Old Sep 10, 2008, 02:06 PM
mattgto91 is offline
Find More Posts by mattgto91
Joined Sep 2008
Help!
just bought a king 2 its not working
Hi guys i just got a esky honeybee king 2. I flew it last night well first time flying a helicopter so i got it off the ground but nothing fancy.
This after noon i went to try again after having charged the battery and nothing happened the light on the reciever flashed twice then went out.
The trans just keeps flashing and so does the gyro. Reading the manual i gathered the two needed binding so i reset the rx but now i cant get them to rebind
Was that the prblem in the first place and how do i rebind the tx and rx
Many thanks
Matt
mattgto91 is offline Find More Posts by mattgto91
Old Sep 10, 2008, 02:38 PM
PLATINUM is offline
Find More Posts by PLATINUM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
This may not be a binding problem.. The stock rate gyro is sensative to humidity levels.. it could be that the gyro is not locking in.
PLATINUM is offline Find More Posts by PLATINUM
Old Sep 10, 2008, 02:41 PM
Joined Sep 2008
cheers for that reply mate if that is the problem how do i fix it do i need a new one and what would be a good replacment
also i still need to rebind the controller i followed the instructions but it dosent seem to be working
cheers again
matt
Old Sep 10, 2008, 02:45 PM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
Basically you need to put the heli in a dry place for 30minutes or so..
The king II has some absolute changes you need to make to it.
You need to go brushless motor/esc
T-rex 450 tail blades
and a better gyro is also a good idea
The worst case scenario is that your esc has blown.. this is a VERY common problem with this heli. You would know if it went. Smell of burnt electrics..etc..
Old Sep 10, 2008, 03:04 PM
Joined Sep 2008
ok there was no burning smell the amber light is still flashing slowly but dosent stop on the receiver
the transmitters led also flashes and dosent stop
i have tried many times to bind the two but to no avail i have an esky ek2-0406g
cheers
Old Sep 10, 2008, 03:09 PM
spinup is offline
Find More Posts by spinup
hover happy
spinup's Avatar
over under
Joined Aug 2007
LOL, that's a funny one.
Plati, I think you mean temperature levels. Even the cheapest piezo gyro sensors are packaged so humidity is not a factor. But anyway, temperature does not affect initialization.
On the surface, this sounds like a radio issue. e.g., the throttle stick/trim is up or the idle-up switch is on, so the radio will not initialize.
-Jeff
spinup is offline Find More Posts by spinup
Old Sep 10, 2008, 03:20 PM
Joined Sep 2008
lol right i have tried that all switches are off everything is at zero and it still wont work
also the instructions keep telling me to disconnect the 4 in 1 mix controller what is this i have no idea and the instructions say nothing about it other than in the rebind instructions
Old Sep 10, 2008, 03:21 PM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
I noticed this mostly when its humid.. I have flown in 80-90 degree days with no/low humidity.. and it popped in fine. This particular gyro is rate only .. and seems more sensative then the other HH piezo gyros to heat/humidity..
Definately could be trim on the throttle or idle up switch on..
Bind plugs might not be secure?
Old Sep 10, 2008, 03:24 PM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
4-1? lol... there is no 4-1 on a King II..
Old Sep 10, 2008, 03:46 PM
Blade_Killer is offline
Find More Posts by Blade_Killer
innocent victim
Blade_Killer's Avatar
Houston TX
Joined May 2007
you know, I dont remember binding the TX on a stock king2 being an option, and it doesnt have a 4 in 1, are you sure you have a King2??
Blade_Killer is offline Find More Posts by Blade_Killer
Old Sep 10, 2008, 03:57 PM
spinup is offline
hover happy
spinup's Avatar
over under
Joined Aug 2007
ek2-0406g is one of the new 2.4ghz esky radios, which does have a binding process.
Not sure about the 4-1 reference though. Matt, what manual(s) are you reading for this info?
-Jeff
Old Sep 10, 2008, 04:19 PM
Joined Sep 2008
ok its definatly a king 2 the transmitter is the 2.4 g and the manual is the manual that came with the helicopter and there was not a manual for the tranny itself and me not knowing where this 4 in 1 mix controller would be explaind by me not having one lol
Ok so shoulod i send the king 2 back to be sorted or is there something else i can try
Many thanks for the replies
Matt
Old Sep 10, 2008, 04:33 PM
innocent victim
Houston TX
Joined May 2007
k, didnt know the 2.4 kings were out.......cool
Old Sep 10, 2008, 04:36 PM
deadduck is offline
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Throttle trim?
Move your throttle trim to full down before you turn on anything.
Turn on TX.
Plug in battery pack.
Do it with the heli on a level surface.
If that doesn't work, you may need to rebind your 2.4 TX to the rx.
BPhobbies have an Esky 2.4 manual available for download on their site.
Esky 6 channel 2.4ghz
deadduck is offline Find More Posts by deadduck
Help! 6EXHP plugged battery in backwards now its not working BowerR64 Radios 5 May 09, 2008 12:23 AM
Discussion i added a g90 gyro to my cp pro ... but its not working andrew sport Mini Helis 5 Feb 29, 2008 10:48 AM
Help! Honey Bee King 2 Using 30A ESC, 5V/6V Switchable BEC, Brand New, Servo not working? RcSuperSales Micro Helis 5 Aug 04, 2007 12:39 AM
Question Help - just bought an OEM power supply. Not sure how to check and set up. Peter Young Batteries and Chargers 11 Jun 16, 2003 07:02 PM
Helicopter Parkflyer..Sort of..Just look..its not in wrong forum.. SpaKack Parkflyers 8 Oct 13, 2002 10:53 AM
