Old Feb 16, 2013, 04:36 PM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
No its because It was my maiden flight and i was affraid to increase lot throttle. The second reason is the ground, it was really very sticky. At the end of the session I taked off half shortly
Bledi is offline Find More Posts by Bledi
Old Feb 16, 2013, 04:56 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Originally Posted by Andreotti View Post
I had the maiden flight today of my new build baby Polaris:
http://www.youtube.com/watch?v=watRCY9IUGI
Motor: 2200kv (16gr, 8A)
Lipo: 450mA 3S
Prop: 5x2.75
Wingspan: 50cm
Flying weight: 232 gram
Nice one
Like seeingeyegod said it's a quick little bugger but at one point it looked like you got it slowed down pretty well. Good work
Aviefly is offline Find More Posts by Aviefly
Old Feb 16, 2013, 07:22 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Originally Posted by seeingeyegod View Post
It does look underpowered on the ground but in the air it doesn't look nose heavy at all, nose stays up in turns. I wonder if the kfm2 makes it take longer to take off, or maybe its not getting quite full power from the motor? Reminds me of the takeoffs of my first polaris with a half broken motor that was only pulling around 18A
He stated "my motor is the brushless of AXN floater plane." That is a 180w motor, so his build won't have the performance achieved with the motors typically used for this size.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 16, 2013, 09:48 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Votes on whether or not to salvage this?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 16, 2013, 10:12 PM
superrcflier is offline
Find More Posts by superrcflier
Canada, AB, Champion
Joined Aug 2012
Originally Posted by Bledi View Post
The weight is 640g with a 2200mah 50C (170g)
Nice one Bledi.
My first polaris use same motor and prop, 600g with 1300mah (112g), almost same weight if use same battery, this motor has more than enough thrust for the weight, so short take off won't be issue.
superrcflier is offline Find More Posts by superrcflier
Old Feb 16, 2013, 10:22 PM
rayonnair is online now
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Noooooo cobralaris RIP
rayonnair is online now Find More Posts by rayonnair
Old Feb 16, 2013, 10:36 PM
It really took a beating I know . Both wings fronts separated from fuse, right wing carbon spar is partially visible like a bone sticking out of a wound . Kinda amazing that the nose didn't crush at all though, just broke off. I really don't feel like making a new nose, and redoing the paint. Mehhhhhh. There is a chunk missing out of the vertical fin too I realize now that I've tried piecing them back together. I think it is worth fixing though. Just hope it can be reasonably straight. Hopefully will have the onboard video available to post in about a week, guy who's keychain cam I had borrowed said it came out really well
Old Feb 17, 2013, 03:36 AM
Lockey is offline
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Looks like its repairable to me I have repaired planes in a lot worse condition than that one.
Looks like a fairly clean break at the front and I am sure the rest will glue back together OK
My vote is: YES
Lockey
Lockey is offline Find More Posts by Lockey
Old Feb 17, 2013, 06:34 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I would fix it. Anything that's broken and not crushed can be glued back together. As for straight, that's up to you.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 17, 2013, 08:20 AM
JugglerMike is offline
Find More Posts by JugglerMike
JugglerMike's Avatar
Fond du Lac, Wisconsin USA
Joined Dec 2007
Here's what happens when you get so caught up in flying this beautiful bird that you lose track of your surroundings - A tree will jump out in front of you and do THIS!!!
For those of you new to this game, this crash is not as bad as it seems. One on the beauties of Depron is that you can pretty much just put the pieces back together, glue it up, and be back in the air.
Thanks to the many great design attributes of this plane, NONE of the control or power components were lost. Just a few hours of glue and paint and she'll be good as new (plus a little extra weight - we all tend to gain a little weight and battle scars as we age!! )
I'll post a pic when she is back together again...
I have had a number of bad crashes with this model and am amazed at how it can be repaired and flown again and again... My vote is to repair!
JugglerMike is offline Find More Posts by JugglerMike
Old Feb 17, 2013, 10:35 AM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
some pictures of the day
Old Feb 17, 2013, 10:55 AM
flybyjohn is offline
Find More Posts by flybyjohn
Joined Oct 2010
I rebuilt my original polaris and although it still flies, it does not fly great. I built a new one and the lighter one flies more than great. I can't remember if your cobralaris was a little on the heavy side to start with, but if it was, I would start a new one and work hard to keep it light. Since I got my new lighter polaris built, I have not even taken my heavier rebuilt one up in the air. It never hurts to keep the old one around for an alternate one if ever needed.
flybyjohn is offline Find More Posts by flybyjohn
Old Feb 17, 2013, 11:17 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It all depends on how you repair it. If you are careful, use just enough glue and resist the temptation to add all sorts of reinforcement, you can repair with very little weight gain.
Old Feb 17, 2013, 11:29 AM
poweredlawndart is offline
Find More Posts by poweredlawndart
Joined Aug 2004
"A mere flesh wound............"
One more vote to rebuild.....
poweredlawndart is offline Find More Posts by poweredlawndart
Old Feb 17, 2013, 01:56 PM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
a small video onboard for the second day of my Polaris.
As you can see the takeoff is really shortest as yesterday
Polaris Seaplane : 2min onboard (1 min 44 sec)
