Old Sep 10, 2008, 04:52 PM
spinup is offline
Find More Posts by spinup
hover happy
spinup's Avatar
over under
Joined Aug 2007
capture PPM signal from DX7 with radio on?
Hi everyone....a question for you...
What is the best way to capture a PPM signal (ideally TTL level), from a Spektrum DX7 during flight?
The trainer (DSC) port outputs PPM...but the radio section turns off when you plug in a cable. Also, these threads indicate that the trainer port is AC coupled for just 1.3V peak-to-peak:
http://www.rcgroups.com/forums/showthread.php?t=28323
http://www.rcgroups.com/forums/showthread.php?t=723410
This thread from April 2007 claims that the yellow wire on the radio board has an 8-channel PPM signal...
http://www.rcgroups.com/forums/showthread.php?t=671129
...but no mention of levels, or of whether that signal is pre- or post-mixing.
So...has anyone here done this? Or do you have other ideas? Sorry, I don't have access to a scope right now, so I can't check it myself.
Thanks in advance for any help!
-Jeff
P.S. This is so I can record micro helicopter flights for post-flight analysis and correlation against FDR data. If I could record the servo signals onboard, that would be great...but afaik an onboard recorder would be too heavy (>10g), expensive (time or money), or coarse (< 1024 bits/channel, 50hz). I'm open to ideas though.
spinup is offline Find More Posts by spinup
Old Sep 10, 2008, 05:22 PM
Fluffy Monster is offline
Find More Posts by Fluffy Monster
Nice and Fruity!
Fluffy Monster's Avatar
Mornington Peninsula, Vic
Joined Oct 2006
A real easy way would be to use a second RX and log those signals. This would avoid opening up your TX.
Just a thought outside the box
Fluffy Monster is offline Find More Posts by Fluffy Monster
Old Sep 10, 2008, 05:55 PM
spinup is offline
hover happy
spinup's Avatar
over under
Joined Aug 2007
Thanks Fluffy. That would be the ideal approach, if it is possible with a Spektrum radio system. Is it? Can you bind two Spektrum rx's to the same model memory on a single Spektrum tx? And how do you get a PPM signal from a Spektrum rx?
-Jeff
Old Sep 10, 2008, 07:57 PM
Nice and Fruity!
Joined Oct 2006
As I understand it, the binding process is telling the RX what TX to listen to. So binding multiple RX's should not be an issue.
PPM is just a serial (20ms frame) version of what comes out of your RX. ie a pulse between 1 & 2ms. Plenty of articles on the web to fully describe it.
Old Sep 10, 2008, 09:21 PM
Tomapowa is offline
Find More Posts by Tomapowa
R/C Electro-Gadgeteer
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Yes you can bind two Spektrum AR9000 receiver to one model on a DX7 (and even Futaba/Spektrum modules). I never tested this with two AR7000 receiver though... but it certainly should work.
Tomapowa is offline Find More Posts by Tomapowa
Old Sep 10, 2008, 10:10 PM
spinup is offline
hover happy
spinup's Avatar
over under
Joined Aug 2007
Yes! I just confirmed this too with two AR6100s, v1.2 firmware. The RX's also send a signal when binding...but I guess they just identify themselves as DSM2, no GUID.
Correct. The question is, how do you get a PPM signal from a Spektrum AR6100? Does it output the PWM channels sequentially, with enough delay that they can be simply muxed together? I seem to remember reading that the AR7000 slams out the pulses edge-to-edge, too close to just mux...but again, I don't have a scope to check this...
Regardless, I'd still like to know if anyone has pulled a PPM signal out of the DX7. Then I won't have to buy another $50 receiver...yet...
Thanks all...
-Jeff
Old Sep 10, 2008, 11:29 PM
Nice and Fruity!
Joined Oct 2006
I guess the RX option was a little OT
You would not be able to just mux it together, specially if 'servo sync' was on. As 'Servo Sync' is designed to align the servo movements.
I would use a micro to capture the pulse lengths and log them. Format of logging them (PPM, stream like used for FMS serial etc) would depend on final application.
So if you did it serially (FMS format), you could fly Virtual and Real at the same time
Old Sep 11, 2008, 12:52 AM
spinup is offline
hover happy
spinup's Avatar
over under
Joined Aug 2007
Oh, I think it was a great suggestion, thanks!! Really, I'll use whatever approach works best/fast/cheap.
FWIW, this is the thread about AR7000 PWM-to-PPM problems: http://www.rc-cam.com/forum/index.ph...pic=2064&st=20. I'm just guessing the TX approach is easier...but we'll see. Hopefully someone else has done it already.
-Jeff
Discussion No signal from Tx with antenna collapsed buurin Radios 3 May 01, 2007 11:58 AM
Using resisters on servo amp with radio without EPA rogueflyer Aerial Photography 0 Sep 25, 2004 01:13 PM
trouble with mix on radio snolord1 Flying Wings 6 Aug 29, 2004 09:49 PM
Radio glitches with power on my Hacker setup. Any ideas? Neil Morse Power Systems 10 Jun 17, 2003 01:53 PM
Help from somebody with a Hacker 26" FF Decathlon kit on the shelf smokinjoe Electric Plane Talk 0 Nov 25, 2002 10:20 PM
