Old Sep 07, 2008, 11:36 PM
ohm116 is offline
Find More Posts by ohm116
Keizer Oregon
Midwest Fantail Launch photos and question
I have had my Midwest Fantail Launch done for few months now but hadn't taken any photos of it so I thought I would share. I also have a quick question, I seem to have the engine running pretty good now, goes for about 20min or so, but I have to keep oiling the valve surface every few minutes to keep it running smoothly, could I add a few drops of oil to the water to help keep things lubricated, I was thinking olive oil as it is nicer to the lake that it would be exhausted into. Here are the photos.
ohm116 is offline Find More Posts by ohm116
Old Sep 08, 2008, 01:33 AM
steveciambrone is offline
Find More Posts by steveciambrone
steveciambrone's Avatar
United States, CA, Santa Clarita
Joined Dec 2005
Nice job on the steam boat, check out this thread
http://www.rcgroups.com/forums/showthread.php?t=475833
If you have any questions please ask.
Steve
steveciambrone is offline Find More Posts by steveciambrone
Old Sep 08, 2008, 02:28 AM
ohm116 is offline
Keizer Oregon
Excellent thanks, I well look into making a displacement lubricator, how does a 1/2" diameter copper tube with caps on both ends about 1" long or so sound and a tee made out of 1/8" brass tube for the connection to the steam line? Can the steam line go perpendicularly to the oil tank body? Also for the fill on top could one just plug it with a rubber stopper or would it be under too much pressure for that. Or does it work better if gravity is helping it. I have a perfect empty dope bottle for the condenser tank.
Again thanks for your help.
Old Sep 08, 2008, 10:17 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
The steam line can go in perpendicular, up near the top of the tank (you are not supposed to fill the tank with oil higher than the steam line, though it has been done). The steam line can be "dead end" or "flow-through" wrt the oil tank. That is, the tank could be serviced via a T fitting from the steam line, or you could stick the steam line in one side, and have an exit steam line on the other side of the tank. The easiest way to make a flow-through would be to use one continuous tube through the oil tank, with a tiny hole in the tube in the middle of the oil tank; I think the hole should be horizontal, but am not sure. My Accucraft locos have the flow-through design, with the tube filed away, instead of a tiny hole. They eat oil much faster than necessary, so I have to replenish the oil tank more often than convenient. The oil need only be a mist in the cylinder, not a dollop, like the Accucraft provides.
A rubber stopper would not be a good idea. The oil tank is subjected to the same pressures as the boiler, so the stopper would probably blow out. Once it blew, you'd be dead in the water as all the steam would exit thru the top of the oil tank, none reaching the cylinder. Also it'd probably make an oily mess :-). If you are enamored by the rubber stopper idea, then put a keeper on the stopper, like you see on Grosch beer bottles, or like you see on champaign bottles.
Brooks is offline Find More Posts by Brooks
Old Sep 08, 2008, 11:01 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Xlnt job on the boat build!!
Kmot is online now Find More Posts by Kmot
Old Sep 09, 2008, 05:46 PM
sergio_Italy is offline
Find More Posts by sergio_Italy
gamma
sergio_Italy's Avatar
milano_Italy
Joined Aug 2008
Hi Ohm, I like your little boat very much and I'm going to check Midwest site right now, thank you for sharing and keep your pics coming.
sergio_Italy is offline Find More Posts by sergio_Italy
Old Sep 09, 2008, 07:09 PM
Joined Dec 2005
some pics of Lubricators and condensate tanks.
Steve
Old Sep 09, 2008, 11:57 PM
ohm116 is offline
Keizer Oregon
Great thanks for the info, it should not be hard to produce something then. Me and my Dad took the boat out briefly yesterday and tested it and it was a good thing that we had tied a fishing line too it as the wind picked up and it soon became impossible to get it to come back to shore and the steam engine stopped once due to lack of lubrication so I think this oilier well be a major improvement for it. As for the cap I am thinking I could even use a copper end cap and cut an L shaped slot into it to go over the steam line and lock it down, I well have to see what I can come up with.
P.S. Thanks Steve, Kmot and Sergio for the comments, this was my first boat, I have done a lot of RC and CL Planes and I have quite a few hobbies so this was a nice change of direction, that and I have wanted one ever since I saw one at the hobby shop when I was a kid I am really looking hard at the liberty tug and wondering if I can justify it enough to get out my credit card to pay for it, give me time and I am sure I well find a way I would probably go electric on it though.
Old Sep 10, 2008, 07:57 AM
gamma
milano_Italy
Joined Aug 2008
take all the time you need Ohm, i'll wait and welcome on board!
ciao
Old Sep 11, 2008, 10:23 PM
ohm116 is offline
Keizer Oregon
Well I think I have the oilier figured out, it is a 1-1/2" long piece of 1/2" copper tubing with a cap soldered to one end and an 1/8" diameter copper tube with a slit filed into it going through it for the steam line. The top cap well be held on with a piece of music wire bent over the steam line. Here is some photos:
Old Sep 12, 2008, 12:54 AM
Joined Dec 2005
You will need a seal in the cap so there will be no steam leakage.
Steve
Old Sep 12, 2008, 04:31 PM
ohm116 is offline
Keizer Oregon
It seems a pretty good fit, if not I well toss an o-ring it there to seal it up.
Old Sep 12, 2008, 06:01 PM
420TEE is online now
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Fill it with water and turn it over. If water leaks out, which it will, so will steam which is under pressure. That's why pipes are soldered and not just pushed together.
420TEE is online now Find More Posts by 420TEE
Old Sep 13, 2008, 08:40 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
Perhaps you could use a rubber stopper under the brass cap. The stopper would seal against steam leakage, and the cap & wire bale would keep the stopper from blowing out. The cap would have to fit snuggly over the top of the stopper to keep the stopper from lifting, naturally.
I question whether your ship stopped due to lack of cylinder oil. I would suspect low steam pressure is a more likely cause. You did not run out of water did you, that would be another cause of stoppage?. When the cylinder&piston have no oil, they still function, but some of the power is absorbed by friction between the piston and the cylinder walls. The steam, condensed to water droplets on the cool cylinder walls, provides some lubrication, even w/o oil. A well-oiled piston may decrease friction so much that run times double, so it's worth making the displacement lubricator; I think you will be pleased with the result :-).
btw, you have to suck out the water from the bottom of the lubricator after every run (and top up the steam oil). I use hypodermics I got from the farm animal feed store (check the medications section): one to suck out the water, and another one to add the oil. I ground off the sharp ends of the needles by rubbing them on a stone in the yard, cleaning the needles throughly afterwards.
Old Sep 16, 2008, 01:28 AM
ohm116 is offline
Keizer Oregon
That's an idea, with the stopper, I also have some rubber sheet that I could cut into a seal to go into the top of the cap as well, either way I'm sure well work, just need to get time to do it
Question about Midwest Fantail Launch orenda635 Dock Talk 2 Oct 23, 2005 04:41 AM
ARR fantail launch ebay vett Boats (FS/W) 2 Sep 28, 2004 08:31 PM
Fantail Launch II and Steam Engine rpm3 Boats (FS/W) 0 Aug 03, 2004 10:08 PM
Bungee Launch Flying Wing Question War Bird Radio Thermal 2 Mar 13, 2004 08:39 AM
Hand Launch Glider Battery Question? putt_13 Electric Sailplanes 16 May 20, 2003 06:07 PM
