Old Apr 18, 2009, 06:10 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Originally Posted by Brian76239
I am having a problem with the ESC that I got with my 2212-6 from
Greyson. The ESC works just as it should, but the motor starts to run
if I accidently shut off my Transmitter with the lipo still connected.
THAT AIN'T RIGHT.
The ESC came in a nice plastic bag. There were No printed instructions
on how to program. HELP! This is a bad accident waiting to happen.
I want to get this plane done, but I can't really do anything until this
gets sorted out.
Any assistance is greatly appreciated.
Are you using a 2.4GHz system or PCM (which I doubt)? If so, then you may have to reset the failsafe. If it is a Spektrum, then you will have to rebind with the throttle stick in the low position. If it is Assan, then all you have to do is make sure your sticks/switches are in the failsafe position when you plug the rx in to the batts.
If it is a Corona synthesized PPM rx, then you will have to RTFM. If it is not a failsafe problem, then maybe someone else can come up with another explanation. Or maybe the failsafe is in your esc...?
chewy
chewytm is offline Find More Posts by chewytm
Old Apr 18, 2009, 10:44 AM
marie3379 is offline
Find More Posts by marie3379
france
Joined Aug 2008
I started by assembling all queue / drift / engine. This part is quite complex and extensive testing to white for the very well aligned. It is necessary to lengthen the son connecting the engine controller.
It will be equipped with a Turnigy 2826-1350 (given to 245 watts with a 7x5)
The assembly of the fuselage is not a problem. A tube of glass fiber is inserted and glued with epoxy in the wing.
After testing the engine and setting up 2 servos, collage of power on the wing with epoxy.
Engine: in 2S: 7x5 ==> 70W 9A / 8x4 ==> 78W 10.1a; in 3S: 7x5 ==> 181W 15.6A / 8x4 ==> 185A 15.6A
I therefore retain the 7x5 in 3S.
marie3379 is offline Find More Posts by marie3379
Old Apr 18, 2009, 12:22 PM
Deadeye is offline
Find More Posts by Deadeye
Glow fuel mainliner
Conrad, MT
Joined Jun 2004
Originally Posted by barnyardflyer
I would like to see how you mount the motors an run the wires on the 2 that do not have motors installed.
I could always use some other ideas as my mind is kinda stretched sometimes.
BYflyer, I just have three wires ran to the motor pod. The end user only has to solder the wires to his motor. Motor is simply screwed to the firewall with a little slot cut in it to allow the wires to go through. After that, just glue the stab and fin to the assembly. Easy cakes.
Deadeye is offline Find More Posts by Deadeye
Old Apr 18, 2009, 02:51 PM
darkseacret is offline
Find More Posts by darkseacret
Wilmington, N.C.
well I took apart the fusalage to test esc and it worked fine in another bird so now its either the motor which has been dunked a few times or the rec which may have gotten wet awhile back the other channels work fine I will swith rec. and see if that works before getting another 2212-06 . throttle is unresponsive and will not arm esc when plugged in polaris but the esc powered up just fine in my depron sukoi
darkseacret is offline Find More Posts by darkseacret
Old Apr 18, 2009, 06:15 PM
Brian76239 is offline
Find More Posts by Brian76239
Brian76239's Avatar
Nashua, NH
Joined Nov 2008
Thanks, Chewytm
You were correct. I am using a Futaba 6EX 2.4
The throttle channel has a fail-safe that allows you to set the
speed if the receiver looses the TX signal. Mine was set to 20%.
I shut off the fail-safe completely. Everything is behaving properly now.
I am definitely back into RTFM Mode. Once Again, Thanks for the Help.
Brian76239 is offline Find More Posts by Brian76239
Old Apr 19, 2009, 10:14 AM
chewytm is offline
Joined Jul 2006
Brian, you're welcome.
chewy
Old Apr 19, 2009, 02:02 PM
france
Joined Aug 2008
Following the montage ... nothing special if it is my choice of location of aileron servos ...
bye
Old Apr 19, 2009, 05:10 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Finally closed up my engine pod, hinged the elevator and glued on the horizontal and vertical stabs. Still need to install the elevator control horn, close up the top of the fuse, cut hatches, sand, and apply decals. Then it's finally time to fly! If the weather cooperates, that should happen about two weeks from today.
Tom
RCPtero is offline Find More Posts by RCPtero
Old Apr 21, 2009, 05:57 AM
Minsoo Kim is offline
Find More Posts by Minsoo Kim
Joined Apr 2008
http://www.youtube.com/watch?v=Do83ZJ02NOY
Polaris Seaplane
Pilot: Minsoo Kim
Thank to Steve Shumate.
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old Apr 21, 2009, 06:33 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Cool! Great video!
Old Apr 21, 2009, 07:51 AM
Model Aero is offline
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
Nice video!
Model Aero is offline Find More Posts by Model Aero
Old Apr 21, 2009, 08:04 AM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
How did I miss this thread? A buddy of mine sent me the link. Looks like another great one by Steve. Can't wait to start this one.
i12flyrc is offline Find More Posts by i12flyrc
Old Apr 21, 2009, 08:22 AM
LADDIE is offline
Find More Posts by LADDIE
DUNDAS CANADA
Joined Feb 2006
Minsoo, great flying.
LADDIE is offline Find More Posts by LADDIE
Old Apr 21, 2009, 09:24 AM
barnyardflyer is offline
Find More Posts by barnyardflyer
Experienced R/C Repairman
barnyardflyer's Avatar
Three Oaks, Michigan
Joined Sep 2003
Nice vid Minsoo. On the other Polaris rescue, I thought for sure your prop was going to shread the other elevator, but it went smoothly.
barnyardflyer is offline Find More Posts by barnyardflyer
Old Apr 21, 2009, 10:53 AM
FlattyFlier is offline
Find More Posts by FlattyFlier
Joined Dec 2003
Im going to order my second kit on Saturday after I get paid! I cant wait to start my new one! I've almost got my Northstar ready to recover!
FlattyFlier is offline Find More Posts by FlattyFlier
