop owner")!
Scott's right--you need more power than 130 Watts for this model. It may fly with that motor, but will struggle to get off the water and will just be lethargic when cruising around. And aerobatics will be out of the question. One of the keys to the really spectacular performance of this model is the very high power loading (combined with a very low wing loading). And since the recommended power setup is so inexpensive, there's really no reason to skimp. The 2212-06 motor is easily available pretty much worldwide, so I'd recommend just ordering one by mail if you can't get it locally.
Steve
Old Oct 26, 2008, 06:17 PM
Joined Jan 2007
Hey guys !
Thank you so much for your friendly help.
I´ll see how to get the right electronics this week.
Thomas
Old Oct 26, 2008, 06:33 PM
rclarkeingg is offline
Find More Posts by rclarkeingg
Watts up
rclarkeingg's Avatar
Orange County, California
Joined Apr 2007
Just built this plane---Unbelievable---
And out of blu-core and white gorilla Glue.
Weight so far 17 1/4 oz
With the 2212/6 motor this plane is has the power.
Just finishing up a few details like the CG and hope to get it in the air soon.
rclarkeingg is offline Find More Posts by rclarkeingg
Old Oct 26, 2008, 07:04 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
I love it! A living room floor demonstration. I want see some video of it taxiing around in your living room next. If you hold a little down elevator to the lift the tail and then give it some rudder with a little throttle, it should pivot pretty easily in your living room...
Old Oct 26, 2008, 08:52 PM
TPfingston is offline
Find More Posts by TPfingston
Retired and Lovin' it!
TPfingston's Avatar
United States, KY, Sturgis
Joined Jul 2007
I'm really glad to see some other guys building this plane. I really love the way it flies.
Tony
TPfingston is offline Find More Posts by TPfingston
Old Oct 27, 2008, 12:52 AM
wilco1967 is offline
Find More Posts by wilco1967
Winterswijk, Netherlands
Joined Jun 2007
Spectrum receiver waterproofing
Got a question one on you Polaris flyers might know.
I'm flying with 35 MHz equipment at the moment, but have a lot of trouble with glitching (not just with the polaris, but with many planes), so want to upgrade to a Spectrum system.
I've been reading a lot of people waterproof their receivers with corrosion-X (or similar)
Anyone used this on Spectrum receivers ?
I'm thinking the 2.4 GHz might be more sensitive for any coatings (like corrosion-X) on the electronics then a normal 35 (or 72) MHz system.
Regards,
Wilco
wilco1967 is offline Find More Posts by wilco1967
Old Oct 27, 2008, 01:07 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
I use CorrosionX on both my AR6100s and my AR7000 Spektrum receivers. They work great even after dunking in the water several times. Saturate the inside of the receivers with CorrosionX and then let them drain on a paper towel overnight.
Mike McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Oct 28, 2008, 11:15 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Kits are almost done!
I'm happy to announce that kits for the Polaris are just about done and should be available very soon. The vendor will be Model Aero, who's a big sponsor of RCGroups and already produces a great line of innovative high-performance foam aircraft. Here's a link to the Polaris page on their website:
http://modelaero.com/Merchant5/merch...tegory_Code=AM
I was excited to work with Scott at Model Aero (known as galloping ghost here on RCG) to develop this kit. It was clear to me from the beginning that Scott is laser-focused on satisfying his customers, and he and I worked together to make several improvements to the Polaris design to make it even easier and quicker to build--without sacrificing any performance. I think folks will be very happy with the result.
More details will be available soon!
Steve
Old Oct 28, 2008, 11:39 PM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Great news Steve!! Cool!
And I for one really like the Coast Guard looking scheme!
Bajora is online now Find More Posts by Bajora
Old Oct 29, 2008, 07:26 AM
darkseacret is offline
Find More Posts by darkseacret
Wilmington, N.C.
very nice C. G.color scheme
darkseacret is offline Find More Posts by darkseacret
Old Oct 29, 2008, 11:18 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Steve
That's fantastic and the price is great too. Even my colors.
larryross is offline Find More Posts by larryross
