All you need to do, though, is to set up the elevator on low rate so it has about 1/2" throw each way. That should be ample for good control and will give you a chance to find out how much throw is needed for the kind of flying you want to do. With the change in size and angles, you may find that the model needs a bit of elevator trim to fly level, so be ready for this on your first flight. Be careful to set up the ailerons with moderate throw. About 1/2" is plenty for low rate. Use 30% or so expo on A and E. Rudder is not critical, so use an inch or so, but it helps to have expo to reduce sensitivity around neutral for steering during takeoff. Make sure the CG is on the step or no more than about 1/4" ahead. It's a very nice looking model, so be careful till you have things sorted out. Best of luck. We're expecting flight pictures. |
Latest blog entry: Polaris Aileron Pushrods
Yes I wish to fly together with you in "het gat" (good that we don't need to translate that...). |
Joined Jun 2011
I am getting ready to build the Polaris XL and ran into a glitch. I had the file "Polaris Parts Templates (Scaled 133 Tiled).pdf" printed at an office supply store but when I started to measure the parts I found that they were the same size as the standard Polaris. i.e. 29" wing span and 4" fuselage width. The 4" scale pattern measures 4" so I am puzzled. Has anyone else had this problem or have solution?
PS - This file printed on 2 pieces of 34" wide paper. Is there a truly "tiled" drawing that I can print on 81/2 x 11 paper at home on my printer like the original? Those large format prints cost almost $14. |
Nevada City CA
Joined Nov 2001
As you begin to print, there is a choice of scale and "tiled", I used the "tiled" option. I printed it out on my home printer, 48 pages! in all I believe, which gives you two plan sheets, taped it all together and cut out my parts. Took some time but if you like puzzles, it can be some fun. One interesting "problem" was that the left and right fuselage sides are different sizes! I found that one side was about 1/2" to 5/8" taller at the step than the other. Maybe it was my printer, but the side lengths were correct...so I used the larger fuselage side and made two foam sides from it... Like others have commented, the plans appear to have been purely "scaled up" so that the thickness of the depron is closer to 8mm rather than the standard 5-6mm, so some adjustments must be made. Same with the height of the motor pylon and placement of the "second" CF wing spar. Once printed, I adjusted the foam slot thickness for the wing, added the second spar about 4 1/4" forward of the main spar, made sure that I had at least 4 1/4" prop clearance on the pylon motor mount. Looks like my pylon is a bit big at 2 1/2" square, as I cut the pylon too short and added to the top of the pylon to get the motor firewall up high enough for a 8" prop but fits in with the rest of the larger model. Took a little planning but that is the best part of scratch building, IMHO. My XL is ready for maiden flight, just needs the prop and a little more trim tape for color. So far, AUW without battery is 29 oz. Seems in step with other builds, as I added a little 'glass and enamel paint to the bottom and pylon, with somewhat larger CF wing rods (all that I had available) and a 80 gm HET 1500 kV motor (older brushless). So I may be in the ballpark...got to try to read the older posts again. Pictures added. Big Sucker...compared to the 100%. TK
Joined Jun 2011
Also you mentioned a second wing spar.Is this necessary for normal flying or just for high speed aerobatics? |
The XL/133 doesn't do high speed aerobatics (though it definitely does do aerobatics!). It's distinctly slower than the 100% Polaris (about 10 mph). While I haven't tried it without the second spar, I strongly recommend that you include one, as the wing is quite flexible. I've never had any problems in over a year of flying, but I do have pictures showing considerable bending of the wing during serious pull-outs, and that's with two spars. |
Nevada City CA
Joined Nov 2001
Polaris XL
Ramblin,
Ditto what Daedalus66 wrote... My XL Polaris wing (2 CF spars) is more flexible under loads than the smaller 100% Polaris (1 CF Spar). That extra 10" of span needs the second CF wng spar or there will be trouble... I fly an old Tribute 3D 40" flat foamie that has twin CF wing spars, that really bow nicely under load. It has a speed limit due to the tail feathers not liking that much wind, as the fuselage is also more flexible than the new style 3D foamies. Have not failed it with many overspeed, panic pullouts so far... Daedalus66, you mentioned the APC 8x6 as a good starting point for this motor, and I agree. The motor flew an old Alliance pattern foamie using a 9x6 APC, 2200 3S pack and a Phoenix 35, pulling about 25-28 A. This combo flew for years before I retired the airframe. I also agree that the 8x6 3-blade would be excellent, if I can find one locally. These new 25C and 30C lipos are the ticket for great performance. I got used to 6 min. flights with the 100% on 1600 mah lipos, got a little warm with the 2200kV motor but sure is entertaining. Looking forward to some more relaxing flights with the XL. TK |
