Old Feb 03, 2013, 01:28 AM
superrcflier is offline
Find More Posts by superrcflier
Canada, AB, Champion
Joined Aug 2012
Polaris XL nearly finish.
Waiting for motor and esc
superrcflier is offline Find More Posts by superrcflier
Old Feb 03, 2013, 07:47 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by cmaynex View Post
Thank you for the responses. I am not sure I want to sand it for fear I might take off to much or some how fudge it. So I think I may leave it square. Seeingeyegod you say trim tape and I have heard others mention it but what is it exactly? I have some Scotch extreme tape I used to reinforce my CTH wings and it works well and also lighter than most tape from what I heard.
It will fly fine if you leave things square, but I like the more finished look of rounded leading edges and top corners of the fuselage (I often leave the trailing edges square). It's easy enough to do with a sanding block and fine paper (150 or so). Don't try sanding "freehand" with unsupported paper, as that's a recipe for uneven work. Just practice a bit on some scrap.
As for the tape, it's not trim tape but 2" colored packaging tape like this:
http://www.fast-pack.com/colored_tape.html
Also known in the RC world as Zagi Tape from its use to cover such wings.
I generally use it to improve the visibility in the air, as you can see in my avatar.
To stick well it needs to be ironed on, but go easy on the temperature, as you don't want too much shrinking. One nice thing is that if you don't like the results, you can just strip it off and try again.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 03, 2013, 05:12 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I like this stuff http://www.monokote.com/trim.html
Those are the colors it comes in, the checkerboard patterns are ridiculous time savers if you want that pattern. More expensive than tape obviously and mainly for the fact that it matches monokote colors but I really like the texture of it and it sticks to depron well, no ironing needed..
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 04, 2013, 12:34 AM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Thank you again guys. I now understand and I use this tape for visibility http://myworld.ebay.com/paperstreetplastics/, it looks to be similar. D66 I think I know now what you mean by strengthening the bottom fuselage. I did not have the last pieces installed, the ones that connect the bottom fuselage near the bottom of the nacelle.
cmaynex is offline Find More Posts by cmaynex
Old Feb 04, 2013, 07:33 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The best colors for visibility are black and white. Fluorescent orange also works well. Many of the decorative tapes look good close up but simply disappear at a distance when you really need help with orientation. Bold distinctions are what is needed, with strips being around 2" wide or more.
For protecting the front bottom against damage, the best choices are plastic sheet (the sort of stuff that's used for file folders, etc.or certain kinds of duct tape. My preference is the Scotch Tough Transparent Duct Tape, which is easy to work with, innocuous and slippery.
Old Feb 05, 2013, 12:27 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
quick scratchbuild question
is the centerpiece of the fin hollowed out from the front of it in the inside to allow esc and servo wires access before nacelle if sealed up?
grfcon is offline Find More Posts by grfcon
Old Feb 05, 2013, 12:48 PM
flybyjohn is offline
Find More Posts by flybyjohn
Joined Oct 2010
I am not sure exactly what you are asking but I think it has to do with how the channel in the vertical stab is formed. If this is the case then here is the answer. The lower vertical stabilizer has 4 parts, 1. front center section, 2. rear center scection and 3. and 4. are outside side sections. The front center and rear center are separated by the channel width, and the sides sandwich these two peices creating a channel. I run my wires in the channel after all the pieces are assembled but before I glue it to the wing. It is easier for me to get the wires in the channel this way.
flybyjohn is offline Find More Posts by flybyjohn
Old Feb 05, 2013, 03:16 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just take a look at the manual:
http://modelaero.com/pdf/Model%20Aer...on%20Guide.pdf
There are very clear pictures. You'll see that the fin has three layers and that the center layer is in two parts, thus creating a channel for the motor wires and elevator cable.
Old Feb 05, 2013, 04:14 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks.. sillly question I know.. I think because my whole scratchbuild is two pieces of elmers board glued together I initially freaked out as most of the nacelle space goes away inside once you glue both sides on.
