Go Back   RC Groups > Aircraft - Exotic and Special Interest > Ornithopters
Featured In
EZone
Intro
Fenice is a good little flyer with an included transmitter and built in charger.
The Ornithopter Zone's Fenice Review
Article Stats
Hits:  6586
Wingspan:
Weight: 1.0 oz.
Length: 10"
Servos: micro actuator for tail
Transmitter: two channel with charger
Battery: 3.7 volt LiPo
Motor: Brushed
Available From: The Ornithopter Zone
MSRP: $59.95
The good folks at the Ornithoper Zone are your source for mechanical birds, providing plenty of good information about flapping wing flight.
I'm Fenice, as it was formerly called, is also known in ancient Egyptian mythology as the bird that regenerated itself with fire. For us we might refer to the same as Phoenix. A one ounce bird made of durable foam that, trust me, is indestructible, with a 16-inch wingspan and brightly colored wings, the little bird flies really well and with some stick time you will become a capable ornithopter pilot.
The product arrives well packaged and looks a lot like a toy, however it is much more than that. It has an included transmitter that also doubles as a charger. Fenice also uses a LiPo battery and can fly five or more minutes at a time.
Fenice comes ready to fly. It is housed in a cardboard box with a plastic insert tray that protects it during shipping and safely stores it when it’s not flying. The transmitter has its own receptacle under the Fenice.
Includes:
  • Foam bird with wings
  • Transmitter and charger
  • Extra set of wings
  • Screwdriver
  • Instructions
Kit Requires:
  • 6 AA batteries
There is no assembly required. I am not even sure you will ever need the extra wings. The Fenice is so light, crashes do not even dent the foam body, and the carbon spar wings seem every bit as durable. To fly, all you will need to do is put the batteries into the transmitter, and charge the internal battery.
Tail
The tail uses a micro actuator for rotation and control. It is really a simple method, but it is very realistic in how it controls flight. There is no elevation control. Direction is changed via a rotating tail that places one edge of the tail higher than the other.
The Fenice comes in two different frequencies, and to prepare to fly the frequencies must be synchronized. There is a switch on the transmitter, and the bird is clearly marked with a channel. There is a provided charging cable with that plugs into the receptacle under the bird. Charging takes about ten minutes. LEDs on the transmitter alert you when the charge is complete. Each subsequent charge will take longer until your six AA batteries are depleted.
A word of caution: Don’t continuously discharge and charge your battery. You should let them cool a few minutes between flights.
The Fenice’s flying is limited to calm days or lots of indoor space. Light winds take some practice.
When you drive big boats you have to anticipate the movement and make corrections well before they occur. With Fenice you need to also anticipate. I found a right and left rocking motion to be the best method. If you do not anticipate your next control input, you end up down wind. You can fly right into the wind by constantly moving right and left.
I found the Fenice to be a pretty good flyer. It climbs really well, and if you cut the throttle you will fall from the sky in a spiral. If you time the throttle cut off you might get the wings to stop flat and it will glide some. Otherwise you run the Fenice at full throttle.
You hand launch of course and landings are really just letting it hit the ground when you run out of battery. No real landing of any notice, but again this bird is durable as all get out.
This is a great gift for a young pilot to be. They can learn the controls and see flight in its truest form. The colorful Fenice is easy to see, and you cannot beat the simplicity and user-friendly charger. It’s a fun little ornithopter for all ages, totally ready to fly and a good starting point those interested in mechanical birds.
Type Name
Size
Fenice takes to the air.
9.95 MB
What a great way to get a very young person started in this hobby. The bird is durable, and while it does require some learning to fly, it is not a limitation. It is a wonderful product to get your kids involved and a super way to spend the afternoon flying. At $59.95, Fenice is a winner.
Pluses:
  • Durability
  • Easy to see
  • Flies well
  • Lon flight times
Minuses
  • Take some time to learn direction control
  • No way to open the body to replace the battery
Old Jan 07, 2009, 05:39 PM   #2
Thanks for the review 78dave. Nice to see that more people are trying these.
