Old Sep 12, 2012, 10:33 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by choochoo22 View Post
With a kv that low, wouldn't it be feasible to use a 4s battery? This could cause an issue with the bec but it should get the rpm back into 6x4 range.
On 4s, a 1300 KV motor becomes like a about a 1700 KV on 3s in terms of prop speed. Not quite enough for best performance on a 6x4 but might be OK with 6x4x3 or 6x5.
You need an ESC that can do 4s. In particular, the BEC needs to be able to drive 3 servos at 4s -- something most won't do reliably.
You also need a slightly unusual battery. Not too many people have say 4s 1500.
So the answer is that you could do 4s with the 1300 motor, but it's probably more trouble and expense than just using the standard 2200 KV motor. It's these sorts of considerations that made me say there's no practical way to do it.
By the way, I flew the XL with a 1500 motor on a 4s 2200. I had to reduce the prop from the usual 8x6x3 to 7x6x2. It worked OK but I returned to 3s as there was no real advantage and I only had two batteries.
Daedalus66 is offline Find More Posts by Daedalus66
Old Sep 13, 2012, 10:37 PM
bob93447 is online now
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
New "Duck" tape
My local Home Depot in SoCal started to carry black and white Checkerboard "Duck" tape a few months ago. Since I finally wore out the back tape on the wingtip floats, I finally decided to buy some and try it out. While I was at it I did the hull too as I am always looking for enhanced visibility.
Bob
bob93447 is online now Find More Posts by bob93447
Old Sep 14, 2012, 02:40 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Started making the engine nacelle last night and melted some of the foam with my heat gun trying to make the bend in it Trying to decide whether to just live with it or make a new nacelle piece.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Sep 14, 2012, 03:25 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I'd make a new one if its really bad. If not then go with it. I broke a side piece of my nacelle trying to bend it. Just glued it with some CA and it worked out fine. It all comes down to personal choice and does it look and perform right.
Tom
carr52 is offline Find More Posts by carr52
Old Sep 14, 2012, 05:13 PM
Texas Buzzard is offline
Find More Posts by Texas Buzzard
Texas Buzzard
Texas Buzzard's Avatar
McAllen,Texas
Joined Mar 2004
3 Year old Polaris
Jetset44 gave us a great plane in the "Polaris"
I have built three over a 3 year period. I takeoff the grass and can fly in winds up to 14 mph.
The motor is a 2812-06 w/ a 6 x 4 prop. Am using a 1200 mAh 3S Lipo.
Texas Buzzard is offline Find More Posts by Texas Buzzard
Old Sep 14, 2012, 05:23 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It looks as though you did the motor mount and some other things differently. Maybe you could explain a bit.
Old Sep 14, 2012, 05:57 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Yes, I looked for the familiar nacelle, and didnt see it (a word I never heard of untill about 3 months ago, lol. Lots of new words in this aviation hobby, alot I have heard, but never knew what exactly they meant.)
stuball56 is offline Find More Posts by stuball56
Old Sep 14, 2012, 06:17 PM
aldalo is offline
Find More Posts by aldalo
It Flys Me
aldalo's Avatar
United States, PA, Washington
Joined Jun 2012
Revised Nacelle Design
On the pdf of revised nacelle , it has a horizontal tail . Do I need this or can
I use the old one ?
Thanks, Alan
aldalo is offline Find More Posts by aldalo
Old Sep 14, 2012, 08:58 PM
Ramblin is offline
Find More Posts by Ramblin
Canada, ON, Carleton Place
Joined Jun 2011
The easiest way to bend Depron is to put masking tape on the outside of the bend. This causes the inside to compress without stressing the outside.
Ramblin is offline Find More Posts by Ramblin
Old Sep 14, 2012, 10:15 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by aldalo View Post
On the pdf of revised nacelle , it has a horizontal tail . Do I need this or can I use the old one ?
Thanks, Alan
Not sure what you are asking. The horizontal tail is not optional on either the original or the revised nacelle.
I would advise following the later design, as it was revised for a reason.
Old Sep 14, 2012, 11:13 PM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
Polarii-Palooza
We were able to gather nine Polarii together this morning for a great mornings flying. Nrg2go, Ghost who walks, Mikejo_au and myself enjoyed near perfect conditions draining many batteries.
Who else has been flying?
Aus.
Aus is offline Find More Posts by Aus
Old Sep 15, 2012, 12:59 AM
rayonnair is online now
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Aus.
Me! The other pilot's Polarii are "coming soon" so it was just me and the hatcam.
Hatcam footage is hard though. All my flight vids were unusable, the plane being too small to see. So all you get is a video of take offs, landings, and what I generously like to call touch-and-goes. Half of it is twitchy because I was on 100% throws and no expo, and I couldn't figure out why the Polaris was so twitchy... If you squint you can see bubbles where turtles are startled into hiding when I get close.
Steve Shumate Polaris Hatcam 15.09.12 (5 min 16 sec)
I need to get a hatcam with a better lens or something.
The 1800mah nanotechs and 2200mah zippy compacts were perfect. I should not have used the 2250mah high discharge nanotechs for this bird, they were too heavy. 6-7 min gentle flying and you land at storage charge .
Aus, you must post vids! The big Polaris with the jagged leading edge and what looks like dihedral at the end looks interesting to fly, as does the tiny one in front.
rayonnair is online now Find More Posts by rayonnair
Old Sep 15, 2012, 01:33 AM
Aus is offline
Aus
Aus
Aus's Avatar
Joined Jul 2011
I didn't take any video today - too busy flying .
The two planes you refer to are by 'Ghost who walks'. I'll leave it to him to elaborate further. I'm sure he'll post something later tonight.
Glad to see your flight was successful. How did you find the orientation?
Old Sep 15, 2012, 02:35 AM
rayonnair's Avatar
Joined Jun 2012
Not great, but not as bad as I thought it would be. I do have a colour plan, I just have to get to it done. Once I complete something that can fly I usually just want to fly it.
I feel like the Polaris is made for the water. I did a "slam and go" on the grass earlier this morning. Quite hilarious.
Old Sep 15, 2012, 03:05 AM
Aus is offline
Aus
Aus
Aus's Avatar
Joined Jul 2011
Until you get to apply your color scheme of choice, I recommend you apply some color packing tape before you next fly. This can easily be removed before you apply your final finish. I agree with you, the fun factor is greatly amplified when on the water.
