Old Sep 07, 2008, 10:30 PM
speed8081 is offline
Find More Posts by speed8081
Joined Jun 2007
Question
Esky lama v4 with Walkera rx-2411 2.4G receiver - possible ?
Hi guys,
Just wondering is it possible to use the Walkera 2.4g receiver rx-2411 on the Esky lama v4? Or any other walkera 2.4g receiver?
I have the Walkera wk-2401 2.4g TX (for my walkera 5G6) and thinking if i can use this tx for my esky lama v4 that will be great. No need to use 2 TX.
Thanks.
speed8081 is offline Find More Posts by speed8081
Old Sep 08, 2008, 11:08 PM
Hokum Jim is offline
Find More Posts by Hokum Jim
This is what I want!!!
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
The short answer is "probably"
It would take a bit of tuning but I reckon you could use that Rx (for those that don't want to dig it up the Rx is from from a Walkera 5G4Q3 and probably the 2.4G 5#4 - but I can't find spares for that one to confirm)...
Note that the swash arrangement is similar between the Lama and 5#4 and 5G4Q3 BUT the Lama's swash controls are the reverse of the Walkeras... put simply the elevator servo on the Lama pushes up to got forward where the Walkeras pull down... the end result is the same movement of the swash but the servos moved in the opposite direction Hence the big catch and the reason for the "probably" is the possibility that you would need to reset the servo reverser switches onthe TX each time you switch from the Lama to the 5g6... might not be a big deal but it would bug me.
The 5#10's receiver (RX2410) is probably the prime candiate for this mod since the control throws are the same as the Lama (there is a difference in the swashes because the 5#10 is a 120degree arrangement where the Lama is 90degrees) but the big catch here is that it a 3.7 volt bird that uses smaller motors than the Lama. So the Rx might not be able to handle the extra voltage and the Lama's awesome grunt (that's Aussie for Power).
The only way I know for sure that will tell you if it works is to buy one and see if you blow it up... No really a sophisticated method but there is comedy value in making $40 purchase, waiting up to 2 weeks for it to arrive from another country (possibly paying duty on it when it arrive) and then setting on fire the first time you use it...
Hokum Jim is offline Find More Posts by Hokum Jim
Old Sep 08, 2008, 11:15 PM
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
I joke because I've done it...
Old Sep 08, 2008, 11:19 PM
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
...more than once.
Old Sep 09, 2008, 01:52 AM
Joined Jun 2007
Yeah.. u are right the 3.7v is a problem. I didn't notice that point.
Maybe the RX-2413 (receiver from Walkera 53Q) will be better since it is 7.4V.
Might give it a try if i can find the receiver online..
Old Sep 10, 2008, 12:02 AM
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
I dug up the info I got from ehirobo.com and they have the parts that you need...
I'm not associated with them but I have purchased parts from them a few times with good results. The postage was reasonable, the items were well packed and received reasonably fast (7-10 days from Hong Kong to Australia).
Old Sep 10, 2008, 03:09 AM
Joined Jun 2007
Thanks for the info.
Unfortunately i couldn't find the rx-2413 on ehirobo.com. Can u pls send me the link if you see it.
I found rx-2411 but not sure if it's the same specs & voltage as rx-2413 or not.
Old Sep 10, 2008, 10:10 PM
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
I see what you mean... the website shows the RX for the 5G4Q3 as being the RX-2408 but the spare part they offer is a RX-4211... Maybe stay clear of this one all together because it's getting too fiddly
...Better yet. This one might be your sweet spot - no photos, unfortunately
http://www.ehirobo.com/shop/product_...oducts_id=6114
It should be the RX-2405 which is the 2.4G reciver for a Walkera 53 (the big Lama type heli) the control setup is the same as an e-sky Lama AND it's designed for 7.4V... and not killer expensive.
Still I'd e-mail them first to confirm. I don't like the lack of a photo or consistent part numbering...
Old Sep 27, 2008, 04:06 PM
gladiax is offline
Find More Posts by gladiax
Joined Sep 2008
hi could i use rx 2411 with 7,4 v lipo battery?
gladiax is offline Find More Posts by gladiax
Old Mar 16, 2009, 05:40 AM
svetsch is offline
Find More Posts by svetsch
Joined Mar 2009
I just bought the new Walkera 2801 transmitter, and I would like to use it to fly my esky lama v4.
Which receiver have you finally used ?
Thanks in advance,
svetsch is offline Find More Posts by svetsch
Discussion Esky Lama V4 VS. Walkera 5G6 PicooMan Coaxial Helicopters 12 Jul 08, 2008 02:19 PM
New Product NEW 2.4GHz Esky Lama V4 Ready To Fly Helicopter Kit Quah Micro Helis 2 Mar 19, 2008 09:11 AM
Sold Esky Lama V4 with all the upgrades luky Aircraft - Electric - Helis (FS/W) 2 Jan 02, 2008 09:10 PM
Discussion Esky lama V4 mode 1 to mode 2? mbt1760 Coaxial Helicopters 3 Nov 14, 2007 08:29 PM
Sold **Esky Lama V4 with Xtreme Blades and Xtreme LED Flybar** wilsgrant Aircraft - Electric - Helis (FS/W) 8 Sep 11, 2007 12:18 AM