I should point out though that they come on 3 channels not 2, with 3 in the air you can have dogfights which is fun as they can pick up a lot of speed
After flying this bird a lot you will find that it can handle a good deal of wind if you stay on top of it (dont TURN too hard and far or you will have an annoying bit of upwind flying to do!)- I commonly fly mine in 15-20 kph winds (very windy over here), this is especially great wind to fly in if you have a hill to ridge-soar at as you will get very long flights and the bird will go up and up.
airDemon64 just reported a timed 22 minute flight which is fantastic for a micro! (http://www.rcgroups.com/forums/showt...9#post11293873)
I bought a big lot of these from the distributor Batstangerz a while ago to sell them online but gave up on that, so now I am selling them off at a low price (see: http://www.rcgroups.com/forums/showt...=979362(asking $45 each).
These can ROG if you have hard packed snow, just make sure the switch is covered so that snow does not get inside.
For soft landings, just set up a good, long, approach and slowly drop off the throttle, you can then fly within a few inches of the ground and let it land softly.
bugstugler is offline Find More Posts by bugstugler   Reply With Quote
Old Jan 07, 2009, 06:20 PM   #3
Inciting Riots
village_idiot's Avatar
Pretty cool, wish you could use a better quality TX with these.
Would be nice if they sold replacement bodies so that they could be opened to change the receiver to use with a better radio, and also to change the batteries.
village_idiot is offline Find More Posts by village_idiot   Reply With Quote
Old Jan 07, 2009, 06:26 PM   #4
The body is really easy to open, I have opened some of my own to take a look. All you have to do is remove the wings and carefully slice (not too deep or you will cut through some foam dimples) along the seam.
There is a lot of space inside so you probably could upgrade the radio gear. The part that might be dificult to upgrade would be the motor as the gearbox is molded to the shape of the motor. Seriously though, considering how powerful and long lasting the motor is I see no need to replace it.
Old Jan 07, 2009, 07:28 PM   #5
the guy
Send a message via MSN to airDemon64
Thanks for the review Dave. I was actually thinking of writing my own review but jobs done, maybe I'll wait a year or 2 then post mine
Yeah Its a great bird, it has a much larger learning curve compared to the more "toy-grade" vamp or I-bird. I would definitely not say it is a "gliding" or soaring bird, its far too light to keep momentum so just spirals to the ground but if you just keep your finger on the throttle as low as possible it will stream right along, especially in winds.
Happy to see more people enjoying the Fenice, think people are avoiding it cause they're still using the "first flying bird" ad.
Edd
airDemon64 is offline Find More Posts by airDemon64   Reply With Quote
Old Jan 08, 2009, 05:26 AM   #6
Dr. Dave
Guys, thanks for your comments. I agree with the thought that you need to stay ahead of it and not turn too much. The bird climbs great and when you do learn to fly it it is just plain fun. Bugstugler, thanks for adding your wealth of information.
78dave is offline Find More Posts by 78dave   Reply With Quote
Old Jan 08, 2009, 05:52 AM   #7
I can fly mine EXACTLY as shown in the online factory video: that INCLUDES gliding flight with outstretched, non-flapping wings! Further, I can do some tricks, including rolls and one semi-accidental loop! OK, I'm a very experienced pilot and know how to use the machine's natural tendencies to advantage (i.e., as in proper soaring, use, not fight with, "the force").
My two birds (already used to flying inside with normal-size and smaller Tim-birds) LOVE coming out with me and watching me buzz and tightly circle them (they, AND all dogs, love the wheezing sound too!). "Star" screams with excitement as Fenice quickly spirals higher and higher, which she thinks is way cool. Me too
xlcrlee is offline Find More Posts by xlcrlee   Reply With Quote
Old Jan 08, 2009, 10:52 AM   #8
Machy2k's Avatar
Lee; hi man, ahhh we need some vid. of the birds and the mechanical birds playng and flying together.
Have you posted info. before about your birds?
