This thread is privately moderated by CarreraGTSCS, who may elect to delete unwanted replies.
Old Sep 08, 2008, 08:19 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Flight Log: SAPAC Jas-39 Gripen
Flight 1: Aborted. Veered sharply right into the grass and damaged the nose gear. Nose gear disengaged.
Flight 2: Free castoring nose wheel. Veered slightly left, launched off of grass edge of ballfield. Approx 3 minutes of flawless flight. Landing gear wire very weak. Lipo charge-- pack#1 took 1.223 amps, pack #2 took 1.213 amps, both down to 3.8+ volts per cell.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 24, 2009, 11:13 AM
Louierc is offline
Find More Posts by Louierc
Just Plane Nuts
Louierc's Avatar
USA, NC, Southern Pines
Joined Dec 2008
JAS-39 questions
Mike - thanks for all of your posts on the SAPAC JAS-39, they has been very helpfull to me. I am into this build and have a few questions -
1. What glue did you use for the foam parts?
2. What paints did you find that worked OK on the foam surfaces (I have seen Testors, Krylon H2O, acrylics, enamels, others).
I am building without gear, may make a bungie launcher, since I only have grass fields.
Thanks, Louie
Louierc is offline Find More Posts by Louierc
Old Jan 24, 2009, 11:20 AM
Joined Jan 2004
I used GWS glue (a contact adhesive) on all parts except for the wings. To attach the wings I used polyurethane glue. I don't remember if I used the Gorilla brand or Elmers brand.
I haven't completed painting it but I used craft store acrylic paints which are water soluble (sp?). Look for the SAPAC Eurofighter thread. In the last 10 pages or so I mention the color, brand and mix of black to get the SAPAC grey.
I use a takeoff dolly instead of a bungee. If you're going to belly land you must do something to protect and reinforce the lower edge of the intakes. Even grass will damage the soft foam. I had a spare length of carbon tube that was split to make a leading edge for the intake.
Hope this helps.
Build Log Large 70 to 90mm Fan SAPAC JAS-39 build and first test flight video EDDIEGIGOWATTS Foamy EDFs 2068 Jan 04, 2015 11:13 PM
Video Sapac JAS-39 Gripen JIMinKENTUCKY Electric Plane Talk 0 Sep 07, 2008 08:40 PM
Video JAS 39 Gripen Pusher Jet Flight Video Nadim Electric Plane Talk 6 Jan 21, 2008 02:37 AM
Alert Foamie JAS-39 Gripen Build... all foam plates! ssyed Foamies (Kits) 0 Jul 28, 2004 11:34 PM
JAS-39 Gripen section drawing. rcaviator Electric Ducted Fan Jet Talk 1 Feb 21, 2003 01:10 PM