Old Feb 05, 2013, 09:06 PM
Rotatto is offline
Find More Posts by Rotatto
Nanaimo BC Canada
Canada, BC, Nanaimo
Joined Sep 2007
My Latest Polaris
Built first Polaris over a year ago, flew it on water, in parks, hung it high in a tree on a friends farm and he used a shotgun to get it down and it has been one of my favourites. But alas,one day a servo let go and it was quickly reduced to shipping popcorn. Just had to have another so i thought i would share this one as requested by Jetsett, and thanks for your excellent interpretation of the Northstar.
I decided to glass the entire thing, as i've done with my Chara designed H29, which has stood up to hard flying extremely well.
I use 3/4 oz cloth for most of the hull, with the exception of the hull which is built up with drywall sticky tape on the bottom and a layer of 2 oz over it.
For epoxy i'm using Ecopoxy with med hardener and i'm very carefull to squeegee off any excess as i don't have bagging equip- yet.
AUW with a 2200 3 cell is 875 gms, or just over 31 oz, yes heavy but this design can handle it, and i like to fly in windy conditions.
For power i picked an NTM 2836 -1800kv, 40 amp esc, and with an aggressive 7x6 e prop it is pulling 339 watts at 11.1 v at full throttle.
I also fitted a JXF 7x6 and got 282 watts at 11.27
Sooo, that will give me about 175 watts/lb. which should make me giggle.
Used a 13 gm digital metal gear servo for the ailerons, and 9 gm analog for the rudder and elev.
Just for fun i bent up a cambered full length canopy with openings front and rear for cooling. just a bit of velcro holds the rear down. I installed all servos, except the elevator, accessable in the tray, and this is first time using control cables in sleeves.
Going to maiden it tomorro.
Rotatto is offline Find More Posts by Rotatto
Old Feb 05, 2013, 10:23 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Nice work, Rottato! That's one stout Polaris! Looks like it will be a screamer indeed.
jetset44 is offline Find More Posts by jetset44
Old Feb 06, 2013, 12:59 AM
Rotatto is offline
Nanaimo BC Canada
Canada, BC, Nanaimo
Joined Sep 2007
Thanks! I will report back with flight results, i'm hoping for 70mph plus and the usual smooth flight qualities. I especially like flying on and off water, i just love the look of this model off water.
Thanks again!
Old Feb 06, 2013, 03:36 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Nice work Rotatto some interesting ideas there. I used control cable in sleeves too, in my case it was any tube I could lay my hands on with 1mm carbon fibre rods inside. I sunk the aileron ones into the wing which meant I had to sink the aileron servos down a little to line up with them where they came into the fuse. I did both the rudder and the elevator too, these took a little bit of work and experimentation to get them running free enough with no slop but I got there in the end.
Is it an optical thing or is the upper vert stab shown in your second picture a little off line?
Also your rudder set up appears to have a lot of unsupported rod or cable at both the rudder and servo end. I'm sure you've tested it for slop and flex but if your planning on 70mph plus you want to be sure it's not going to flutter.
Love the hatch idea that is a work of art. Keep us informed and good luck with the maiden, hope you have a video camera on the ready too. I'm sure it will fly fine at that weight for what you want it for though might not be as good at the high alfa stuff. I think you've just taken my title for the fattylarus, mine came in at 763g with 2200 3s pack
Aviefly is offline Find More Posts by Aviefly
Old Feb 06, 2013, 03:55 AM
nrg2go is offline
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
Yeh, nicely done Rotatto. I'm sorry what did you call her, Porkalaris was it?
nrg2go is offline Find More Posts by nrg2go
Old Feb 06, 2013, 06:03 AM
pmisuinas is offline
Find More Posts by pmisuinas
United States, VA, Springfield
Joined Feb 2000
Next time just for grins, after squeegee effort, go over it with a roll of toilet paper and see if you soak up any more. Just be sure to roll it the correct direction--lol. As it picks up excess epoxy, tear it off and roll some more. Pretty sure this will get you down to the absolute minimum expoxy...Pete M
pmisuinas is offline Find More Posts by pmisuinas
