Old Sep 10, 2008, 12:17 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
BVM Bandit, Electra, Mig-15, Tamjets A-4 and F-16 power by TJ100 videos
Today I got three more flights with 12s set up.
Here is two videos clip.
http://www.rcgroups.com/forums/showt...2#post10519095
http://www.rcuvideos.com/video/Mig-1...J100-video-wmv
Tamjets is offline Find More Posts by Tamjets
Old Sep 10, 2008, 01:29 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Awesome airplane!! Can`t wait to see it in person.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Sep 10, 2008, 06:07 AM
LeadSled is offline
Find More Posts by LeadSled
Just here to fly stuff
LeadSled's Avatar
Everywhere
Joined Dec 2005
Tam, the Bandit looked great! Really looking forward to seeing it fly at Ohio.
LeadSled is offline Find More Posts by LeadSled
Old Sep 10, 2008, 10:01 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
The light 12s settup flys better than the 14s.. less money in packs and less weight to land
That pretty much proves your point...
good job
Ron
Ron101 is offline Find More Posts by Ron101
Old Sep 10, 2008, 10:04 AM
k_sonn is offline
Find More Posts by k_sonn
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Nice Tam but I thought you were going for speed. The fastest pass in the second video (the one with 4.5kw) was only 171 mph and that was out of a dive and with a strong tail wind. The doppler below was taken between 2:30 and 2:36 on the video. Unless you get more speed, the 12S EVF powered Electras are going to give you a rough time.
Kirk
k_sonn is offline Find More Posts by k_sonn
Old Sep 10, 2008, 12:08 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
time for more cells...or more green bottles!
corsair nut is online now Find More Posts by corsair nut
Old Sep 10, 2008, 12:24 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Kirk
Kirk,
This is a Bandit and is big. The 6600mAh 12s set up weight 18 lbs. Even I only go 120mph. But there is no body fly the Bandit to compare the power.
If the Electra. That is we can see the power different. I had this set up in the Electra right now. I won't post the video until after Ohio.
Old Sep 10, 2008, 12:52 PM
k_sonn is offline
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Ok, the Bandit is a little larger than the Electra but not that much. So what you're saying is that by dropping 2 cells and adding 1700 more mAh you increased the weight of the Bandit by 2 pounds (the 14S setup weighed 16 pounds). Wow. So much for those light weight setups you've been preaching about for the last couple of months. That's a serious weight increase. Throw those batteries away and go back to the 4900 mAh setup.
By the way, below is the doppler of the first diving, downwind speed pass from the 16 pound, 14S setup. It looks like the 12S setup is a little faster. It must be all that extra weight creating some momentum in the dive.
Kirk
Old Sep 10, 2008, 01:16 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Kirk
Kirk,
The Bandit is a lot bigger. I had two size by size. The weight different between Band and Electra 3.5 lbs on the same power set up.
That is huge different.
The Bandit 14s 4900mAh was weight again after I final finish was 17 lbs.
My early post weight was off by .7 lbs. I didn't had all the accessories install after is all finish.
The 6600mAh 12s weight 1 lbs heavier than 4900mAh 14s.
I wish the Kontronik Power Jazz work smooth through out the flight.
I had 3 set of those 14s 4900mAh. Until Casstle get their HV sorted out. That when I'll go back to 14s.
Old Sep 10, 2008, 01:39 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Tam this is the controller you want to use: Schulze fut-40.160H
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Sep 10, 2008, 01:58 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Come on K sonn, the Bandit and Electra are like apples and oranges, surely you know that. If not, your perceptions are so out of whack that I`d hesitate to put much stock in your Doppler work either.
Old Sep 10, 2008, 02:23 PM
k_sonn is offline
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Come on Lee, no need for you to take this personal. You have no dog in this fight as you texan say (if there was a fight, which there isn't). Anyone can do the dopplers and they will get the same results. I gave the time on the video from where the first doppler was taken. I'm not putting Tam's fan down. I have one and you and I were the first to fly his fan. All I'm saying is that Tam made the comment that he was going for speed with the Bandit. Based on that comment and the dopplers, these two setups could be considered failures by anyone with analytical skills. In a phone conversion Tam and I had a couple of months ago he stated he would not test the 1521 motor because the added weight of the motor and cells was not worth the few hundred watts it produced. It seems he was right. Tam has also been comparing his setups with all of the other setups in the 110 to 120mm range stating that his setup is the lightest and produces the more power than any of them without reguard to the size of the airframe. So, let's not start crying about the Bandit being larger than the Electra. Besides, I'm not the one who brought up the size of the airframe and if Tam was going for all out speed he should of made a wiser decision about which airframe to use. In reality, no one flying Tam's fan has been able to break the 200 mph barrier. That can't be said about the TF4000. Been there, done that and it will be done again.
Kirk
Old Sep 10, 2008, 02:45 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
yeah don't sweat it Lee, kirks just being honest and analytical about his perspective, that's a good thing, it ensures we look at everything honestly. it' too easy to do your own thing and think it's the bees knees, but we all need an outside eye.
I still might agree with that about the 1521, but this setup was the smaller 1518 motor. and lets say for argument it only did 150, the bandit isn't a tad bigger, it's 25% more wing, 25% more weight but 30% less inlet! what more is there to say looking at that alone! then compare it to other bandits flying' oh wait! there are none!
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Sep 10, 2008, 03:15 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Kirk
Kirk,
I'm speakless.
You got me. I should not fly the Bandit with E-power. But why not.
Breaking 200mph is only question how much power to do it and what the weight of the aircraft?
If you had to use 5.5kw 6kw to do it.
Well, 195mph on 4.2kw is not bad right?
Anyways, there is chance you see the TJ100 fly in the Electra at Ohio to the speed you want on less watts.
I know what is bugging you lately. But we let it go and we have fun at Ohio.
Old Sep 10, 2008, 03:35 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Oh ... do tell
Gordon is offline Find More Posts by Gordon
Discussion Tamjets TJ100 Tamjets Electric Ducted Fan Jet Talk 446 Jun 22, 2012 12:40 PM
Discussion Spark power by TJ100 videos Tamjets Electric Ducted Fan Jet Talk 58 Sep 10, 2008 10:01 AM
Video TJ100 power BVM Bandit ARF's Tamjets Electric Plane Talk 0 Sep 07, 2008 11:40 PM
Video Tamjets A-4 power by TJ100 11s Tamjets Electric Plane Talk 2 Jul 09, 2008 11:09 PM
Bandit Power stephen.s1 Electric Sailplanes 6 Sep 21, 2001 11:41 PM