I would love to hear more, especially if you routinely excercise them using r/c toys, that is cool...
Please man inquiring minds need to know..
L8r...
Petey...
Machy2k is offline Find More Posts by Machy2k   Reply With Quote
Old Jan 10, 2009, 06:33 AM   #9
first: it am WINTER here, boys! Kiki and Star fly indoors. When we visit my friend Susanne's huge 300 yr old house, instead of normal room-room flight, Star figured out to lead them on a grand tour of the whole house: like upstairs, around and down, ending at starting point. She is one clever, wild creature! Kiki likes his hanglider airtime, since before precision "landing practice", several times daily I fly it tethered for several minutes around the living room, letting him control it, like a child's amusement park ride (he uses body-shift, plus wings for various effects). Anyway, last night, Star decided that "enough was enough" and flew in formation with Kiki on his delta for around 20 times around the room (tiring her a lot!). If you search "Kiki piloting his Delta" in the total forum you might find a photo of Kiki doing so (I posted it previously). He HAS gotten bored with the Tim-birds, and won't circularly chase them any more, just fly after them in a straight line.
Old Jan 10, 2009, 06:34 AM   #10
http://www.rcgroups.com/forums/showt...ta#post9283491
Old Jan 10, 2009, 10:15 PM   #11
Live to ride... and fly!
Tres Wright's Avatar
Sounds like you guys have had pretty good luck, mine didn't fly worth a darn. The actuator was not strong enough to turn the tail consistently. Sometimes it would turn, but then it might stick at full lock and not return to neutral and would just spiral in. I tried working on the tail to make it more free, but no joy. I've read some similar reports, so it sounds like the QC on these is iffy. You might get a good one or you might get a lemon
Tres Wright is offline Find More Posts by Tres Wright   Reply With Quote
Old Jan 11, 2009, 03:02 AM   #12
Machy2k's Avatar
Yeah Tres the Qc is a problem, and of course if you get a good one your in.
On my best one the bellcrank popped off, I finally fixed it, My B channel has a range prob. but last night it flew great.
IMO the velcro on the back is a weak point in the design, but these birds fly like the Cybird P2 if you could compare the size.
When I flew my p2 the first time, it had powerfull flap strokes and was not flitting around like the P1, this bird is definately worth the dough (as long as you get a good one), lol
Old Jan 14, 2009, 01:14 AM   #13
Just Say No To GMO
demisemiquaver's Avatar
I'm reading the O.Z. site and it says the fenice and eledove come in different frequencies... is that 27mhz and 49mhz (I hope) or some just variation of 27mhz?
I ask cuz 27mhz does not work well where I live. I want one of these bad.
demisemiquaver is offline Find More Posts by demisemiquaver   Reply With Quote
Old Jan 14, 2009, 09:06 AM   #14
The manufacturer says it works on 2.4 GHz. Not sure but I don´t think that Nathan Chronister does change the radio system.
midlander is offline Find More Posts by midlander   Reply With Quote
Old Jan 14, 2009, 11:18 AM   #15
They aren't sold on 2.4GHz, they come on three different channels on 27 mHz.
I should note that the birds are a simple enough design to mod and it would not be difficult to run say a Vamp 49 mHz RX in there. You could likely run Spektrum or Plantraco gear in there just as long as you can figure how out hot keep the motor and actuator working correctly.
Hello from E-Zone's new Sales/Marketing Mgr.! Shawn Palmer Electric Plane Talk 9 May 22, 2002 02:43 PM
Endoplasma (original) brushes are S or M? jopereira Power Systems 1 Feb 26, 2002 11:45 AM
TRADE Deans Ultra F's for M's sgil2001 Aircraft - Electric - Airplanes (FS/W) 5 Nov 23, 2001 02:30 PM
S&E M Design Comp - Part Trois ? Dereck Sport Planes 2 Jun 28, 2001 08:07 AM
S & E M Design Comp - Part Deux Dereck Sport Planes 18 May 24, 2001 05:57 PM
11
