Old Feb 14, 2013, 08:15 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by nickchud View Post
Wow! That's amazing. I wonder if it's possible to do that with UHU Por. I must give it a try.
Elevon hinges are so very mission critical, I think I would still want something reassuring like tape across the join.
You could do the Foam Tac hinge and then add tape on just the top surface for peace of mind.
Something else I've seen is smearing a very thin layer of Foam Tac on the Depron to improve the bonding of the Blenderm. The glue is allowed to dry before the tape is applied. I've tried this on a small section where the tape had come loose. So far, so good.
Daedalus66 is online now Find More Posts by Daedalus66
Old Feb 14, 2013, 08:26 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by 042joasva View Post
Time for maiden this weekend .
How much throws should it have?
Attachment 5535762
HIGH RATE
Elevator 0.75" = 20mm
Aileron 0.75" = 20mm
Rudder 1.25" = 30mm
LOW RATE
Elevator 0.5" = 13mm
Aileron 0.5" = 13mm
Rudder 1.0" = 25mm
Use low rate initially.
(These are throws in each direction.)
Make sure the CG is on the step or very slightly ahead.
Good luck!
Old Feb 14, 2013, 10:30 AM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by G550Ted View Post
#41!?
Is there a 10 step program for this affliction?
Ted
Thankfully NO!
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Feb 14, 2013, 05:51 PM
flybyjohn is offline
Find More Posts by flybyjohn
Joined Oct 2010
I learned a valuable lesson today and luckily I still have my polaris in one piece. Here is the short of what I learned.
Flying off water = good
Flying off snow = good
Flying off snow & water = BAD
Here is the long of what I learned. I saw that the lake had opened up on the end that had a dock and there was a really nice level snow covered lake about 60 feet out so since I haven't been able to ROW with my polaris yet, I thought " what a great time to try". WRONG. The initial take off from water seemed good. Not as quick as grass or snow but still good. I landed on the snow covered lake and then jumped into the water and took off again. I continued to play the game of landing and taking off on multiple surfaces when all of a sudden turns became really sluggish and at times it would get stuck in a bank and would not pull out. I assumed the correct reason which was frozen control surfaces. I landed just barely and notice big ice chunks built up around the ailerons. I cleaned it off as best as I could and then just stayed on the snow covered lake after that. It was just about freezing temps and I did not want to take a chance of freezing up the control surfaces again.
I guess I will have to just wait another month to run on the water.
flybyjohn is offline Find More Posts by flybyjohn
Old Feb 14, 2013, 08:19 PM
meanbaby is offline
Find More Posts by meanbaby
meanbaby's Avatar
United States, PA, Mt Pocono
Joined Jul 2007
of all the foam tac control surfaces i done, none has seperated yet(knock on wood)
but ya like they say, add a small strip of tape of some sort to keep yourself safer
-pete
meanbaby is offline Find More Posts by meanbaby
meanbaby is offline
meanbaby's Avatar
Joined Jul 2007
#41!?
Ted
i agree with King here, i hope not also
-pete
Old Feb 14, 2013, 09:10 PM
Ramblin is offline
Find More Posts by Ramblin
Canada, ON, Carleton Place
Joined Jun 2011
I'd replace that with a one-liner:
Flying off water when air temperature is below freezing = BAD
I discovered this last fall before the lake froze, and fortunately I also landed safely.
Ramblin is offline Find More Posts by Ramblin
Old Feb 15, 2013, 05:23 PM
kadil is offline
Find More Posts by kadil
unconventional :-)
kadil's Avatar
Brisbane north, Australia
Joined Feb 2009
Corrosion resistant control rods
In my ambitious but extraordinarily slow and unconventional polaris build that I am perusing, I am trying to make it durable in a very salty environment. So weeks ago I set forth to buy some stainless steel tig welding rods, but all the local suppliers only stocked bulk quantities. I looked at ebay and there were options, but I had no idea if the metal would be soft or brittle, then the idea dawned on while walking through a discount store. I came across a stainless steel egg whisk. I extracted the wire, places a test piece in salt water and let it evaporate over a week. Not a sign of rust.
$4 for 8 strands, rigid, non-corrosive, non-brittle control rods. Same thickness as my regular wire. Readily available. Nice!
Hope that helps others.
kadil is offline Find More Posts by kadil
Old Feb 15, 2013, 05:56 PM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
Well done mate. Are these for linkages, torque tubes or both? What other kadilations are you doing on this build?
Aus is offline Find More Posts by Aus
Old Feb 15, 2013, 07:46 PM
superrcflier is offline
Find More Posts by superrcflier
Canada, AB, Champion
Joined Aug 2012
I've been using whisk for my pushrods, I buy 3 in one package (S,M,L) only a $1.25 from local dollar store, cheaply made but perfect for pushrods, I did try expensive one before from walmart but it was very hard to bend.
superrcflier is offline Find More Posts by superrcflier
Old Feb 15, 2013, 07:51 PM
Joined Aug 2012
Originally Posted by Bledi View Post
Ok 2 days before the maiden flight.
For information I made 2 layer of varnishing. The protection looks very good
Looks great, good to see others use KFM2 like I do.
Old Feb 15, 2013, 07:52 PM
meanbaby is offline
meanbaby's Avatar
Joined Jul 2007
what a bout bike spikes??
they should be weather proof, like these? http://www.ebay.com/itm/SAPIM-Bicycl...item27cfae184a
2mm diameter, fits the 2mm ez connectors and about 10-11inch long
here in nyc theres tons of bike wheels laying around, just cut em off!
and one end has a 90* bend and its capped, 1 less ez connectors to use
-pete
Old Feb 15, 2013, 07:53 PM
Joined Aug 2012
The EPP- plane is totaly covered with laminating film used for paper lamination. It is ironed on with a normal iron set to 120 degres celcius. There is also some packing tape in some places for reinforcement. Some areas were not possible to cover and they are varnished. It makes it a litle heavy but very strong. It will bee interesting to see if it is waterprof enough. First flights will bee on snow.
Attachment 5535762
Looking nice, good luck on maiden, such a great flyer.
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Brilliant!
Great idea guys for corrosion free push rods!
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 15, 2013, 09:38 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
-pete
2mm is pretty thick and heavy for this job. I generally use .047" wire, which is about 1.2mm and about 1/3 the weight.
I like the kitchen sourcing idea. Anything fit to use in the kitchen should stand up to salt water.
